Question about Sharp XE-A402 Electronic Cash Register
Screen stuck on x2/z2 turn the key and it stays on x2/z2 no matter key position
  • Sharp Master
  • 1,635 Answers
It is normally a faulty mode lock unit (especially if liquid may have run into the key hole). Sometimes it can happen if the machine is waiting for you to finish a key sequence in X2/Z2 mode, so try printing an X2 report while the key is in the x2/Z2 position, then after report prints, turn key back to REG. If it is still stuck in X2/Z2 mode, the mode lock is probably faulty.
Posted on Mar 18, 2014
  • 45 Answers
Either the memory is locked in which case you could initial clear (if ur lucky that might fix) or memory reset and reprogram completely, but more likely is that the keylock itself is not working and will need a new keylock.
  • Sharp Expert
  • 591 Answers
What model is you till. Please specify
Ignition of ford edge will not turn completely off..it is stuck in position 2 in auxillary power
1-
My ignition key will not turn to off. I can remove the key, but it stays in the accessory mode. What's the fix?
My ignition key will not turn to off can remove the key but it stays in...
2.
Ignition key is stuck and does not turn Inspection Service & Cost
Ignition key is stuck and does not turn Inspection Service Cost...
3.
Ignition key won turn
Aug 24, 2016 | 2012 Ford Edge
PEA is on the screen and no keys work
stuck splash screen Cash Registers & POS Equipment ...
www.fixya.com > Forum > Tags > stuck splash screen
Ask your stuck splash screen cash register and pos equipment questions. ... ...screen displays PE, machine stops working Register tape won't feed, turning it off then back on ... the register is stuck and is displaying PEA Perfom a master reset ... Screenstuck on x2/z2 turn the key and it stays on x2/z2 no matter key position.
delay stuck Cash Registers & POS Equipment Questions ...
www.fixya.com > Forum > Tags > delay stuck
Cash Registers & POS Equipment delay stuck questions and answers. Ask your delay stuck ... Also if that doesn't work and its a dual com, make sure its set to dial. coppy ... Ad ... the register is stuck and is displaying PEA Perfom a master reset ...Screen stuck on x2/z2 turn the key and it stays on x2/z2 no matter key position.
Hi There my SAM4S is showing PEA on the screen. All the ...
Nov 26, 2015 | Retail Supplies
System error # 07,010.43:27456 on a xerox c2424 copier
The printhead is stuck in the tilt position, need to replace the process motor camshaft kit, part number WCC2424-Z2
http://www.iteminconline.com/wcc2424-z2_wcc2424-z2-xerox-workcentre-c2424-process-motor-camshaft-kit.htm
Jul 07, 2015 | Xerox Office Equipment & Supplies
How to get grand total of the month on sharp cash register ER-2385
I can't believe we still have a book for this one - the ER2385 began production in 1987!
Most business owners take their totals daily. You probably have, too, by turning the key to Z1 and touching
. CA/AT (I hope you can the decimal point in front of the CA/AT. It's essential.)
To take monthly totals, do exactly the same thing, but in the X2/Z2 position.
Note that these totals are monthly only because you print them monthly. If you do it every Saturday night, you'll get weekly totals. The register prints totals that have accumulated since the last time you took a Z2 reading. It's up to you to make them monthly by taking them monthly.
So, on January 31 take your usual nightly total, then the Z2 total. Taking the daily one first ensures that today is included in the month.
Skipping the decimal point before the CA/AT will give you an X2 total. The same numbers will be printed, but they won't be cleared back to zero. That's fine if you want to see your totals so far, without messing them up, but if you forget it at the end of January, then February's totals will include both months. The same rule applies to daily totals. Use the decimal point if you want the numbers cleared.
While the CA/AT key gives the familiar department totals, other readings are available.
PLU gives your PLU totals, if you use them. (X1 and Z1 only)
#/TM gives totals for each hour of the day (X1 and Z1 only)
SBTL gives a total for each day of the month (X2/Z2 only)
Dec 30, 2012 | Computers & Internet
How to grand total of the month on sharp cash register ER-2385
That is a very old machine. It might not have enough memory for two Z reports. if it has a Z2 position, turn the key to Z2 and press CASH (if it is marked X2/Z2, press decimal point before cash). Note: If you have never used the second report it will have a large total built up. you will need to reset it as above to clear it and then it will be correct from the next month onwards.
Dec 30, 2012 | Casio Parts Cash Register PC Desktop
How do i reset the x2/s2 readings on a casio se-s300 cash register please?
Try turning the key to X2/Z2 then press RA until you see the report that you want. then press CASH.
Nov 24, 2011 | Computers & Internet
How do I reset the grand totals to zero on my sharp cash register model XE - A406
Go to PGR, hit tm/sbtl, then hit 64 (black keys) @10 (black keys again), tm/sbtl. Then go to x1/z1 and hit decimal point and then ca/at/ns. Do the same with x2/z2.
Oct 04, 2010 | Sharp XE-A402 Electronic Cash Register
ITS DOING NOTHING
I'V GOT A CASIO TK-2300 ELECTRIC CASH REGISTER.ON SCREEN IT SHOWING INDW OVER 0 WHEN I PRESS ANY KEY IT SHOW MAC-CODE 0 THE NUMBER PAD IS WORKING.IF I TURN THE KEY TO REG1,REG2,RF,PROGRAM IT STAY SAME BUT IF ITURN KEY TO X1,Z1,X2/Z2 IT SHOW OPE ERROR 0.CAN SOME ONE HELP ME TO SOLVE MY PROBLEM.THANK YOU.
Apr 16, 2009 | Casio Parts Cash Register PC Desktop
0 THE YEAR TO DATE OUT OF THE CASIO TK-2700
Hi.
Have you had periodic reports setup on this machine? If you do daily reports, then you need to use the periodic report mode (Z2) for a yearly report. Try turning to Z2 then press 1 then CASH.
Make sure the top of the report shows 'Z2' and not 'X2'. If it shows the X then it probably hasn't been setup for periodics.
Mark
Jan 02, 2009 | Casio Parts Cash Register PC Desktop
Sharp XE-A402 Electronic Cash Register Logo
97 people viewed this question
Top Sharp Retail Supplies Experts
k24674
Electroboy
Electroboy
Are you a Sharp Retail Supply Expert? Answer questions, earn points and help others
