Question about Quad 47 cc / 49 cc Pocket Mini Bike Scooter Atv Pull Start
I opend the pull start cover the coil,rope and spring came out?
I tried to fix the pull start on my pocket rocket dirtbike because it got stuck so i opend it and the coil, washers, rope and spring fell out how do i put evertithg back together again..
plz help
You have to put the spring back into a circle thing how it was when you would have seen it before, then put your spring in put on the plastic bit with the pull chord in it and bolt it up, it should all work out well if you take time to do it! :)
Posted on Oct 02, 2011
    Problem Solver:
  • 16 Answers
I won't try to much work i would just buy a new one
Posted on Jan 26, 2010
How do u remove recoil spring assembly that is held in place by a roll pin on a 4hp Briggs and stratten
I suspect you asked this question because your recoil starter rope has broken , so first let me say be extreemly carefull the coiled spring on top of rope pully has a lot of tension to it , it can and will hurt you if it gets out of the pocket it sets in, what ive allways done is to NOT remove the pully at all but hold it with a large C clamp i put this on right after i get about 6 good turns to tighen the spring then i apply clamp , use a razor knife to cut ball off end of old rope and pull out using pliers thread new rope from outside rope guide to into the rope pully and knot if off in original hole (use a lighter to part melt rope end) measure off about 5 feet of rope and tie starter handle on there then its simple just slowly let clamp pressure off the pulley will pull rope in to cover automaticly done !!!
Aug 24, 2014 | Mtd 22" Yard Machine Push Mower
How do i rewind the recoil spring on my craftsman lawn mower?
Normally these small engines use a clock spring to retract the rope.
Remove the cover on the top and you should find the spring either broken or the tab where the spring end has broken off or jumped out of the mount.
You will need to pre-load the spring with enough tension to retract the rope.
Remove the pull handle from the rope, load the spring and then wrap the rope around the pully holding the pully and spring in the loaded position. place the end of the rope through the hole and tie up the handle. The rope should pull and retract without being installed on the engine.
Best explained here...
https://www.youtube.com/watch?v=tmo6oYOJJ4U
Jun 27, 2014 | Mtd 22" Yard Machine Push Mower
Starter cord will not pull
The pull cord or rope works on a tight spring just under the cover that the rope is in. Usually three to four small bolts on the edge of the cover to remove to repair/replace either the spring or the rope. First I would try to turn the motor manually with your hand on the flywheel, it should move around either direction freely with no effort. If it does not the motor itself maybe stuck not the rope. Then you have a seized engine and a different problem to deal with.
Dec 27, 2013 | Husqvarna 41 141 41 136 36 Recoil Pull...
DO I NEED SPECIAL TOOL TO REFIT COIL SPRING WHICH CAME OUT WHEN FITTING STARTER PULL CORD
There are special tools made for this job, however not needed for most jobs (makes easier). Clean the spring and lube slightly with silicone spray or light oil. Catch the end of the spring that would be the outer end onto slot or pin and slowly spiral the coil into place holding down coils as you turn(dont try to coil the spring then drop it in, take your time as you wind and maybe ask a freind to lend a third hand if your fingers get tired, once you start you cant stop). The inner part of the coil has a bent hook that will catch on the inner portion of the pull rewind. Lood at how the rewind catches this hook by turning the rewind in the direction that it turns when you pull the rope. When you pull the rope it winds the spring. If you put the spring in backwards the rewind spring will not catch. Once you got the spring in place, turn the rewind in the direction that it turns when you pull the rope until it stops, then release one turn and insert rope thru guide and into spool to tie knot. Slowly let rewing pull in new rope. Good luck
Aug 23, 2011 | Electrical Supplies
Rope pull start rope is stuck on Troy-Bilt weed trimmer
There should be 3 screws holding the cover on. Take those out and pull the cover off. The is a spindle and spring on the inside. rewind the cord and put it back together with the spring tabs in place. The tabs tend to come undone.
Apr 24, 2011 | Sport & Outdoor - Others
The coil rope broke I would like to know how i can repair it. Generator 5500 watt champion.
If I understand correctly, you have a pull-start generator.
The rope to the pull-start broke.
This happened to us out on the job one day.
Our equipment might be different than yours. Our pull-start assembly is held with 4 bolts. Simply remover those bolts and lift off the cover ... carefully. The rope is attached to something I will call a pulley. The rope wraps around the pulley several times.
Do not lift out the pulley that the rope attaches to >> or the spring that re-winds the rope will come un-sprung (at least it did on our machine). If the spring comes unwound, then you got another job, and have to put the spring back also. Your machine might be different.
Keep pulley in place. Remove rope. Get another rope with same diameter and length and put it in.
Oct 18, 2010 | Champion International Champion Power...
Hey Google ur question about the pull start and there's a video that shows u how to do it its real easy.
Apr 01, 2010 | Quad 47 cc / 49 cc Pocket Mini Bike...
Replacing starter pull cord on Cub Cadet mower
1st get same size cord 24" long .remove pull start assy. remove old rope.burn & smash ends flat of new rope(helps it go thru holes on pulley & cover easy). tie small knot in 1 end of rope. unwind spring pressure like if rope is pulled all the way out when starting.align holes in pulley & cover .fish rope thru holes start on pulley side, out thru cover so knotted end on pulley side.when ropes thru slip handle on .rewind spring will wind itself pulling rope in . your done
May 05, 2009 | Garden
When try to pull on the rope to start the mower is will not move. It feels like it is stuck. But I can move the blade around. Thank you
I thing the recoil spring is stuck it may be rusty. Its time for a complete maintenance on this mower. But you could try tapping the top of the recoil where the rope coils up into. Bang it a few times as you pull on the rope. this may free it up. Good luck DFD
Apr 20, 2009 | Garden
Quad 47 cc / 49 cc Pocket Mini Bike Scooter  Atv Pull Start Logo
866 people viewed this question
Top Quad Cycling Experts
Marvin
Marvin
shaun taylor
Charles T Nevin
Charles T Nevin
Are you a Quad Cycling Expert? Answer questions, earn points and help others
