Question about Dyson Flowcheck CRO1 Front Load Washer
Dyson cr01 fault F4
We have just had to take our machine apart to get to the fuse that had blown on the circuit board. Fuse was replaced & all looking good to go, then it has come up with a new fault saying "close inner door & press start". I'm getting very frustrated with this machine now.
  • Official Brand Answer
  • 2,572 Answers
Hi Sue, it's Jack at Dyson.
An F4 fault code means 'inner door opening'. Unfortunately since 31st December 2012, we have been unable to support CR01 and CR02 washing machines with spare parts or servicing. In October 2012 proactively wrote to all CR01 and CR02 owners that we'd interacted with within the last 3 years to make them aware of this.
If you would like to discuss your concerns further with one of our experts, you can reach us on 0800 298 0298. Calls are free from UK landlines, and we're available from 8am-8pm from Monday to Friday, and 8am-6pm on weekends.
Posted on Mar 18, 2014
  • George Kearse
    George Kearse Apr 29, 2014
    What you are saying isn't true. I've not received any communication from Dyson about this and I last serviced my washing machine the 25th of September 2012!!!
  • AskDyson
    AskDyson Apr 29, 2014
    Hi George, please be assured we did write to owners to advise them that support for Dyson washing machines would be discontinued. I can only apologise if you did not receive this communication. If you'd like to discuss your concerns further, please give our freephone Helpline a call on 0800 298 0298. We're available from 8am-8pm from Monday to Friday, and 8am-6pm on weekends. Calls are free from UK landlines.
Hello
I'm in France, my dyson wach, :
Wat is mean :
0F255F255F255F4D
thank you
Posted on Nov 24, 2014
The machine stopped working and tripped the fuse box i changed the fuse still not working
Something electrical has blown in the machine causing the fuse to blow. After replacing the fuse , the machine isn't going because whatever blew is now "open circuit" Have a look for obvious blow outs on any of the switches, control boards , all other electrical components and the wiring. look for telltale black marks where something has "blown" on the cabinet or around the components.
Mar 20, 2017 | Washing Machines
No lights,no clock no functions. Power to the unit is good. Any suggestions?
The likely cause for your radio not functioning is a blown fuse on the power supply circuit board. Unless you are able to take the clock apart and solder a new fuse to the board, your best option is to purchase another radio. If this clock radio is a wall plug-in, the fuse may have been blown during a thunder storm.
Mar 24, 2015 | Audio Players & Recorders
Blown fuse and Q12 is blown apart. Who repairs this inverter board 8181330?
no make ,no model we can noy look up the code but bets are no one repairs boards just replace till no longer available
Mar 18, 2015 | Washing Machines
How to power my deskjet 450?
I would take it apart and look for burnt spots on the circuit board and for blown capacitors. If it has a fuse, and it is blown, make sure you replace it with one of the same rating. DO NOT BYPASS IT! Also, make sure it's unplugged and wear a static grounding bracelet. Good luck
Jul 31, 2014 | HP Deskjet 450 wbt Printer
My machine wont power on. I checked the outlet and it is fine.
you have blown the fuse on the main board. you will need to check short circuits in your pump and motor, and for leaks onto any electrics, and then replace the motor control board (or try to replace fuse on board if other components look fine ie no burn marks)
Oct 06, 2013 | Fisher and Paykel WA37T26G Top Load Washer
Blown fuse on a ilpi-009 power supply
hi, i don't know the exact power board you speak of, most fuses for power supply protect ac inboard power, and backlights. if backlight inverters touch ground or ground out, this will blow fuse. otherwise, the fused circuit is used for main inboard power going to primary capacitor. take an automotive fuse holder and solder test leads long enough to work with, install 4 amp blade fuse and jumper/solder the circuit to the fuse on the board and power on the monitor. if all goes well, probably just power surge or outlet grounded. if blows fuse, check to board for obvious burns or blown capacitors. if not there, unplug backlights and power on, if still blows, check to make sure no direct conact with board and back of screen. just be thorough about looking carefully for shorts if there is one. and don't forget to replace the factory fuse on the board with the correct one after you finish repairing, don't leave that automotive fuse in. good luck.
May 10, 2010 | Emprex LM2201 22" LCD Monitor
Drink o matic problems. help!!!!!
Ok here is the poop. I just tore mine apart the green light did not come on and the fan did not work. I looked at the circuit board I don’t know how many times before and missed a covered fuse. There is one (maybe it is a decoy) fuse that sits out in the open it was fine. But this fuse is next to the outlet wire on the circuit board was blown. It is small and covered with black shrink tape. This fuse is very easy to overlook. I unsoldered the ends and replaced the 12V 5 amp fuse. I used an inline fuse holder during replacement so if it goes out again I can just change the fuse. It is worth a look, good luck.
Jun 02, 2009 | Sharper Image Drink-O-Matic
I need a 120v power supply circuit board
purchase a AC to DC adaptor and use the 12volt power cord plugged into it.. these are commercially available, just make sure you purchase an adaptor that can handle the power used by the fridge which is on the back of the unit.
May 30, 2009 | Sharper Image (SI714SL2) Compact...
Machine no power, power supply good, fuse in plug good machine will not turn on.machine type zanussi washer dryer 3 months old.
hello inside the machine theres is circuit board at the bottom there might be a glass fuse on the board which might have blown make sure the power is off before you check it good luck
shaun
Mar 18, 2009 | Zanussi WJS1265W Front Load Washer/Dryer
In line fuse
I suspect that the fuse is 0.75 A, and I believe that it is soldered in place. Can you see that it is blown?
Mar 27, 2008 | Bose Wave Radio
Dyson Flowcheck CRO1 Front Load Washer Logo
154 people viewed this question
Top Dyson Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Dyson Washing Machine Expert? Answer questions, earn points and help others
