Question about Bosch Dishwashers
Bosch SGS6302 Dishwasher failing to complete cycle
My Bosch SGS6302GB/07 was running when we had a power cut. Since then it will not complete a full hot wash cycle, only the Quick wash. When trying to run the full 65 deg programme it runs for a while (about 30 minutes) then cuts out with all the power lights and indicators extinguished. Water is left in the base. If we leave it for 10 mins or so it can be restarted but often will pump out but still not finish cycle. Can't understand why power cut caused this problem - we've had it for many years and prior to that has worked perfectly. It seems to be some form of overheat/thermal safety cut out. The drain is clear - often on restarting it will immediately drain fully. No obvious blockage in filter or outlet pipe.
    Top Expert:
  • Bosch Master
  • 25,706 Answers
Does it heat properly? Was that the cause of the power failure?
Posted on Mar 17, 2014
  • 2 more comments
  • Ian Corfield
    Ian Corfield Mar 18, 2014
    The water gets hot as expected. I tried again last night and it stopped after about 12 minutes into the 65 deg. cycle. The power failure was a power cut to the general area where we live. I don't think the power was out for very long but it was during the night so can't be sure as we were asleep!
  • Ian Corfield
    I've just run a "Quick Wash" cycle (31 Minutes) that has completed OK. No residual water and the dishes are hot so it is heating the water. However the water temperature is probably lower thanthe 65 deg on the full wash. I'll try a 55 deg "Eco Wash" next.
  • Ian Corfield
    Ian Corfield Mar 19, 2014
    no it won't complete an Eco wash either.
  • James Smith
    James Smith Oct 19, 2014
    Ian, hopefully you're still monitoring this thread. Did you ever find the cause of the problem? I have just picked up a used one of these dishwashers and it is exhibiting exactly the same symptoms as you describe.
How to run self test on bosche dishwasher
Here is an excerpt from "Bosch Dishwasher Troublesoooting".
Running a Test Cycle
Bosch dishwashers have a test cycle which can be run as a troubleshooting measure. The method to run this test cycle is similar across the Bosch dishwasher range so if your dishwasher features seems different from those described below then try experimenting, as the process is fairly straight forward and will be very similar. Bosch dishwasher model numbers are usually found around the top or lip of the door. One of the most common differences between dishwasher models is simply the names of the buttons. For example in the first example below, POWER SCRUB PLUS and REGULAR WASH may be called WASH and ECO depending on your dishwasher model and the country you are in. The other key difference is whether your dishwasher has a display panel (which can display error codes) or not (in which case a program light will illuminate to tell you the fault.
To run the test cycle hold down the POWER SCRUB PLUS and REGULAR WASH buttons. Whilst held down press the ON/OFF button. The lights above them should flash. Now you can check the status of each dishwasher program by pressing its button. Now you can run the full test cycle = Press the POWER SCRUB PLUS and REGULAR WASH buttons again. The dishwasher will start up and when the cycle has ended one, if you have no display panel on your dishwasher model the indicator lights will illuminate if a malfunction was detected as follows -
CLEAN - A temperature sensor fault. If this is the case then the test cycle will be very short as the dishwasher will terminate the test once it's been detected.
RINSE/DRY - A water sensor/filling fault. If this is the problem then the test cycle will not complete as the dishwasher cannot detect the right level of water, the dishwasher will just keep filling and draining again.
WASH - A heating fault. Check your heating element.
If you do have a display panel on your Bosch dishwasher then after the cycle is complete an error code will be shown if a fault has been detected. The error codes are as follows -
0 - No errors have been detected.
1 - A water sensor/filling fault.
2 - A heating fault.
4 - A water filling fault. This can also appear as F on the display during a normal cycle.
8 - A temperature sensor fault.
When troubleshooting your Bosch dishwasher, running the above test cycle is a good start in diagnosing the problem and should give you an idea of where the problem lies with your Bosch dishwasher and what fixes and repair are in order. Our general troubleshooting page will give you some ideas on other things to check on your dishwasher. Good luck!
Mar 29, 2013 | Bosch 24 in. SHU5305UC Built-in Dishwasher
My Bosch Dishwasher is not drying my dishes now. The model number is SHE44C05UC.
Unfortunately, it seems that the heating element has failed. The dishwasher uses steam to heat the tub to dry the dishes. I suspect your dishes are also being washed in cold water.
To check this, please run a regular full wash cycle. Allow the washer to fill with water and run for about 10 minutes, then open the door and feel the water temperature in the bottom of the washer. If the water is cold, it's more than likely the heating element has failed.
There are other possible faults which would cause the element not to heat, but these often prevent the dishwasher from completing the cycle. If the water is cold but the dishwasher still drains the water at the end - and completes the cycle - the heating element has probably failed.
Please try this simple test for water temperature and let me know if you need further assistance.
Regards,
BElectric
Feb 18, 2011 | Bosch 24 in. SHE44C05UC Stainless Steel...
Bosch dishwasher shx55m with bottom tub full of water
The dishwasher really shouldn't pass any particles near large enough to clog the drain hose. It sounds more like a mechanical issue. Check the circuit breaker to make sure it's not tripped. See if you can hit a cancel button or something to make it drain. Try to run another cycle. If the computer is stuck or acting funny, trying cutting the power for a while, holding down a stop/reset/cancel button, or running a cycle that you don't usually run. I had this kitchenaid that would randomly refuse the normal wash cycle, but would run fine when you ran rinse only or something, then regular wash and everything would be fine again too. If the line somehow is clogged, there's a good chance it's right where the hose connects to the disposal or drain pipe.
Feb 18, 2010 | Bosch Integra® 500 SHX55M05UC Built-in...
Bosch Dishwasher, model SGS6312GB/07. The water does not heat up so the dishwasher does not complete its cycle and remains in wash mode. The water has to be scooped out
press cancel/drain sequence to get water out-check owners manual.
2 possible solutions to your problem discussed here:
http://www.squidoo.com/Bosch_Dishwasher_Drainage_Problem_Fixes
problem may be a burnt out solder connection on circuit board
call bosch to see if it recall issue
Oct 30, 2009 | Dishwashers
Dishwasher not draining after a power cut
I would run the heated dry cycle a few times to try and get rid of that residual water, then restart the cycle and see if it work now. If it still is a problem try cleaning out the drain line behind the dishwasher, this is a very common problem with draining. If not that then might need a valve or if you have a new garbage disposal you need to punch out a peice of the plastic or it wont drain. Hope this helped, good luck
Jul 14, 2009 | Bosch 24 in. SGS43C12 Classixx...
BOSCH SGS6302GB
Hi nikkij
It is simple to put them back on. the plastic pices fit on the bottom of the hinges. there is a cut out where they fit in. when you look at the door at the bottom you will see the hinges and the cut outs, the plastic pices fit in the cut outs flat side in. hope this helps
Sep 15, 2008 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Bosch sgs6302gb
the problem is the circulation motor needs to be loosen up take a 5'16 driver open the filter on the bottom and loosen it at froom thr small hole on the left.
Dec 10, 2007 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Dishwashers Logo
218 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
