Question about Garden
MOUNTFIELD lawnmower SP454 SERVICE MANUAL
I have taken the carb off and and i can't get it back to working
  • 64 Answers
What model and manufacturer is the carb?
Posted on Apr 29, 2014
4 Suggested Answers
mowerman1857
  • 389 Answers
SOURCE: how much oil does a mountfield omega lawnmower take
If it is a small horsepower engine 4, 5, 6 HP, it will take approximately 20 ounces. If it is a larger engine8, 9 ,10, 11, 12 and on up it will take from 40 to 48 ounces
Posted on Sep 15, 2009
  • 110 Answers
SOURCE: service manual
No such thing exists - but you can get an Operator's Manual for the engine if it's a Briggs & Stratton, direct fron the Briggs web site.
Posted on Sep 22, 2009
Knucklebstr
  • 222 Answers
SOURCE: my mountfield petrol lawnmowers pull cord has gone
I'm going to link you to my two favorite "How-To" videos. Depending on your machine, one of these will show you enough to do it yourself. Once you do one, You'll be a pro. Just make sure you use enough rope and do not wind the spring too tight or you'll break it;
Video 1: http://www.youtube.com/watch?v=GyjQir3b3xI
Video 2: http://www.youtube.com/watch?v=i3ZMVFi0yqY
Best of Luck to you.
James
Posted on Nov 12, 2011
How do you replace the piece that the belt an blade are attached to on a mountfield RV 150
you talking about the self propelled model
Repairing Lawnmowers For Profit Part 55 Replace Mountfield Lawnmower Drive...
the blade is a one piece ..you take that off
take off the belt cover
if really stuck .. use a puller for the pully/blade boss
remove the back plate to get to the idler tension pully
there was a tension device or ider pully and spring
for the belt tension
Jul 03, 2016 | Garden
I should be grateful if you could advise me how to remove the cutting blade on the Mountfield hp474 lawnmower
I would suggest you contact the manufacturers customer service with the year and model number...
May 02, 2016 | Garden
Hi i have a mountfield rv40.Not been used for a while.put fresch fuel in it, started it up fine but cut out after few secondsanyone help me?have checked fuel for tank to carbhave taken carb apart and...
Tom Make sure that the gaskets on the carb are back good and tight. They may be worn due to taking it apart. The engine sucks the fuel through with the vac seal caused by the piston drawing. If the carb 'o'ring is not seated right it wont create a proper seal.
Jul 19, 2013 | Garden
I am looking for a Mountfield HP 470 Lawnmower instruction manual
I have a Mountfield HP 470 Petrol Mower 8 years old and I have started it the for the first time and it runs but seems to be hunting or missing as I cut the lawn.
Mar 24, 2011 | Garden
Cannot get my Mountfield lawnmower going. Have primed but just won't start?
make model engine might just need spark plug or carb cleaned dont know what you have!!!!
Mar 20, 2011 | Garden
How do I change a worn Carburettor Gasket and Diaphram on a SP470 B&S Engine on my Mountfield Lawnmower? I'm good at DIY. The engine is hunting and running erratically.
Hunting and erratic operation are signs of air leaks or diminished fuel flow at WOT settings.
If this mower is running a vacu jet style carb with a diaphragm you simply take off the air cleaner, the vent tube, and then the four screws holding the carb on the gas tank and after the carb body can be lifted remove the throttle linkage so you can flip over the carb and pull the main jet and clean the inlet screens.
http://www.psep.biz/store/briggs_stratton_carburetor_kits.htm
Aug 11, 2010 | Briggs & Stratton Garden
Just bought a mountfield sp454 mower filled it with petrol the petrol then started to pour out of fuel bowl there was a plug missing fitted a small bolt in the hole then started the mower it felt as though...
Get he model, type and code off of the engine shroud and take them to your local small engine parts dealer and get the proper bolt for the fuel bowl. They use a special bolt that is hollow and with a weep hole for the gas to flow through the inside of the bolt and up into the carb. Get the right bolt and it will most likely run for you.
good luck
roundo4
May 23, 2010 | Garden
How much oil does a mountfield omega lawnmower take
Sep 13, 2009 | Garden
Garden Logo
603 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
