Vizio picture Here is a picture of the problem- http://i1360.photobucket.com/albums/r647/Jay_Everett_Kadlec/10006736_10153884433695142_659371861_o_zps939e9e1e.jpg Basically it is blowing out and distorting the highlights. I've messed with the picture settings and got it a little better but still far from fixed. What is the problem and how can I fix it?
  • 42 Answers
It looks like your picture is zoomed, that control should be on your remote. Or change your picture ratio. Tints are all messed up. I would bring everything back down to black and white and start adjusting back up. To do this you have to be in picture mode custom (your pic shows your in standard mode). Everything else is preset for you. Go into all your settings and make adjustments. I also own a Vizio. It took me several attempts to adjust the picture to my liking.
Posted on Mar 17, 2014
5 Suggested Answers
  • 2318 Answers
SOURCE: Dell W1700 LCD no picture, already replaced board
I would suggest to remove the connector from the board and the wire harness and solder the wires directly to the board. In many cases the high current that runs through that connector makes the connections overheat due to the poor contacts at this location. A solid solder connection will last longer.
Good Luck.
Posted on Mar 18, 2008
SOURCE: Red Lines in Picture grainy picture
Try checking the board for swollen caps.. That fixed my Vizio p4
Posted on Sep 10, 2008
  • 192 Answers
SOURCE: Help me please - Gateway FPD2185W
Ok, I have some news on this that I know you will not like, but the whole point of this site is to try and help you fix the problem, or at least, try and point you in the right direction.
The news:
I have done some extensive searching on this problem over the last month, as I have also had a friend with a similar problem that you are describing. There is a manufacturer's fault on the main power board, this has been recognised by Gateway, but as it happens inconsistantly (it may happen after a few months or a few years), they are not prepared to recall the product.
Obviously this doesn't help us as consumers that buy their products. The blue screen that you describe happens with alot of visual hardware inc. graphics cards that affects the whole market, and has now become affectionately known as The Blue Screen Of Death (BSOD).
If you are one of the lucky one's, and it is still under the manufacturer's warranty, get it sent back asap, and ask for a replacement to a similar model. If not, the only thing you can do is get it repaired or get a new/2nd-hand one.
Like I said, I'm sorry this isn't the news you wanted, but I didn't think it was fair for you to hang on.
Regards
Tim
Posted on Dec 09, 2008
Mas Baz
  • 177 Answers
SOURCE: LCD tv Vizio 42 inch has vertical colored lines
hello imvega7, as i know, 42 inch is a plasma display TV.
Refer to your image, and my experience that symptomp because of connection between buffer PCB and panel. Some cases, dirty conection may cause this symptomp.
Un plug power cord, open rear cover, fine pcb on upper or lower panel.
unplug flat cables from pcb buffer, clean soket using a brush. And also clean flat cables using celaner or alcohol.
Wait untill that conection dry. reassembly and try it.
i hope that help you.
Posted on Mar 15, 2011
Testimonial: "Very detailed."
My vizio 37 inches hdtv went black with no sound. can this be fixed?
Yes,power of the tv just have a tv LED power light indication flashing or blinking only?Yes.Tries tv unplug,replug it back like about an hour later for the tv to do a whole resetting itself back to factory setting.Tv should be working again.If not than the tv power supply board have a problems and the causes.That the board where the tv power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish a tv power supply board for the replacement.
Sep 03, 2011 | Vizio L37 Television
Tv has no power worked fine yesterday tried to turn it on today nothing no power light
The power supply module may have failed, I would inspct the main AC fuse first.
http://s807.photobucket.com/albums/yy352/budm/VIZIO/VIZIO%20L32HDTV10A/
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: http://interliquidparts.com/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Jul 14, 2011 | Vizio L32 32 in. LCD HDTV
Vizio wont turn on yellow light is not e\ven on
The indicator light is not on, that means the 5vdc standby is not working, you need to inspect the power supply module main AC fuse and other component in the power supply. See pictures here:
http://s807.photobucket.com/albums/yy352/budm/VIZIO%20L32HDTV10A/
Apr 16, 2011 | Vizio L32 32 in. LCD HDTV
Tv screen went black no sound or anything
You need to inspect the power supply moulde first for bad caps and output voltages, here are the pictures of the boards (there are more than one version of this TV): http://www.shopjimmy.com/catalogsearch/result/index/?q=VIZIO+L32HDTV&limit=50
Basic troubleshooting guide here:
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Feb 01, 2011 | Vizio L32 32 in. LCD HDTV
No picture power just a yellow light
Check the power supply module for bad DC filter caps, and the DC output voltages. Check the backlight inverter board for short circuits.
If you are going to DIY and have proper tools, knowledge of electronics and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://s807.photobucket.com/home/budm/allalbums
Jul 13, 2010 | Vizio L32 32 in. LCD HDTV
Sep 10, 2008 | Televison & Video
Omnitech jumbo universal remote control and vizio hdtv
I have a solution but it is too much info for this tiny screen they have, and there is no support for photos1.gif. So, unfortunetly I have to send you to my photobucket account where I posted scanned pictures1.gif of the "Acual Manual" I hope the website doesn't get banned. Here are the five pages you'll need to set up your giant remote:
http://i162.photobucket.com/albums/t241/swestside/5.jpg
http://i162.photobucket.com/albums/t241/swestside/4.jpg
http://i162.photobucket.com/albums/t241/swestside/3.jpg
http://i162.photobucket.com/albums/t241/swestside/2.jpg
http://i162.photobucket.com/albums/t241/swestside/1.jpg
Jan 02, 2008 | Big Button TV Universal Remote
Televison & Video Logo
64 people viewed this question
Top Televison & Video Experts
Electro Med Services...
