Question about Stairmaster 4600 Cl Cordless Freeclimber
How to charge the batter on stairmaster cl 4600
  • Stairmaster Master
  • 914 Answers
If they battery is not bad, you can recharge using the battery charger for this machine. This link will take you to our site for purchase.
Power Supply Kit with Plastic Output Connector Domestic Stairmaster...
Posted on May 20, 2014
4 Suggested Answers
maxtreadmill
  • 832 Answers
SOURCE: stairmaster climber model 4600 pt pedals go all
Unplug dc power connection then remove right side panel check for loose connections on on alternator, check distance of speed sensor to speed sensor disc you should no more than 3 credit card distance between them. Next remove the black wire from the B+ terminal on the alternator, then remove the brown wire from the field terminal on the alternator.Place a short wire with alligator clips between B+ and field terminals start stepping for about 10 to 15 second you should full resistance in that case its the upper console that if not replace alternator
Posted on Mar 14, 2010
SOURCE: looking for a manual for stairmaster 4600 free
Hi, I just purchased a used StairMaster 4600CL last week, and found a link for an owner's manual that covers the StairMaster FreeClimber 4200 PT, 4400 PT/CL, and 4600 PT/CL. This is a free, .pdf download:
http://gymstore.info/manuals/upload/StairMaster/stairmaster_freeclimber_4200_4400_4600pt_cl_c40_om.pdf
Vanessa
Posted on Dec 27, 2010
  • 30 Answers
SOURCE: where can i find the power supply for stairmaster
contact sportsmith fitness products you can find them on the interenet
Posted on Feb 03, 2011
Where is the battery on the free climber 4600 cl located?
http://www.sportsmith.net/images/product_support%5Cstairmaster%5CDiagrams%5C4600CL%20Assembly%20Diagram.pdf
Apr 03, 2013 | Stairmaster 4600 Cl Cordless Freeclimber
Stairmaster freeclimber 4600CL will not accept any program for a less than 100 pound person. My husband gets on and it always works fine. I am wondering if the lighter weight will not keep the batte
A new battery will more than likely allow you to use the machine, but the lighter weight is not recharging the battery correctly. I would suggest replacing the battery and possibly adding an external charger. Repair Parts for Stairmaster Equipment Batteries Springs Belts Chains...
Jun 07, 2012 | Stairmaster 4600 Cl Cordless Freeclimber
How do you tighten the cogged timing belt on a stairmaster 4600cl?
hi
i think you have bad timing belt usually you tighten it through alternator bolts
if it is skipping you should check one of crank bearings it could be gone bad
Dec 04, 2010 | Stairmaster 4600 Cl Cordless Freeclimber
Where in the world is the battery for the Stairmaster 4200 PT? I have read the manual multiple times and taken the cover off and still can not find it. Help!
There is not a battery in this unit. Stairmaster steppers that require a battery are labeled as CL for cordless. The PT machines have a power supply that plugs into the wall.
Stairmaster Stepper 4200PT Parts Eccentric Hub Pedal Arm SPORTSMITH net
Sep 12, 2010 | Stairmaster 4600 Cl Cordless Freeclimber
Machine has not been used in a long timescreen is flashing is battery dead? how do i charge battery?
You may get a battery charger for National Gym Supply, If that battery has been in that unit for a good length of time I suggest replacing it. Here is their Ph# 1-800-496-7278
Jun 10, 2010 | Stairmaster 4600 Cl Cordless Freeclimber
Looking for a manual for stairmaster 4600 free
Vanessa
Jan 23, 2010 | Stairmaster 4600 Cl Cordless Freeclimber
Freeclimber 4600 CL full resistance
Check all connections and make sure all wires are not broken or smashed. Replace lwr cntrl board.
Aug 27, 2009 | Stairmaster 4600 Cl Cordless Freeclimber
STAIRMASTER 4600CL RIGHT PEDAL LOSES RESISTANCE AND SLIPS
http://support.nautilus.com/support/stairmaster.jsp?lid=StairMaster you can download and view all manuals here. If by drive sprocket you mean the hub that both step chains go over.....replace the entire hub. faster easier and less hassle. cost difference is about 40 dollars.
Jan 31, 2009 | Stairmaster 4600 Cl Cordless Freeclimber
Stairmaster 4600 Cl Cordless Freeclimber Logo
167 people viewed this question
Top Stairmaster Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Matt Olenzek
Matt Olenzek
zr800o1le
zr800o1le
Level 1 Expert
Are you a Stairmaster Exercise and Fitnes Expert? Answer questions, earn points and help others
