Epson Stylus Photo 1400 Printer Logo
s
surasen mohapatra Posted on Mar 17, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Epson stylus photo t60 paper light and ink light blinking error
Robert Allocca
Level 2:
Sergeant:
Champion:
  • Epson Expert 387 Answers
  • Posted on Apr 29, 2014
 Robert Allocca
Epson Expert
Level 2:
Sergeant:
Champion:
Answers
387
Questions
Helped
83616
Points
609
5 Related Answers
Anonymous
  • Posted on May 27, 2008
SOURCE: Epson stylus photo R1800 printer
http://www.fixyourownprinter.com/forums/printer/35608
this website will answer all your problems
Anonymous
  • Posted on Feb 16, 2009
SOURCE: epson stylus photo 950 printer flashing lights
I had the same Problem and checked the solution:
This is a Printer Maintenance request.
Ink Overflow -
you sould change the waste ink pads under the printer mechanic.
Solution:
websnail
Martin Smallridge
  • 419 Answers
  • Posted on May 12, 2009
SOURCE: reset ink-pad counter on epson stylus photo 1400
The simplest way to do this is to grab a copy of the A10_IPR utility that Epson distribute to their customers...
The utility is available to North American customers if you register no this site page http://www.epson.com/ipr/
The utility is also know to be available in the wild if you search for "waste ink ipr".
Just remember to scan any download using a virus and malware scanner before you attempt to use it as some utilities contain trojans or similar nasties.
Hope that helps.
aicaxz
Anjazmoro Wicaksono
  • 511 Answers
  • Posted on Jun 26, 2009
SOURCE: alternate flashing red lights on epson stylus photo 900
Flashing alternately? Need reset waste ink. SSc ver 4.3 support this model. Find at indoreset.blogspot.com.
websnail
Martin Smallridge
  • 419 Answers
  • Posted on Dec 03, 2012
SOURCE: Epson Stylus Photo P50 - flashing alternate amber
This is an identical issue to the one reported here:
http://www.fixya.com/support/t13406382-epson_p50_not_respond_blinking_lights
As per the information provided in my solution you can either get the printer serviced or fit an external waste kit and reset the waste counter yourself.
Epson t60 general error
A "general error" with two red lights blinking on an Epson T60 printer can be caused by various issues, such as a paper jam, a foreign object inside the printer, a problem with the ink cartridges, or a malfunctioning of the printer mechanism.
To troubleshoot this issue, try the following steps:
  1. Turn off the printer and unplug it from the power source.
  2. Check for any paper jams or foreign objects inside the printer and remove them if found.
  3. Ensure that the ink cartridges are installed properly and have enough ink.
  4. Check if any of the cartridges are damaged or expired and replace them if necessary.
  5. Clean the print head using the printer software utility or manually.
  6. Check the printer mechanism for any damages or obstructions and remove them if found.
  7. Turn on the printer and check if the error persists.
If the issue persists, you may need to contact Epson customer support or a certified technician for further assistance.
Epson t60 the two light are blinking
The Epson printer light blinking when you have low or empty ink in tank, Lack of communication between printer and computer, printer print head overheated, fuser not working and more.
Follow the steps to fix Epson printer lights blinking error:
·Fix paper jammed
·Check printer ink cartridge
·Check network connection
Read more steps to fix Epson printer lights blinking error.
1helpful
Epson 1440 printer repair
both the paper/ink buttons blinking in red simultaneously means fatal error. Use AP for figure the latest fatal error code. Btw, i have Service manual for 1400. Contact me at aicaxz(at)yahoo(dot)com
Red paper and ink lights blinking
red paper light is blinked as it is indication that plz insert paper in your printer, and ink light blinks because your printer is low on ink, kindly get your printer cartage refilled.
1helpful
Epson R230 ink & Paper Lamp Blinking
Blinking alternately or not? If alternately, need to reset waste ink counter. SSC can fix it. But if not, it's general error. It's may be carrriage error.
58helpful
5answers
My printer epson r230 is not working. the two red light are blinking. is it my counter reset is end?
my printer epson r230 is not working. the two red light are blinking. is it my counter reset is end?
Epson Stylus Photo 2200
Hi there. I managed to find an excellent resource that should help you solve your problem. Try the suggestions given here http://www.fixyourownprinter.com/forums/inkjet/24337 i would start with "holding both paper and ink buttons then powering on untill the paper light flashes and then holding the ink button for 10 secs" Let me know if this helped. D.
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
