Access motor belt zanussi aquacycle 1000
How the motor and drum pulley can be safely accessed and belted in a zanussi aquacycle 1000 please.
    Master:
  • 485 Answers
There is usually a hatch at the back of the washing machine.
Posted on Mar 17, 2014
  • 139 Answers
SOURCE: bearing noise
Hi there im the wash docotor. With your zanussis once you have removed the back half of the pannel and the top pannel. you will have to then detach the motor wire plug. then the heater wires and also the there is a sensoer on the side of the drum that also has a wiring connection. Also detactch the earth wires Then here come the tricky part. if you look on the top of the drum you have a rubber pipe connected to it comming from the washer draw detach that its easy. Then you have to dicconect the door seal from the front of the machine by the door (do not dissconect from the seal from the drum as you dont have to . Then disconnect the the drain hose. once this is all done you have to disconnect the legs, from the drum side. these are easily done as the pegs come out easily if you push in the pips from one side you can either knock them out with a hammer but it is best to pull em out with either some long bent nose pliers or gripping em in such a way with a monkey ranch Best way og getting the drum out is once you have done all that is to turn the machine onto its back and lifting the casing off leaving the drum on the floor.
Posted on Oct 10, 2006
  • 641 Answers
SOURCE: how to fit drive belt to zanussi washing machine
Does it a new belt or the existing one ?
Posted on Sep 04, 2007
SOURCE: Zanussi IZ 12
I've just spent an hour taking mine to bits. On the back there are 2 x 9mm silver nuts at the bottom, below the star head screws you removed to get the top off. Then there are two more sneaky ones at the bottom of each side panel, just next to the gap about half way along on both sides., with a plastic cover hiding them from view. Make sure you release the mains cable holder from the top of the back by pressing the plastic clips down, then the whole shebang should slide off easily.
Regards. Paul C
Posted on Jun 28, 2008
SOURCE: Zanussi aquacycle 1200 smells.
1. Set the washing machine on the highest water level, temperature on hot and the wash cycle to normal.
2. Fill a gallon jug with hot tap water. Once the cycle begins, let it run for a minute or two, then stop the cycle, open the lid and slowly add the gallon of hot tap water. Don't overfill — you just want to raise the water level so that it is able to reach and clean the inside top rim.
3. Add 2 to 4 cups of household chlorine bleach and restart the cycle. In a couple of minutes, stop it again and just let it sit for at least 30 minutes. Afterward, let the cycle finish, and open the lid to air out the inside.
I got it from this link: http://answers.yahoo.com/question/index?qid=20060827101905AANuYg4
and here:
http://deseretnews.com/dn/view/0,1249,600124768,00.html
Posted on Aug 13, 2008
SOURCE: I HAVE A ZANUSSI XC AQUACYCLE 1000 FRONT DOOR
broken circuit in printed circuit board
Posted on Jan 12, 2010
Placing drum belt onto motor pulley
pulley on motor has grooves that must have the belt grooves in them. Make sure that the belt is not kinked but is smooth around drum. Spring tensioner with smooth pulley must take up the slack and keep the drum belt tight. sometimes back access panel is easier than reaching from in front.
Oct 22, 2013 | Dryers
I have a Zanussi Aquacycle 1000. It is taking in water and draining but the drum does not rotate both during wash cycle and spin cycle. Urgent help needed as we have people staying from England and NO wash...
Hi.
If the machine is filling up, then cycling and draining, the problem is usually the belt. The belt is reached disassembling the appliance . If the belt is OK the problem is usually the motor or the motor control unit, which is a sealed electronic module connected to motor and to control board and located inside the washer. If the motor has volts and does not turn, then the motor must be replaced. In some less common case the control module itself may be responsible. Motor assembly and belt are located at the back of the drum and get accessed disassembling top and back of the washing machine.
If the machine does not go through the cycle, but it starts draining from start, then the problem is overfill detected. In that case check the drain system, the drain hose, the inlet valve and the pressure switch.
Regards.
Ginko
Aug 29, 2011 | Zanussi FJS1225W Front Load Washer
I want to change a belt on a Zanussi Aquacycle Washing Machine. How do I access the rear of the machine
There is a panel at the rear of the machine that you can remove to access the belts and pulleys etc. Make sure that the machine is unplugged before removing the back panel, opening it will expose live terminals etc.
Mar 06, 2011 | Zanussi Washing Machines
Unsure how to access drier to put on new drive belt
Here is my own solution...
Disconnect from mains (of course) remove top (2 screws at back near top) Unplug electric connectors (on back panel, top RHS). Make sure note what goes where! Lie unit down on front remove screws (2) holding the drum spindle cover (centre of back) and remove cover pop off the circlip holding drum spindle, and washer unscrew back panel - hex headed screws round outside of back Remove screws at bottom of back panel which screw into the plastic vent housing (3 I think) Lift whole back off. (there's a plastic lip at bottom - need to pull away from this a bit) The drum spindle will be unsupported now, so don't move unit Full access now to drum and motor beneath Get and put on new belt reassemble.
Actually, having got into unit, found could not get belt from local spares shop (it had closed down), so bought new drier!
Dec 15, 2008 | Zanussi TD4212W Electric Dryer
Zanussi Aqualux washing machine
the belt is a tight fit so you need some strength
remove top. loop belt over the motor pulley and start belt onto drum pulley. turn drum pulley and belt will work its way on. there is just enough room to do this
Oct 08, 2008 | Zanussi F1045W Front Load Washer
Zanussi tumble dryer. no.TC7114W
loop the belt around the drum.
slide the belt down the drum directly over the motor pulley
loop the belt around the motor pulley
pull the tensioner pulley hard to the end of its travel against its spring
wrap the belt around the tensioner pulley
release the tensioner so the spring pulls it against the belt
rotate the drum by hand to ensure the belt is aligned and does not pull offf the pulleys
reassemble case
dry clothes
its easier than it looks seeing a broken belt in the bottom of the case.
Aug 07, 2008 | Zanussi TC7114W Electric Dryer
Zanussi aquacycle 1000 washing machine spin problem
this is possible due to a bearing collapse or bearing spider broken. this causes drum pulley to be out of line and the belt comes off
May 29, 2008 | Zanussi FJS1225W Front Load Washer
How to replace the belt on zanussi fla1101w
just struggle i'm afraid. put belt on motor pulley then start it on the drum pulley. turn the drum pulley and it will go on but very tight
May 22, 2008 | Zanussi FLA1001W Front Load Washer
Zanussi TC7114W condenser Drier
belts do not figure 8
they look something like this
f6516ed.jpg the front panel comes off, to access the drum without removing bearings etc, and the belt can be placed easily, around the drum and motor pulley.
then pull the tensioner hard against its spring, loop the belt around the tensioner and allow the spring to tension the belt.
Feb 14, 2008 | Zanussi TC7114W Electric Dryer
Washing Machines Logo
129 people viewed this question
Top Washing Machines Experts
