Question about Kenmore Dishwashers
Dropped a earring into bottom of dish washer
Don't know how to get to the pump
    Master:
  • 485 Answers
Check the filter. If it is in the pump, you will have to open it from the bottom.
Posted on Mar 17, 2014
Hobart dishwasher making loud grinding noise in wash cycle
suspect you have something in the wash pump.that has got through the filter or when you cleaned base filter it dropped down the hole,when you had the filter out,could be a small piece of glass or a chip of a cup, if you also think the same ,suggest search on u tube REMOVING OBJECT FROM A HOBART WASH PUMP or
removing objects from a dish washer pump, or pull mains plug out gain access to wash pump, screwdriver in back pump shaft ,turn and you will fill if there is something in pump, some times you can vac out through base filter using a wet vac.
Nov 23, 2016 | Hobart Dishwashers
Whirlpool wtw7300xw2 washer leaking from bottom
check for cracked pump hose/ loose hose, leaking pump, small tube up to water level control
if the water is grey or whitish then it could have water in the gear box from a failed shaft seal
Apr 03, 2016 | Whirlpool Washing Machines
Split black hose from bottom of dish washer does it just go to bottom of tray
Ypou'll have to examine the hose, because without a make and model, we don;t know which hose you're referring to. In fact, it is likely there may be more than one hose on dishwashers, anyway.
Mar 21, 2015 | Dishwashers
Dish washer not emptying
put your model # into a google search and choose a place that has parts and look up your drain pump. you probably have either a clogged drain hose, not likely, or a bad pump.
May 13, 2012 | Dishwashers
My dishwasher doesn't clean my dishes anymore and sometimes it doesnt dry them. it is a quiet partner 1 and it is about 2 years old.
It sounds like the water pump on the dish washer has gone out. A dish washer works (much like a clothes washer) by filling up the washer with a set amount of water, then through circulation, pumps the water up through the various spray nozzels. If the water pump is worn and not making enough pressure, the spray won't get the job done. Depending upon make/model, it may be cheaper to replace the water pump.
Run an empty dishwasher load with a bowl of white vinegar on the bottom shelf. As the dishwasher runs the cycle, the vinegar is slowly disbursed and cleans the dishwasher.
Mar 02, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
I dropped an earing in the vent opening of my dryer and can't reach it. How do I take the lower front panel off.
Did you try taking the exhaust pipe of the back of the dryer? The earring might find its way down to the bottom. Good luck!!
Jan 29, 2010 | Whirlpool GEQ9800L Electric Dryer
Du401 doesn't drain water
there is a little pump at the bottom of the machine,called the askoll pump".this is what pumps out water before and after a cycle.the pump needs replacing.
Nov 01, 2009 | Dishwashers
Errant earring
assuming this has long since been dealt with, but if its not in the rubber gasket at the front of the machine, take off the bottom panel at the front, there is a small pump there that drains the unit. It may be trapped in there. You can use pliers or vice grips to remove the couplers holding the hoses on and a screwdriver to remove it.
Jan 27, 2009 | Frigidaire FWTBB30DS Front Load Washer
Small earrings fell into holes on bottom
if they fell through those small holes doubt you'll find them something that small would probably be pumped out and down the drain ..if you haven't used washer since may be lucky enough to find them in pump but doubt it pump is pretty strong and can handle almost anything except socks and thongs
Sep 11, 2008 | Estate TAWX700JQ Top Load Washer
Dishwashers Logo
29 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
