Question about Sony Handycam DCR-HC28 Mini DV Digital Camcorder
CASSETTE DOESNOT EJECT
CASSETTEE TRAY DOES NOT RESPOND
WHY CAN I NOT EJECT DISC.
use a paper clip and there is a tiny hole on cassette tray ... just open clip and push it in till tray ejects. might have to fiddle a bit..lol
May 31, 2015 | Dell Computers & Internet
Canon IR1022if copier can't print in Legal size(8.5inx13in) using bypass or even paper cassettee
Did you trying hitting an Ok button, green button, etc to confirm legal size paper, maybe it wants you to confirm paper size. Also legal is 8.5x14, did you select legal or enter the size as a custom page?
May 22, 2014 | Canon IR1022IF 220-240 VOLT, 50/60HZ
Nakamichi DR 10 does not eject. I loaded a cassette, pressed 'Play' the cassette played 10 seconds and stopped. The display showed 'ERR'. I removed the cover, nothing immediately obvious. The cassette...
The DR1o might have a Sankyo transport and they have sense fingers that become tarnished. This needs to be serviced to make the deck work. It is possible that the deck is still in play mode which blocks the eject from taking place. Unplug the unit and open it up and rotate the worm gear with a finger and the door will eventually open up but do not force things as understand the size of motor in the unit that normally turns the worm gear.
Sep 19, 2013 | Nakamichi Audio Players & Recorders
Will not accept cassette - keeps responding "eject cassette"
Had the same problem and took the battery out of the camera to reset. Worked fine after that.
Mar 28, 2009 | Canon ZR300 Mini DV Digital Camcorder
CASSETTE STUCK IN VCR WONT EJECT I TURN VCR ON IT STAYS
When the tape has been removed the carriage deck will still be in the wrong position. The cassette tray has to be aligned so that the timing of the tape will detect that there is a tape in the machine. At the moment your VCR thinks there is a tape still in it because the cassette tray is not in the full eject position. This can be fixed by a service technician.
Mar 26, 2009 | Emerson EWV401 S-VHS VCR
Canon mv300i
I have glued a small plastic square over the "switch" on the cassette that presses down more on the sensor in the camera so it can sense that on the cassette and it should clear the tape cassette. Better still have a camera tech adjust the sensor in the camera. Good luck
Aug 25, 2008 | Sharp Viewcam VL-AH151U Camcorder
Cassette not being ejected
I have this same problem but the cassette tray will not go in. Error 1 "safe mode". I jiggled the mechanism beside the rubber "guide" ( in the middle above the drum) and it works now!! It must be some sort of sensor??
Mar 21, 2008 | JVC GR-DF550 Mini DV Digital Camcorder
Cassate tape will not eject from my Canon ZR85 Mini DV Digital Camcorder
I found a temporary solution for this problem. When the tray with the cassette tape comes out remove the battery so that the tray will not go inside again. Now on top of the tray it will be written as "PRESS" just adjucent to it you can see a spring connected to the tray just press the string down wards and the tray opens and you can replace the battery. Hope this can help.
Feb 01, 2008 | Canon ZR85 Mini DV Digital Camcorder
Sony Handycam DCR-HC28 Mini DV Digital Camcorder Logo
27 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Parshiv Luthra
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
