Question about Water Heaters
Water pressure problems with well - Water Heaters
    Master:
  • 485 Answers
You might need to change the well. The nut is kinda specialized size.
Posted on Mar 17, 2014
Pressure relief valve intermittent noise
check your water pressure and then make sure it is not to high or all the problems you have had were not the answer. it is a pressure /temperature valve not just . temp.
Apr 06, 2014 | RHEEM 40 GAL ELEC Water Heater 6YR SC...
I have a problem with low hot water pressure can you help would an elec shower help
1) If possible, it is Best to solve pressure problem before installing new shower.
http://waterheatertimer.org/Low-hot-water-pressure.html
2) If the cold water has good pressure, then Electric shower could fix problem ... but shower would have to be connected to the cold water line and not the hot.
3) Seems the expense of adding a electric shower would be greater than having plumber fix low hot water pressure.
Assuming you have access to plumbing pipes, and this is not apartment building.
Jan 05, 2013 | Water Heaters
PTG-74PVP-2; Where can I see/get/download a parts diagram? I continue to have O-ring failure on what appears to be the Water Flow Solenoid. The unit is installed at my vacation home, I shut down and...
Open following link for troubleshooting resources including Rheem contact information.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
High water pressure might be causing problem.
Use Brady BTG-100 pressure gauge to check pressure on nearby spigot.
Add a pressure reducing valve on incoming water line.
http://waterheatertimer.org/images/Check-water-pressure-250.jpg
Water heaters, tankless and tank-type are damaged by high water pressure 80 psi.
House plumbing fixtures also have shortened lifespan.
However if water pressure or water flow are too low, then burner will not activate.
Tankless are like bowling on a ship sometimes.
Repair most tankless water heater problems yourself, same day, any brand, for $320
http://waterheatertimer.org/How-to-install-gas-water-heater.html
May 02, 2011 | Rheem Paloma PTG-74PVN / RTG-74PVN...
I have a ge smartwater filter system #GXWHO4F. My problem is that since system was installed the water pressure and the water volume drops alot when more than one faucet is turned on.The filter system...
Filters always reduce pressure.
You can add a pressure tank between filter and tankless.
Tankless are sometimes like bowling on a ship.
Add a comment saying how you fixed problem.
Fix most tankless problems yourself, same day, all brands for $330.
Absolutely feel obligated to upvote the free help.
Or take advantage of fixya paid help.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 03, 2011 | General Electric GE SmartWater Household...
Turned off the hot water to fix a leaking tap. now the tap has no hot or cold water and the hot water tank valve is leaking?
It sounds like two problems.
Problem 1) Clog inside faucet or clog inside pipes at faucet
Remove supply tubes leading to faucet and see if problem is inside pipes or inside faucet.
My bet is clog inside faucet.
If you have galvanized pipe that meets copper pipe, this can be trouble spot.
Article on clogged water pipes at Inspectapedia:
http://www.inspectapedia.com/water/Water_Pipe_Clog_Repair_Guide.htm
Article on clogged pipes:
http://www.waterheaterrescue.com/pages/WHRpages/English/Troubleshooting/Tanklets/backflushing.html
Problem 2) Water heater leak ... you say tank valve is leaking? Is that cold-water shut-off valve? Or tank drain valve? Or TP valve?
If cold water shut-off is leaking, then replace shut off.
If tank drain valve is leaking, then check if plastic valve is cracked. If drain valve is cracked, then replace with a brass valve from Home Depot. If plastic valve breaks off, then use hammer and screwdriver to gently chip out the broken plastic valve. New valve threads need teflon tape to seal pipe. If valve is just dripping, then put garden-hose cap over end of valve and screw down tight.
If TP valve is leaking, then replace with same temperature and pressure rating.
New TP valve threads need teflon tape to seal pipe.
Problem 3) If pressure is low all over house:
Buy pressure gauge at hardware store that screws onto hose connection.
Test pressure on outdoor spigot.
Open faucet and check if pressure drops. This says if problem is inside pipes that enter house.
Test pressure on water heater drain valve.
This says if pressure problem is before -or- after water heater.
If problem is before the water heater, then shut-off valve located on cold water line is suspect.
If problem is after water heater, it could be in hot water outflow pipe on top of water heater, or a nearby elbow.
Remove hot water line leading from water heater and check pressure. This says if problem is where hot water leaves tank.
Read articles above about clogs inside water lines.
Nov 16, 2010 | Rheem Water Heater Pressure Relief Valve
I have a warrior glass hot water heater.model number 71-305.serial number r 0590822159.wattage 240 volts ac only. 30 gallon.the water pressure is low.drained tank to clean out.still having problems.any...
Buy a pressure gauge at hardware store that screws onto hose connection.
This will tell you if the pressure problem is before -or- after the water heater.
If problem is before the water heater, then the shut-off valve located on cold water line is suspect.
If problem is after water heater, it could be in the hot water outflow pipe on top of water heater, or a nearby elbow.
Nov 11, 2010 | Rheem Water Heaters
Upsstair shower doesn't supply continuous hot water, downstair works great. Water pressure problem?
It could be a water pressure problem but most water supply companies put out enough pressure for a 2 story house (or even 4 stories) easily. Can you clarify what you mean by continuous? Does the water get cold, on and off (i.e. no hot water) or does it vary in temperature mildly?
Mar 12, 2010 | Bosch 2700ES Natural Gas AquaStar ...
Leaking pressure relief valve
what is the water pressure on the cold side? You may need to install a pressure reducing valve at the water heater inlet to reduce inlet pressure and keep pop off valve from opening when not needed.
Feb 27, 2010 | Emerson Part UWL Chrome Ultrasystem water...
Low Water Pressure Gas System but High Pressure when Solar Water
if you have a gate valve on the unit from the hot water tank it could be as simple as the valve on the gas system being clogged going to that bathroom,, from how it is described it sounds like that would be the problem check to make sure all valve are not stuck in the on position ans change the valve if it is frozen in place
May 22, 2009 | Water Heaters
Boiler keeps losing pressure when the heatings off
Hi Leehardcast,
Yes the problems are related. The system is low on water. So now instead of water you have air in radiators which is easily compressed when it heats up. Then pressure loss when it cools down.
Add some water to your system until you have 15lb pressure and bleed out upstairs radiators at the same time.
Please rate this response and Good luck, Phil
Jan 13, 2009 | Watts 3/4 Pressure Relief Valve
Water Heaters Logo
15 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
