White smoke coming out of the oil fill cap is not good, it means there's water in there (white smoke = water, blue smoke = oil, black smoke = lots of junk in gas or ruined engine). I suspect bad head gasket or cracked block.
CAR NO START PROBLEMS:-----
It
can be the issue with weak battery or faulty battery or if battery is ok,then
its faulty starter causing the issue.
From
start to end troubleshooting these problem i suggest you to click the link
below and follow its procedure:-----
What to Do When Car Turns Over But
Won't Start?
http://technoanswers.blogspot.com/2012/11/what-to-do-when-car-turns-over-but-wont.html
http://technoanswers.blogspot.in/2012/02/car-starting-issues.html
http://whoisbyme.blogspot.in/2012/06/car-starting-problems.html
http://whatisbyme.blogspot.in/2012/05/1991-toyota-trecel-engine-starts-fine.html
http://howtobyme.blogspot.in/2012/05/1994-toyota-pickup-starts-fine-but-dies.html
http://whatisbyme.blogspot.in/2012/06/1999-chrysler-cirrus-8-ign-fuel-starter.html
http://whatisbyme.blogspot.in/2012/05/2001-toyota-camry-no-start-after.html
http://whatisbyme.blogspot.in/2012/05/1995-lexus-ls400-running-hot.html
http://www.howtorepairguide.com
These will help.
Thanks.
It
From
Won't Start?
These will help.
Thanks.
It
From
Won't Start?
Car starting issues?
Car Starting Problems
1991 Toyota Trecel: Engine Starts fine but
dies when gets Warm?
1994 Toyota Pickup: Starts fine but dies in
few seconds?
1999 Chrysler Cirrus: 8 IGN Fuel Starter Fuse
Blows?
2001 Toyota Camry: No start After replacing Battery?
1989 Toyota Pickup Truck: Turns over but not
start?
http://whatisbyme.blogspot.in/2012/05/1989-toyota-pickup-truck-turns-over-but.html
Car dead and will not Start?
http://whatisbyme.blogspot.in/2012/05/car-dead-and-will-not-start.html
1995 Lexus LS400: Running Hot?
2001 Toyota Prius will not start?
http://whatisbyme.blogspot.in/2012/05/2001-toyota-prius-will-not-start.html
1996 Jeep Grand Cherokee: Engine will not start?
http://repairhelpcenter.blogspot.in/2012/06/1996-jeep-grand-cherokee-engine-will.html
Mitsubishi will not start
These will help.
Thanks.
It
From
Won't Start?
few seconds?
Blows?
start?
These will help.
Thanks.
It
its faulty starter causing the issue.But if these basics are checked ok,then the problem is low fuel pressure or no spark:------
From
Won't Start?
few seconds?
Blows?
start?
These will help.
Thanks.
It
From
Won't Start?
few seconds?
Blows?
start?
These will help.
Thanks.
It
From
Won't Start?
few seconds?
Blows?
start?
These will help.
Thanks.
NO WATER ANYWHERE IT DONT BELONG, BUT IT DOES HAVE OIL IN THE INTAKE MANIFOLD, ANY SUGGESTIONS
When the gas engine starts is there any blue smoke coming from the tailpipe?
