Question about Sony Video Game Consoles & Games
Dish tv no signal
How to remove signal not found problem
    Master:
  • Sony Master
  • 665 Answers
Here you go, good luck. ^^
HOW TO RESET HDMI Video PS3
Posted on May 06, 2014
Inputs don't work
more likely faulty tuner. have to take it to a repair shop, ask for quote , if the set is old may be cheaper to buy a new one.
Jun 26, 2015 | Vizio SV421XVT 42 in. LCD TV
Hooking up a Coby tv 32" to dish network but it says no signal
"No signal" usually means you are on the wrong input. Look at the back of the TV to determine what plugs were used to hook up the Dish box, it will be labeled nearby (like Video 1, Component 1 or HDMI1). Now find the "Source" or "Input" button on the TV remote (it can also be found on the TV) and set it to the input the Dish box is plugged into.
If you are using the Coax cable (the kind that screws on), go into the menu of the TV and run a "Channel Search/Scan". This will find the channel the Dish box needs to be set to on the TV.
Let me know if this doesn't work.
Jan 14, 2013 | Televison & Video
My tv is not getting the signal from my direct dish.Just says no signal. I contacted direct and we tried several things via phone. They said the problem is with my tv not the dish or receiver. Nothing has...
Tries tv and the dish box unplug,replug it back an hour later for the tv to do a restting itself back to the factory setting and dish box to reboot and upgraded it software.This no signal problems should be fixed,not request another dish box for the replacement,because tv have no signal input bouncing around in the tv screen it is 90%-95% are broadcasting receiver boxes for tv incomming signal cable for tv signal problems.
Jun 27, 2011 | LG 37LC7D 37 in. LCD HDTV
My 622 DVR dual (DISH ) receiver has lost 3 local channels in a row ( SAT 61.5) . Connecticut 7385,7386,7387 - (ch 20,24,26.) Other tv's/ HD box and old 310 box converters work fine. I have unplugged,...
Hello, my name is Daniel Busa with Dish Network customer service. Whats probably causing the issue would be that either you're not getting high enough signal strength on the 61.5 satellite. Otherwise there could be an issue with the box if you swap it with another reciever in the home, and the issue follws it you'll need a new box.
Oct 19, 2010 | DISH Network ViP622 DVR DTV Receiver /...
How to fix lnb signal unlock
my name is Phillip Chang, member of DISH Networks Customer Service and happy to help. Before performing any of these steps, ensure that the weather is clear. Start by pressing the menu button, this can be found on the top left of the DISH Network remote control, then press the numbers 6-1-1, this should take us to the "Point Dish Screen", then select "Check Switch" on the right of the screen, then select "Test" on the following screen. This will acquire the signal. Just a warning, if you get an attention message "836" do NOT save the changes, give us a call at 1-800-333-DISH (3474 for additional trouble shooting.
Hope this helps!
Sep 12, 2010 | DISH Network 301 DTV Receiver
I have Dish sattelite and it won't work with memorex under cabinet. They said I need a cable box in between the dish receiver and the tv. Why is this?
You need a receiver for each TV you want to receive the reception on. Your dish receives the broadcast signal from the network and your receiver decodes and recodes the signal to view on your TV. The companies have created their own proprietary equipment to accomplish this to keep anyone and everyone from simply installing their own dish and receiving all of their broadcast channels for FREE. In the olden days when satellite and cable TV was new, that is exactly what people did. Remember those gigantic dishes some people installed in their yards? They would intercept the signals coming from the satellites and hook up directly to their TVs. The companies got smart and started to scramble the signals going up to the satellites to make these home owner dishes obsolete. Because the signals are scrambled, you now need a receiver to un-scramble the signal. I hope this helps and good luck. Please remember to vote d368a18.jpg if you found this helpful. Thanks.
Oct 31, 2009 | Memorex MVUC821 8 in. Under Cabinet TV
42PFL3603D/F7 PHILIPS HDTV
Your problem is a combination of calibration of your TV and signal strength of your Dish system. Proper color calibration will remove the motion blur and SD issues in the average home. If you continue to have poor quality on your dish system after calibration, then Dish needs to check your signal strengths again. (AND fix it.)
Nov 28, 2008 | Philips 42PFL3603D 42 in. LCD TV
SATELLITE DISH
Sure you can, if you have Dish Network go to the receiver and turn the TV and receiver on. Then press menu-6-1-1. This takes you to the point dish screen. You will come out with better results using a compass to find the azimuth the dish should be pointed toward and bore sighting the dish by pointing it in that direction. You then will need to move the dish in very minute increments pausing for 15 to 20 seconds after each move to ensure the satellite signal can be found. If you have ran a check switch prior to this and have lost all satellites you more than likely will not receive a signal until you run another check switch and have found the signal of at least one of the orbitals. If this proves to be to tedious and many times it will you can usually find an inexpensive signal pointing device at a store like Radio Shack. Hope this is some assistance to you. Let me know if I can be of additional assistance and thank you for using Fix Ya.
Oct 07, 2008 | Televison & Video
Sanyo DS27880 27" TV, Dish signal lost after tv turned off, doesn't return
checks should on your tv tuner it could be bad.IF circuit should also be check and the video section call in the tech to make checks on your tv.and to do repairs on your tv.
Jan 19, 2007 | Sanyo DS27820 27" TV
Video Game Consoles & Games Logo
12 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
