Question about Asrock P4I45GV R5 Motherboard
Not showing normal display to Dell LCD monitor
I have ASrock P4I45GV mother board with win XP SP-3 on it. I have Dell LCD 16' monitor. Mother board not shows correct display. eg. Circle not shows its correct roundness. I hae changed resolion, but not matched with any resolution. Whether there are any solution for this problem ? Pls. guide me. Amit
    Top Expert:
  • Asrock Master
  • 26,681 Answers
If you look at the resolution on the monitor and match it with the windows resolution or download a driver for your monitor from Dell
Posted on Mar 17, 2014
4 Suggested Answers
  • 24 Answers
SOURCE: cannot turn on motherboard
Either the power button itself is bad, or the mainboard is bad. You can test the power supply and mainboard by using a paperclip to short the green wire on the middle of the power connector that goes to the motherboard to the black wire next to it on the same connector. This will force the power supply on. If the mainboard still won't do anything, then it's dead, Jim.
Hope this helps!
Posted on Jan 31, 2008
  • 2246 Answers
SOURCE: didn't format complete i need
http://www.asrock.com/MB/download.asp?Model=P4i45GV%20R3.0
download at link above for R3.0
or
http://www.asrock.com/MB/download.asp?Model=P4i45GV%20R5.0
download at link above for R5.0
Posted on Mar 07, 2011
  • 2226 Answers
SOURCE: does the mother board Asrock 845GV (P4I45GV) support pci sata card
when installing it ask you for sata driver disk when startup is copying files you need to hit f6 key to get them loaded from a drive thats all you need to do.ok jim
Posted on Nov 22, 2011
Monitor is not through in p4i 45gv mother board
http://www.softwaredriverdownload.com/download_asrock_p4i45gv_driver.html
Feb 27, 2013 | Asrock 845GV (P4I45GV) Motherboard
Does the mother board Asrock 845GV (P4I45GV) support pci sata card
If you are trying to install Windows XP then -
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.The FIX.Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.http://www.fixya.com/support/r4335035-installing_windows_xp_sata_hard_drive
Nov 19, 2011 | Asrock 845GV (P4I45GV) Motherboard
I hav a asrock p4i45dv mother board , its cpu lights appear but nothing is displayed in monitor may i know the cause of this problem and soluton
This is either a bad monitor, a bad video card (if you're using a stand-alone card), or a bad motherboard. Test the monitor by connecting it to another computer. If the monitor works, then it's the video card or MOBO. Use a stand-alone (PCIx/AGP) video card that you are certain works. If this does not work, then the MOBO is not working. I hope this is helpful and best of luck!
Sep 21, 2011 | Asrock P4I45GV R5 Motherboard
I NEED MERCURY AS ROCK MOTHER BOARD DRIVERS
HI
your Asrock P4I45GV
Mother board drivers can be dowbloaded from following links
ASROCK P4i45GV VGA drivers
From
All drivers of *********** board is avail at the
Asrock's Website
Here is the link
and select the desired product(Eg:vga drivers,lan,inf )
and the desired OS
and select the download location
And download
1.
http://www.asrock.com/mb/download.asp?Model=P4i45GV%20R5.0&o=XP
and
alternative
2.
http://drivers.softpedia.com/get/GRAPHICS-BOARD/OTHERS/ASROCK-P4i45GV-R30-VGA-drivers-2kXP-131.shtml
Hope this will help you
Feb 28, 2010 | Asrock P4I45GV R5 Motherboard
My Asrok p4i45gv motherboard hang up
check mem, video card and cables in case something is loose change out video card jim
Feb 25, 2010 | Asrock P4I45GV R5 Motherboard
CPU, Prossor fan are runnig well. mother board LED are working. I Remove RAM Then on the sys. but NO BEEB sounds. I Clear CMOS Battry. THEN NO Display in monitor.
Please remove the memory card and clean the pins with a rubber eraser from any stains that causes no display in the monitor.
Jan 27, 2010 | Asrock P4I45GV R5 Motherboard
Mother all driver
Hi, my Board is Asrock P4i45GV
I have a Ati Radeon 9250 128Mb with the drives
On The : Computers Manegement--> Device maneger--> Other Devices
It show that VideoController need drives
I had put it to update Drive automatical but it doens get any drive
what can I do?
Sep 28, 2008 | Asrock P4I45GV R5 Motherboard
Monitor displays signal cable disconnected
Check if motherboards you connect the monitor into has a video signal frequency range that the monitor supports.
Feb 01, 2008 | Dell UltraScan P1110 21" CRT Monitor
Asrock P4I45GV R5 Motherboard Logo
51 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
pankaj rautela
pankaj rautela
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
