Question about Kenmore Dryers
Gas dryer my gas dryer has a glow light that comes on but the gas flame will not light
  • 999 Answers
Either the glow coil has weakened or the coil on the gas valve is malfunctioning, Eric
Posted on Jun 14, 2009
I have a roper gas dryer model rdg4440sq0, the igniter glows then the flame lights. Then the flame goes out and doesn't light up again. When it cools down and i restart the dryer the igniter glows and...
If when the flame goes out ...Check to see that the igniter glows...If it glows and the gas does not light then replace the valve coils...Very common problem.....The coils are to weak to hold the valve open..
Apr 20, 2010 | Dryers
Kenmore gas dryer 80series model 110.c72852101
if you hear the valve clicking but no gas the valve is bad.when the burner lights theres a probe that senses that it is lit and sends a microvoltage back to the controller to tell its lit.check to make sure all ground wires are grounded to a clean metal surface.
Oct 03, 2007 | Kenmore 74602 Gas Dryer
No heat coming from dryer
If electric then the thermostat or the heating element has failed.
If gas: First thing to check is the ignitor underneath the drum. (You have to open the panel to see it) It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off. If the ignitor does not glow then it or the thermostat is bad. If the ignitor is glowing but the gas does not light then the flame sensor may have to be replaced. If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
See also: http://home.howstuffworks.com/how-to-repair-a-dryer.htm
Dec 30, 2009 | Whirlpool Dryers
My dryer will spin but no heat comes from it.
Nov 18, 2009 | Food Mixers
My gas dryer is not heating up I checked to see if any flames is on when its running but its not coming on the timer is turning.what needs to change
All gas dryers have a gas module. The older models (very old) have a pilot light and the new ones have what is called a GLOW PLUG and it is made out of ceramic. If this glow plug is in any way broken, you will not have any heat. The GLOW PLUG is what comes on when you first turn the dryer on and it GLOWS until the gas module actually spits out a small amount of gas and an internal combustion occurs and the flames come on full power and this is what dries your clothes. If the GLOW PLUG is fine, then the gas module could be bad. ALSO, Always check for burnt wires and check any thermostats or fuses internally in the unit.
Nov 16, 2009 | Whirlpool Dryers
Kenmore Gas Dryer ignites then stops heating after ten minutes.
If the glow bar comes back on and the gas does not light,replace the gas valve coils. If the ignitor does not come back on,replace the flame sensor.
Sep 01, 2009 | Kenmore Dryers
FLAME ON SART UP NONE AFTER
Replace the gas valve coils if the ignitor glows but does not light. Replace the flame sensor if the ignitor does not glow.
Aug 29, 2009 | Kenmore 73952 Gas Dryer
The glow plug just lights up but no flame on my maytag mdg 5500aww
If the ignitor is glowing but the gas does not light check the flame sensor. If it is OK then the gas valve coils may have to be replaced.
Aug 12, 2009 | Dryers
The Dryer Turns On But The Heat Does Not Come On.
First thing to check is the ignitor underneath the drum. (You have to open the panel to see it) It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off. If the ignitor does not glow then it or the thermostat is bad. If the ignitor is glowing but the gas does not light then the gas valve coils may have to be replaced. If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
How do you light pilot light?
Dryer does not have pilot light.  There is an ignitor that glows when the dryer is started and lights the flame when the gas begins to flow.  With the front of the dryer off start it up and look for the glow. when it glows hot enough (or on a newer model it might be a spark) the gas should ignite.  When the flame sensor sees that the gas is ignited it shuts off the ignitor and keeps the gas valve open until the temperature sensor gets high and shuts it off.  When the temp sensor cools down the cycle repeats.
If no glow or spark-->bad ignitor If no gas flow-->bad flame sensor or bad gas valve coil If gas comes on and goes off quickly-->lint filter and/or vent pipe or outlet may be clogged or bad flame sensor.
May 29, 2009 | Whirlpool Dryers
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
