Question about Ovens
My Frigidaire Electrolux oven won't heat above 275?
    Master:
  • 485 Answers
Check the thermostatic valve. Prior to this, make sure that your orifice is ok and the fuel gas mixture is right. The way to check the fuel air gas mixture is to see that the flame are all blue and no orange or yellow color flame is visible. The flame should also not lift off the burner tending to lose unburnt gases to the inside.
Posted on Mar 17, 2014
ginko
  • 19396 Answers
SOURCE: how do I remove the oven door of Frigidaire Model
Hi.
You have to open the door all the way through.
Then remove the two locks from the hinges.Pull the tabs out, help yourself with a screwdriver.
Grab the door firmly on both sides, pull up the top of the door and slide it out.
Here all diagrams and parts for your appliance.
Regards.
Posted on Mar 04, 2010
heatman101
  • 43501 Answers
SOURCE: Electrolux wall oven not heating after self cleani...
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Posted on May 19, 2010
  • 195 Answers
SOURCE: Electrolux E@30GS65GSD bottom oven won't heat
most likely it is a bad element easy and cheep to replace check element for burn spots on it with a flash light don't touch unless you have the power turned off , get back to me if you need a part but i will need all info on this oven
Posted on Dec 06, 2011
emissionwiz
  • 78267 Answers
SOURCE: My oven won't reach the appropriate temperature
It is a problem with neither of the two it is the sensor reads the oven temp and shuts off the heating element when it is reached, it is called the thermal probe or thermostat.
Posted on Jan 19, 2012
dmftrucker
  • 1922 Answers
SOURCE: hotpoint oven won't heat above 250 degrees broiler works fine as well as the stove top
either its the oven sensor rod located at the top of the ovens cavity,or your bake element could be getting a hot spot which is when it gets a discolored spot in the element and can no longer pass sufficient current to heat the oven past 250 degrees
Posted on Jul 29, 2012
Frigidaire Gallery 30'' Freestanding Electric Range We recently bought a house with this stove in it. however the oven door outside window part is off.....how can we re-attach it.
Hey Alice, I appreciate your post!
I understand that you need help reattaching part of your Frigidaire range. I have located a parts schematic and attached it for you. If you need any additional assistance please feel free to reconnect. Good luck! -Matt
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Lassomption/5995639282.pdf
Dec 20, 2015 | Frigidaire Gallery 30 " Stainless Steel...
I have a Frigidaire Electrolux Model FEB30S5ABB. The oven will not heat up to the correct temperature and the bottom element is not turning on. We checked the element at it checks out ok. What could be...
Hello lizzyd62 - Sounds like the mechanical thermostat, oven sensor or EOC needs to be diagnosed for replacement. I would suggest contacting a professional to move forward accurately.
Nov 23, 2012 | Frigidaire 30 in. Electric Single...
I have an Electrolux Frigidaire Self Clearning Convection Oven. I was cooking yesterday when it went off and I cannot get any heat now. The oven still lights up when I turn it on. The fan still wor
Hello - Sounds like the element or the control board to the element is not communicating correctly. I would have a professional diagnose the element first. You may only need to replace it. Otherwise it could be the control board not allowing the element to heat up properly, a faulty mechanical thermostat or an oven sensor.
Oct 19, 2012 | Frigidaire GLEB27S7A Electric Single Oven
Frigidaire oven won't heat past 355
Contact a professional to have the unit diagnosed for repairs. Sounds like the heating elements are either faulty or the main control board won't allow the unit to heat up correctly.
Sep 05, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire electrolux oven gallry series front right element won't turn off
What is the model number? Reset the unit by unplugging or turning the circuit breaker off and then retrying.
Aug 09, 2012 | Frigidaire Ovens
Jan 19, 2012 | Whirlpool Ovens
Dec 06, 2011 | Electrolux Ovens
Oven won't heat above 100 degrees
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Apr 23, 2011 | Electrolux Ovens
I have recently moved into a new house and the oven settings on all three dials have been wore away and cant see which setting to use for cooking
The control on the right is for temperature,0 to 275 degrees centigrade.50 is about at 2 o, clock and 275 is about 9 o, clock.Middle dial is for the timer.The left hand one is your functions.at 2o,clock is the light.At 3o,clock is conventional oven top and bottom elements heat.5o,clock is the top element for browning.7o,clock is the bottom element for crisping.9o,clock is the infra red grill for small stuff one element.11o,clock is the full grill for all.12o,clock is off.If you need to order the knobs the part no. is 3303563831. cost € 21.36.
Hope this helped.
May 24, 2010 | Electrolux EOB2610 Electric Single Oven
I have a frigidaire oven model # PLEB30S8CCB won't get above 290
The coils should glow red when working. If the lower (bake) element does not glow it may be burnt out. Some ovens cycle the bake and broil elements during preheat and that mey be why you are getting some heat.
Aug 27, 2009 | Ovens
Ovens Logo
66 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
