Question about Pride Mobility Products New Pride Mobility Jet 3 Ultra Power Wheel Chair
Can you put larger tires on a Jet 3 Ultra? - Pride Mobility Products New Pride Mobility Jet 3 Ultra Power Wheel Chair
  • 175 Answers
You can probably go up to a 12" tire without it interfering with the shroud cover around the tire and without affecting the dynamics of the chair too much. It's gonna' cost you a lot, however, and the larger tires won't do much to increase the speed of the chair, if that's your purpose.
The Jet 3 has front anti-tips that are adjustable by removing the shroud and turning the nut on top of the anti-tip. When you put on taller drive tires, you will need to adjust the anti-tips down a bit to compensate for the adjusted angle with a higher tire profile.
Posted on Jul 07, 2009
Why won't my jet 3 ultra wheelchair run even after installing new batteries?
Batteries are not put in right. the charger is also bad. Strege Mobility
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
Mar 15, 2014 | Jet 3 Ultra Power Chair
HOW DO I REPLACE WHEELS ON MY JET 3?
first thig is to jack up front or have someone help u lift the chair on a, box that that will just fit between the tires and then put in gear and take nut and washer off then pull tire off if u bought new tires without the rims u need to take to a tire repair shop and have them put them on for u then replace
Sep 26, 2013 | Jet 3 Ultra Power Chair
Fuel line routing
Instructions
Fine tune your motorcycle before rejetting your carburetor. If it's still running too lean, you can replace the pilot jet as a first step
Remove the bowl at the base of the carburetor by unscrewing the screws holding it in place. Unscrew the pilot jet inside, but be careful not to strip it. The jet size will be on top.
5 Year/ unlimited mile warranty No up front core charge
www.Cylinder-Heads.com
Use a screwdriver to remove the main jet from the brass jet needle holder, which is also called the emulsion tube.
Put in a pilot jet that is one size larger. Replacing it with a jet two sizes larger will make your mixture too rich.
5
Tune the slow/idle settings before replacing the main jet. Replace the main jet with one size larger. The sizes are in increments of 5.
6
Put the bowl back on, and align the accelerator pump shaft and rubber boot.
7
Reinstall the carburetor on the motorcycle and retune it to finish the rejet procedure.
Jan 11, 2013 | 1998 Honda VT 600 C Shadow
Jet 3 Ultra Power Chair will not turn on.
the aftermarket group but call 1-800-800-8586 tech support first
Dec 04, 2012 | Jet 3 Ultra Power Chair
I need tires for a jet e ultra chair. Registry # PA 23397 is the only number I can find on the chair. the tires have 4 Pr Tube type/3.00-4 vaonni stamped on them can you help me..
You can contact your provider where you got the chair to have him order the tires for you or you can try calling Pride Mobility @ 1-800-800-8586 ask for Jazzy tech support and see if they will get you the right tires. Hope this helps
Apr 27, 2011 | Jet 3 Ultra Power Chair
Where can I get the manual for Jet 3 motorized power wheelchair
acampbel I went to pride website and could only find the manual for the Jet 3 ultra. I don't know if that manual can help you but goto pridemobility.com and select Jazzy chairs, scroll down until you see the picture for the Jet 3 Ultra click on the picture and you can download the manual from that page. Hope this helps you
Sep 15, 2010 | Pride Mobility Products New Pride Mobility...
Can you put larger tyres on a jet ultra 3 power chair if yes where can you get them
Hi. This is a question that has a lot of for and against points.
Bigger tyres will mean a slightly more comfortable ride, but it will cause other problems.
Putting on larger diameter tyres means that you are altering the gearing from the motor to tyres. You will have the potential to travel slightly faster, but the machine will struggle more on slopes and ramps. You will find there will be more places where the machine will get stuck because it doesn't have the power to climb out of certain hollows in the road or footpath.
Good luck. Neil.
Jun 03, 2010 | Pride Mobility Products New Pride Mobility...
The chair wont take a charge and ive bought 3 sets of batteries so it aint that
sound like the charger is not working. You can test the voltage output on the charger with a multimeter. Find the larger connection that comes out of the charger and put the probes on the two outside pins. There should be 25 to 30 volts coming through.
Nov 30, 2009 | Jet 3 Ultra Power Chair
What is the maximum size of wheel that i can put on a Golf 97 CL
In theory, you could go up to a 17" rim with an ultra-low profile tire. The stud configuration on the Golf, however, makes it hard to find the larger rims, and the ultra low profile tires are very expensive. Your best bet is to take it in to a tire shop to find out what can be ordered for the vehicle. If you wanted to order sets online, make sure you measure the distance between the studs and the depth of the wheel.
Jul 17, 2009 | Volkswagen Golf V Vw Scale Diecast Model
Pride Mobility Products New Pride Mobility Jet 3 Ultra Power Wheel Chair Logo
130 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Robin Hill
Robin Hill
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
