Question about Ott lite Natural Daylight Makeup Mirror
Need replacement Ott Lite for model CDO-010, makeup mirror
Need to replace bulbs. Tried online sources. No help. Say the bulb doesn't exist.
How do i change the bulbs in my jerdon makeup mirror?
After thorough research, Ithis product discontinued. I am so sorry to be bearer of bad news; however, perhaps you can go to Wish List on eBay in case seller has extras in stock before product met its fate. Jimmy
Apr 06, 2012 | Jerdon Deluxe Lighted Makeup Mirror JGL9W
Where to purchase bulbs for jerdon JGL9W
Here's the link- www.amazon.com I just researched your question and they do have these for sale currently. I hope this helps!Jimmy
Mar 24, 2012 | Jerdon Deluxe Lighted Makeup Mirror JGL9W
How to replace light bulbs in a Jerdon Tri-fold makeup mirror
In order to replace bulbs, look at the back of the mirror. There will be four white circle coverings hiding the screw heads, and these must be drilled open in order to access the screws that hold the two halves of the mirror together (these coverings will not have to be replaced). Once these screws are located and unscrewed, flip the mirror back over and remove the top half. Carefully, replace the bulbs.
Oct 25, 2011 | Cars & Trucks
I need to replace the three globes in the the miirror, I have shopped around cannot find any. HomMedics Mirror model M1702
You will need a Phillips screwdriver(star), flat screwdriver and a hammer. Unscrew the three screws off the side of the mirror with the Phillips. With the flat screwdriver and hammer GENTLY tap all around, until it comes apart. Replace the bulbs,(if you have nightlights you are not using, those bulbs works just fine.) Set the base back on, aligning the openings onto the grooves and secure with screws.
Sep 07, 2011 | Homedics M-7021 Spa Reflectives...
How do you get the mirror apart to change the light bulb?
Here are the instructions, basically you remove the screws on each side and then on side will lift off. I used a flat head screw driver to work around seem until it lifted off. Hope this helps.
http://www.conair.com/instruction_booklets/06PM8043%20BE18NX.pdf
Jun 16, 2011 | Conair Chrome Double Sided Lighted Makeup...
How do I open the housing of Conair Makeup mirror model BE 103 - I removed the screws but cannot separate the mirror to replace bulb
The two sides do come apart but tend to stick. Pull the magnifying mirror apart from the mirror that is attached to the stand. You may need to budge it a little on one side and then the other to get it to come free, but it will.
Jun 08, 2011 | Conair Chrome Double Sided Lighted Makeup...
Removal of burnt out bulb in ott lite
Depending on lamp the bulb is approximately a 1/8 turn with a slight push toward the base to release the bulb, If you have not purchased the replacement bulb take the old one with you, some "high end" lamp stores will have replacements, if not the website will help. Good Luck!
Douglas
Sep 12, 2010 | Ott Light OttLite Truecolor Table Lamp
Ott lite Natural Daylight Makeup Mirror Logo
718 people viewed this question
Top Ott Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you an Ott Furniture Expert? Answer questions, earn points and help others
