Question about Garden
Tractor will not start
Unit has power, lights , etc work but will not crank over. Tried jumping but will not crank.
    Genius:
  • 1,114 Answers
It sounds like one of the safety switches is not working or the wiring to the switches is connected. There should be at least two switches; one under the seat and one for the mower deck. These switches will prevent the mower from starting if there is no pressure on the seat or if the mower deck is engaged while trying to start the mower.
Posted on Apr 23, 2014
4 Suggested Answers
  • 36 Answers
SOURCE: I HAVE A POULAN MOWER TRACTOR MODEL HD12538B THAT
Try replacing your spark plugs. Make sure its getting gas. Make sure your air filter is nice and clean. Check your fuel filter. and if all those fail try replacing your coil.
Posted on Feb 08, 2011
eugbug
  • 479 Answers
SOURCE: Where should I start in
If the starter motor is actually turning the engine then the first thing to do is check the spark plug to see if you are actually getting a spark. If there is a spark, then move on to the fuel system to eliminate restrictions in the flow. The problem could be due to a dirty fuel filter, faulty fuel pump or solenoid fuel valve, no voltage on valve or dirt in the float bowl or a blocked float valve.
Have a look at these tips for troubleshooting lawnmower starting problems. They apply to tractors also:
http://www.fixya.com/support/r9118692-lawnmower_not_starting
Posted on Aug 16, 2011
  • 6468 Answers
SOURCE: power to all indicator lights but will not crank
that tells me that you have a bad safety switch check the one on the clutch/brake pedal
Posted on Jul 02, 2012
I have an old Cub Cadet model 128. I started the unit and cut grass for about 15 mins.when it missed badly. About 2 min later it just died.
Check the wiring for a dead short. Make sure key is off and removed and try to turn engine over by hand.
May 26, 2017 | Cars & Trucks
Tractor will not crank over.Why?
Sounds like your battery cables on the starter is not working and needs replacing. i had a loose cable and would not work.Your solenoid may be bad as well.
Nov 07, 2015 | Garden
2011 CADILLAC SRX WILL NOT START. LIGHTS AND REAR HATCH WILL OPEN SO DOESN'T SEEM TO BE THE BATTERY???
Try jump starting it from another car. or that thing should have a volt gauge while trying to crank it if it drops lower then 11volts it wont start. or if you can hook up a volt gauge to the battery if not just try jump starting it.
Dec 12, 2014 | 2011 Cadillac SRX
Why won't my 2012 Suzuki Grand Vitara start?
ill answer for NO ELECTRICAL POWER :
sure and is easy with any DMM meter, got one? any $20 DMM.
my guess;1
engine will not crank
dash lamps out.
head lights out. dead.
post systems of electrical system , all parts that work and those that dont work, and problem is easy.
cleaned battery terminals.
tried borrowed battery that reads, 12.6vdc ? (charged is 12.6)
2012 that is in warranty car.... ?
my guess on 2012
jumping a car, that is battery jump starting.
a battery can short, and no jump start on earth will start shorted battery in car. but does lay down some big sparks, or burns up cheap walmart cables.
if the car will not crank, say just that, my starter motor will not crank
jump started from live running other car.
if true then make sure headlights work , if they dont work fix that first.
HL must always work, even keys in pocket.
best is to put a fully charged battery in the car, jump starting can cause
surges that can damage sensitive electronic$$$, do jumps as a desperate measure,
with a charged battery,
1: Head lights work, no fix that , use voltmeter
2: cranks robustly.
no , wiggle shifter lever, (on A/T cars the park switch blocks cranking) On M/T the clutch blocks cranking.
with any dMM
measure battery voltage before crank and during.
12.6v good. reseted.
cranking.
0 to 10v bad (weak battery or shorted starter motor)
11 and above good. and must crank, if not , starter is bad.
to prove starter is bad, check voltage at starter solenoid coil wire lug.
it must be at 11v cranking , below 8v it chatters, and fails.
if at 0v cranking this lug that means the Key start line is failing.
A/T switch not closes, or bad ignition switch.
May 25, 2013 | Suzuki Grand Vitara Cars & Trucks
1999 simplicity landlord tractor doesn't start
Does it crank? There are a myriad of issues to check
Dead battery
Bad battery connections
Safety switches not all in right setting (like a PTO/mower deck turned on that needs to be off for starting, or a brake pedal not pressed, or a seat not sat on)
Bad solenoid
Bad fuse
Bad relay
Bad starter switch
More details can narrow it greatly. Have you tried jumping it? Do you get noise when you turn the key? Was it an all of a sudden problem, a growing intermittent one, have you tested the voltage of the battery or tried charging it? Etc.
Mar 30, 2013 | Garden
2003 lexus es300 won't start... radio lights and windows work. Tried a jump start, still doesnt work...
Are you saying the engine cranks but won't start, or the engine won't crank ?
If the engine does not crank, you would check for voltage at the starter, the neutral safety switch, and the key switch as well as the ground connections.
Sep 18, 2012 | 2003 Lexus ES 300
Ford 4000 TraCTOR WILL NOT START AFTER QUITING DURING BRUSH HOGIN
Try jumping across the 2 large posts on the solenoid, if it cranks doing this, replace the solenoid
Aug 31, 2009 | Ford 8n,9n,2n, Tractor Starter With Drive
My car wont start and my battery has power
your battery has voltage but no amps left replace the battery!
May 31, 2009 | 2007 Pontiac G6 GT Convertible
Car won't start
I'd probably start with cleaning my connections at battery, & making sure my battery has a full charge. If not cured, maybe a new battery is required. If it will start with a jump, try running it for a couple of minutes with boosters on, and if all appears o.k. , change your battery.
Aug 21, 2008 | 2002 Dodge Neon
Garden Logo
35 people viewed this question
Top Garden Experts
Jay Finke
Jay Finke
Dennis Key
Dennis Key
john h
