Question about HP Compaq Presario SR1620NX (SR1620NXEG733AA) PC Desktop
Compaq presario cq5320y wont turn on - HP Compaq Presario SR1620NX (SR1620NXEG733AA) PC Desktop
  • HP Master
  • 27,725 Answers
Test your PSU power supply unit or replace it if your power supply units fan is not working your PSU is faulty
http://pcsupport.about.com/od/toolsofthetrade/f/powersupplytest.htm
Testing & replacing the PC's power supply
http://www.youtube.com/watch?v=hbNxhvm0czs
One bad lead can cause a computer to continue on a cycle of restarting or to shutdown or fail to detect/ boot up a computer hard drive
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer.
While in the computer it is highly recommend that you be aware of ESD and its potential hazards
Remove the memory modules from their slots.
Take the opportunity to clean the slots on the motherboards and the memory module connectors.
Use compressed air to blow dust away and clean contacts with a soft cloth.
Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components.
Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol (Methylated Spirits) on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r
Allow the pins to dry.
They will air dry in a matter of minutes.
If reseating the memory did not resolve the issue try swapping the location of the memory.
If you have only one stick of memory in the computer try moving it to another slot and then boot the computer.
Check the memory module and memory slot contacts.
They are either copper tin or gold.
The colour will tell you which they are.
Mixing tin and gold can result in corrosion that prevents proper contact.
Look for any sign of physical damage to the memory module, memory slots or the motherboard.
Reseat the memory modules.
You should hear an audible click when they are in place.
Do not use too much force to reseat the memory module in to the slot this can cause damage to the module, slot or motherboard.
The hardware that you are trying to access is damaged or failing.
The device drivers for the hardware are faulty or incompatible.
Could be a problem with the Hard Drive or the Hard drives PCB
http://www.onepcbsolution.com/
http://www.youtube.com/watch?v=du0Qd_3wFWM
There is a connection problem such as a bad cable
for internal hard drives
Test all power and data leads that attach to your hard drive SATA
the leads from yourMOTHERBOARD TO THE HARD DRIVEmake sure they have a
secure dust free connections and are not faulty although very rare for sata lead to fail
Make sure all leads that are attached to your drives dvd\cd and floppy (If Applicable) have secure connections and are not faulty.
or just replace them they could be faulty a computer needs power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
Posted on Mar 17, 2014
Run a s.m.a.r.t. test ERROR: (on the drive )said ERROR CODE: BIOSHD-8 (WD-WCAWF2969755)wdcwd50000aaks-65voao. I have a Compaq Presario Model# CQ5320Y Installed win. 10 now itwon't reboot
Use a partition eraser on the drive. Note that unless you use a disk like Hirens boot cd and make it an iso and put it on a bootable drive as an image, you are going to have issues with having to remove the drive and connect it to another computer to remove the partition.
Mar 02, 2017 | Compaq Computers & Internet
Winxpsp2 user verify solutoin
Go to the link below and download Ophcrack and burn the iso to a cd. Boot from the CD and let it do it's magic. You'll have your password shortly:
http://ophcrack.sourceforge.net/download.php
Aug 17, 2012 | Compaq Presario CQ5320Y Desktop PC, AMD...
Manual for cq5320y compaq computer
manual to do what.? name something?
most HP products can have over 30 books,guides etc.
did you even look at HP firsts.
cq5320y
the real name is:
its a DESKTOP
this is all there is, on old compaq circa 2009?
still support it is,
https://support.hp.com/us-en/product/compaq-presario-cq5300-desktop-pc-series/4079828/model/4107710/manuals
Dec 24, 2011 | Compaq Computers & Internet
After power outage compaq presario SR1123WM desktop wont turn on
cHECK THE ps IF GOOD CHECK THE mobo COMMN BECOME DEAD AFTER POWER SURGE.
Nov 06, 2011 | Computers & Internet
Compaq presario f577cl wont turn on
Turn it on, then hold the power button for 4 seconds until it forces off. Turn on again.
Otherwise, turn on, remove battery, insert battery, turn on.
Please rate.
Aug 21, 2009 | Compaq 20GB NOTEBOOK HARD DRIVE KIT FOR...
Compaq presario m2000 sound card
logon to compaq website search for your model and download sound drivers
Jul 15, 2008 | Compaq Presario M2000 Notebook
Wont post
after turning on wait for a moment.. about 5 mins. then press fn+f4
Jan 04, 2008 | Compaq Presario 700 470024-192 Notebook
HP Compaq Presario SR1620NX (SR1620NXEG733AA) PC Desktop Logo
77 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
