Question about HP Photosmart C5180 All-In-One InkJet Printer
Printing 3"x5" note cards
My c5180 prints on 3"x5" notecards perfectly. The problem is getting the cards in and out of the load tray. I am running OS X.5 and MSWord for Mac. In MSWord the paper set up is for t"3x5" notecards I load them from the PAPER TRAY with the 5" side along the right side, and the 3" side against the back stop. But, I have to use a knife to push the backstop border holder (I don't know what they are called) all the way into the machine so that the note cards are flush against the back stop. Getting them out of there (if I loaded too many) is a nightmare and takes 10 minutes or so of inserting different tools through the back of the printer to push the note cards up into the front of the paper tray to where I can use the long knife to pull them out one by one. Should I be using the photo tray? Since that slider DOES push all the way down, and the note cards ARE printed wonderfully, I am thinking that there must be some way to take out the output tray or the paper load or photo tray to be able to access that slider on the 3" side from the front.
SOURCE: tray output
You should configure TRAY 1 as Legal only.
and Tray 2 as plain letter.
Specially when you specify from what tray/paper type to print.
This can be easily configured from the Printer Properties within the Printers and Faxes section of the Control Panel.
Posted on Jan 26, 2008
SOURCE: Mac Leopard OS: Can't print from photo tray
Here's the trick. It took me an hour to figure this puzzle out myself. DO NOT select the Print icon at the bottom of iPhoto. Do NOT select Print from the File menu. DO select EXPORT from the File menu. Select the HP Photosmart Mac tab Select HP Photosmart Print.app from the app selector. Click the Export button. HP Photosmart Print.app will load with a new print dialog box. Make all necessary selections. This is where you can select the Photo Tray as the tray for the printer to take paper from. This solved MY problem! Let us know if this helps you!
Randy
Posted on May 23, 2008
  • 6 Answers
SOURCE: Photo Tray Problem Error Messege Prevents Printing
kknjhinklo
Posted on May 28, 2009
SOURCE: Unable to print to photo tray
FIXED BY ADJUSTING PAPER SIZE
Posted on Sep 21, 2009
SOURCE: I want to print a photo using the photo paper
I had to adjust the advanced print settings on my computer.
Posted on Oct 03, 2009
HP OfficeJet Pro 8600 tray can't be inserted all the way. Stops with 3 inches of tray sticking out.
  1. Grasp the handle on the front of the input tray, and then pull the tray towards you to open it.
    Figure 1: Pull out the input tray
  2. Slide the paper width guides out as far as possible.
  3. Remove all paper from the paper tray.
  4. Inspect and remove any foam or tape packaging materials in the paper tray.
  5. Insert a stack of unused, plain white paper (with the print-side down) in the center of the tray.
    Figure 2: Load paper into the tray
    CAUTION: Do not load any paper above the solid red lines on the sides of the tray. Do not use torn, wrinkled, perforated, wet, or folded paper. Make sure to remove all paper clips and staples before loading the paper. Figure 3: Stack label height
  6. Slide the paper guides in so that they rest against the edges of the paper, and then insert the tray into the product and push it forward until it clicks into place.
    Figure 4: Slide the paper guides in and reinsert the tray into the product
  7. Pull out the tray extender on the output tray.
    Figure 5: Pull out the tray extender on the output tray
Step two: Load paper in optional Tray 2
Tray 2 is an optional accessory. Follow these steps to load paper in Tray 2.
NOTE: Tray 2 supports only plain letter or A4 paper.
  1. Grasp the underside of the tray, and then pull out the tray from the bottom of the printer.
    Figure 6: Pull out the tray from the bottom of the printer
  3. Load a stack of unused, plain white paper (print-side down) in the center of the tray. Make sure that the stack of paper aligns with the engraved lines in the tray.
    NOTE: Load Tray 2 with only U.S. Letter or A4 plain white paper.
  4. Slide the paper guides in so that they rest against the edges of the paper.
  5. Carefully reinsert the tray into the printer, and then push the tray forward to close it.
    Figure 7: Reinsert the tray into the printer
  6. Pull out the tray extender on the output tray.
    Figure 8: Pull out the tray extender
Load specialty paper Follow these steps to load specialty paper such as card stock, envelopes, photo paper, or labels.
Before you proceed, verify that your printer supports the specialty paper on which you are attempting to print by viewing the product specifications . If the size, type, or weight of the paper is not available, the printer does not support printing it. Also note the tray loading capacity for the type of paper on which you are attempting to print.
Sep 27, 2013 | HP Officejet Pro 8600
When asked to print my c5180 all in one ejects blank sheet of paper making no attempt to print
Just click below for more information;
s.gif » Macintosh: All-in-One Ejects Blank Page or Pages in Mac OS X V10.4
Mac OS X V10.4: A blank page or pages emerge from the product when it is turned on. s.gif » A Blank Page Prints at the Beginning of Every Print Job ...
A blank sheet of paper prints at the start of every print job. s.gif » Load Paper
Instructions on loading paper and envelopes. s.gif » When I Try Printing in Windows Vista, My Printer Is Not Available in the List of Printers ...
Windows Vista: The product does not appear in the printers folder when attempting to print on a network. s.gif » HP Photosmart C5180 All-in-One Printer: Manuals
... HP Customer Care | HP Photosmart C5180 All-in-One Printer | Product information HP Photosmart ... One Printer | Product information HP Photosmart C5180 All-in-One Printer: Manuals About these files: These
Hope this may help;
Regards,
VOTIT
Aug 23, 2008 | HP Office Equipment & Supplies
How do I print 3 x 5 cards with my HP C5180?
HP does not recommend printing 3 x 5 cards on this printer. It has a tray for printing 4 x 6 photos but, that is the smallest size available. However, you can set up Microsoft Word to print 3 x 5 cards on regular letter paper and then glue them to the cards. Or you can print them on card stock and cut them out.
Hope this helps. Robert
May 06, 2011 | Computers & Internet
Paper in tray won't load
Make sure you inserting the paper not deep inside just insert and stop it when you feel any resistance .and try to print something. If it is print then well otherwise you have to show it service center.
Have a nice day and do not forget to rate please...!
Feb 15, 2010 | HP Photosmart C5180 All-In-One InkJet...
My C5180 won't print. It sounds like it is printing but spits out a blank page
>try the steps on this link
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01449854&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=1153481&lang=en
.also check if there is still ink on it try printing a self test page
Method one: Print the page from the control panel
  1. Load letter, A4, or legal, unused plain white paper into the main tray.
  2. Press the OK and Help buttons at the same time and then release them. The self-test diagnostic page prints.
Method two: Print the page from the computer
  2. Open HP Solution Center.
    • Windows Vista: Click the Windows icon (c01364735.gif ), click All Programs , point to HP , and then click HP Solution Center .
    • Windows XP: Click Start , click All Programs , point to HP , and then click HP Solution Center .
    • Windows 2000: Click Start , click Programs , point to HP , and then click HP Solution Center .
  3. Click the Settings menu, point to Print Settings , and then click Printer Toolbox .
  4. Click the Services tab, and then click Print test page . The self-test diagnostic page prints.
Oct 02, 2009 | HP Photosmart C5180 All-In-One InkJet...
Can't Print Notecards
I ran into this problem several times. The way I solved it was I drew an arrow on the side of the paper that faced in and up. When you look at the wrong placement, it will tell you which way to place the paper.
Jul 23, 2009 | The Learning Company PrintMaster Gold 15...
How do I realign my hp photosmart c4480 printer?
To align the print cartridges from the HP Photosmart Software
1. Load letter or A4 unused plain white paper into the input tray.
NOTE: If you have colored paper loaded in the input tray when you align the print
cartridges, the alignment will fail. Load unused plain white paper into the input
tray, and then try the alignment again.
2. In the HP Solution Center, click Settings.
3. In the Print Settings area, click Printer Toolbox.
NOTE: You can also open the Printer Toolbox from the Print Properties dialog
box. In the Print Properties dialog box, click the Features tab, and then click
Printer Services.
box. In the Print Properties dialog box, click the Features tab, and then click the
Printer Services button.
The Printer Toolbox appears.
4. Click the Device Services tab.
5. Click Align the Print Cartridges.
When prompted, ensure plain white letter or A4 paper is loaded in the input tray, then
press the button next to OK.
The product prints a print cartridge alignment sheet.
7. Load the page print side down on the right front corner of the glass, and then press
the button next to OK to scan the page.
When the On button stops flashing, the alignment is complete and the page can be
removed. Recycle or discard the page.
Jul 18, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
Paper does not feed from Tray 1.
Check your printer settings.
Sometimes if your printer or the program you are printing from has the paper source set to "Letter" it waits for you to press the continue key on the printer which allows you to insert headed note paper before printing.
If it is set to letter, change it to A4 and this should solve your problem
You may need to change this in both the printer settings and/or each program from which you are printing
Jan 12, 2009 | Lexmark C532dn Laser Printer
Printing on 3x5 notecards.
Some printers have a slot in the exit tray to use for envelopes and cards, if yours does not it may not support printing of cards. Please provide the model number and/or check the HP website for information.
Dec 08, 2008 | Office Equipment & Supplies
Hpphotosmartc4380 the printing is badly out of line .How do yoy align the cartridges?
You may want to run the alignment program again. Below are the steps as found on page 84 of the manual found here.
1.
In the HP Solution Center, click Settings, point to Print Settings, and then click
Printer Toolbox.
box. In the Print Properties dialog box, click the Services tab, and then click
Service this device.
2. Click the Device Services tab.
3. Click Align the Print Cartridges.
The HP All-in-One prints a print cartridge alignment sheet.
4. When prompted, ensure plain white letter or A4 paper is loaded in the input tray, then
The HP All-in-One prints a test page, aligns the print head, and calibrates the printer.
5. Load the page print side down on the right front corner of the glass, and then press
Oct 07, 2008 | HP Office Equipment & Supplies
HP Photosmart C5180 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
