Question about Sewing Machines
I have a Elna 2800-Thread on the needle do not pick up the thread of bobbin-did threading and change the needle
  • Sewing Machines Master
  • 1,388 Answers
Service Timing is NOT a home fix
Posted on Apr 22, 2014
Elna 2004 does not pick up bobbin thread Help please Any easy fix
Install a brand new needle. If that doesn't help, the machine is most likely out of time--the needle is arriving at the bobbin at the wrong time to intercept the bobbin thread. Search for sewing machine timing or take it for service.
Mar 20, 2017 | Elna Sewing Machines
My elna 2800 is jamming the bobbin the thread keeps wrapping around the bobbin case. What can I do
try changing the needle, make sure the machine is threaded correctly,using every thread guide. make sure the top thread hasn't come off the thread take up lever, try a different bobbin, could also be a timing problem
Dec 03, 2014 | Elna Sewing Machines
NEEDLE THREAD WILL NOT PICK UP BOBBIN THREAS
you should try these needle called the organ needle they have 10 pcs. HAx1 130/705H 15x1 size 100/16 these needles are longer and strong . Maybe the one you have is too short
Oct 19, 2014 | Elna Quilter's Dream 6003Q
The needle won't pick up bobbin thread on mu Elna Air Electronic SU
Has this just started after a jam up? As it's usually a symptom of timing being out.
However first check needle is in right way, flat shank to the back and threading is correct including the take up lever.
If no joy then mechanic service time
Apr 18, 2014 | Elna Sewing Machines
Thread from the bobbin is not getting looped
If the bobbin case rotates freely it is probable that the pinion gear is broken. Replace the gear, retime machine and voila it works again. Trouble is tough to find the gear anymore good luck it is a good machine and worth the effort
Jan 09, 2014 | Elna Sewing Machines
The thread on the needle of my Elna sewing machine wont pick up the thread on the bobbin and bring it up?
if changing the needle doesn't help then it's possible that the machine
is out of time & needs to be checked at a repair shop
Aug 22, 2012 | Elna Sewing Machines
The thread from the needle that goes down to pick up bobbin doesn
make sure your needle's flat bit shows to the back and it is in deep anough. else your timing is out.
Jan 22, 2010 | Elna 2007 Mechanical Sewing Machine
I need to thread an elna air electronic su sewing machine
that's a nice machine, one of the last mechanical Elnas with the discs for extra stitches. Firstly, you need to wind a bobbin, always use Elna swiss metal bobbins, with holes on one side only, slightly dished. Put on top of the bobbin spindle and take the thread from your spool on the spool holders at the back of the machine across to the tension disc on top left, its white bump, thread through the tension then back to the bobbin and pull the tail through a hole in the top of the bobbin. Flick bobbin across to the right against the stop, disengage the clutch by holding the outer flywheel and turning the inner towards you. Now press the foot pedal to start winding a bobbin, holding the thread tail so it starts off. Wind one full coverage of the bobbin so that the starting point is covered, then stop and cut the tail off with scissors. Now continue winding at 3/4 speed until bobbin is full, watch as it winds and give the thread a nudge with your finger so it fills top and bottom as well as in the middle of the bobbin. When it is full, the bobbin spindle will stop winding. Move it to the left, cut the thread and reennage the clutch by holding flywheel and turning the inner the other way. Now install the bobbin and click the thread into the tension device, see image.
Now thread up the top thread by taking the top thread from the spool, through the tension discs, across to the eyelet on top, down to the check spring, back up to the take up lever, then down to the needle catching the thread into the two thread guides enroute.
See this image.
Now thread through the needle front to back, hold the top thread, close the bobbin cover leaving the tail sticking out the top, lower the needle down by turning the flywheel towards you through one cycle and pull the top thread, drawing the bobbin thread up to the top of the needle plate with it. Pull both threads under the pressure foot to the back and your ready to go. Remember, top tension should be on 5 and bottom tension should be on the red 1, don't change it. Brush out the bobbin holder assembly each time you use this machine and add one drop of oil into the middle of the bobbin holder, there may be a red dot or just the indenation. Run the machine for 30 seconds after oiling without thread, slowly to spread the oil through the bobbin mechanism. Standard 130/704H needles, change regularly (6 hours of sewing) and pick right sized needle and type point for the work you are sewing. Good luck with your SU. If you wanted to join, there is a Yahoo group called "Elna Heirlooms" for fellow Swiss Elna owners.
Aug 24, 2008 | Singer 7462 Mechanical Sewing Machine
Needle will not pick up thread from bobbin
Without looking at the machine it is very difficult to diagnose the problem on here. Double check the machine is threaded properly and that the thread from the bobbin is through the bobbin tension. If all is as it should be and it will still not pick up, the machine needs looking at by a technician as the timing may need adjusting.
Mar 21, 2008 | Elna Heirloom Edition 6005
Sewing Machines Logo
19 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
