Question about Fisher and Paykel Washing Machines
I have a 2004 Fisher&Psykel Intuitive IWL12 washer, In Dec. It wouldn't drain, it had a clog of a small rag that I had to remove. Now on some random white clothes I'm finding gray streaks They do wash off with dish soap. I have not ran a Tub Clean cycle, in the manual it says to wash with powdered detergent with phosphate where do I buy this? I do not use softener, but do use liquid detergent. I have also seen suggestions to use Bleach or Vinegar, Please Advise!
    Top Expert:
  • Fisher and P... Master
  • 23,109 Answers
A rinse with a lemon cut in half works wonders! Check the rubber boot has not got a blocked drain. (Base of boot at the front in the folds is a small drain hole).
Posted on Mar 17, 2014
  • 8 Answers
SOURCE: stinky laundry
Hi! I have Kenmore Elite 4t and had this same problem: Musty, Moldy smell in washer and on clothes. The Sears Technician suggested that I use a half a cup of Clorox Liquid Bleach and put it in the tub (not the dispenser). NO CLOTHES! Use the longest hottest setting and when it's done clean the inside (underneath rubber tire thingie) and the undernath part of the door with a papertowel. And to always leave the door open. I did what he said with the bleach and it worked. I didn't want to leave the door open because I have 2 cats & was afraid that they would want to go in it, but ended up repeating the bleach thing again because a few days later the horrible smell was back. I leave the door open all the time now and the cats never go in it. They've watched laundry spin around, so I guess they're smart enough to not want to go in it. I have not had this problem again since I always leave the door open and I did this over a month ago. I hope this helps!
Posted on Jan 18, 2008
SOURCE: Water Softner Dispense wont empty - Kenmore Elite Quiet Pak 4 HE3t
I'm sure you heard a small motor running from time to time during a cycle. That moves an "arm" which sends water to the different chambers during a cycle. Fabric softener is dispensed when water goes to that chamber and dilutes the fabric softener. That chamber then empties by a siphoning action.
If you want to narrow down the problem a little to help trouble shoot -- put some wet rags in and run the Rinse and Spin cycle with some fabric softener. If the softener is not dispensed, then you know that the water isn't being sent to that chamber properly.
If you are intrepid enough to take the top off your washer, do that and see if the arm appears to be moving during a normal cycle. Maybe the arm got dislodged or broken during the move.
If water isn't being diverted properly, I think this calls for a real repair person.
Posted on Feb 05, 2008
SOURCE: Can you use Oxyclean along with detergent in front loaders?
I use 2 Tablespoons of Liquid Detergent and a 1/2 to 3/4 scoop of Oxyclean and I have had good results in my Front Loader. Clothes come out very clean and there is no residue on the inside of my washer.
Posted on Oct 07, 2008
Sea Breeze
  • 4654 Answers
SOURCE: Washer is turning my white clothes gray
Oil from transmission is a good possibility. The machine is still young but sounds like you do a lot with the washer. Better have a friend that don't mind looking it over, make sure that's oil and go from there!
Posted on Feb 02, 2009
SOURCE: Stains on clothes after washing
This sounds like the infamous "Frigidaire Flaw" (they make some of GE's washers). The likely culprit is that the bearings on the drum's spindle are leaking.
To diagnose, call a repair man, or pull it out and remove the back cover. If you see brown streaks from the center spindle - that's it.
Repair is cheap if you can do the work yourself (inner and outer bearings), but $300+ for a technician
Posted on Apr 23, 2009
What is error code 130 fisher & Paykel intuitive eco IW812 ?
the R.P.S or rotory postition sensor is faulty or the connections are corroded
Jun 29, 2014 | Fisher and Paykel IWL12 Top Load Washer
Fisher Paykel Intuitive Eco Washer IWL12 fault code 37
Pump Ohms to low will smell like burning enamal
The pump will need replacing,
Apr 06, 2013 | Fisher and Paykel Washing Machines
Fisher & paykel IWL12 Fault code 12
Your water inlet valve is likely defective. The supply hoses behind the machine lead to the watervalve.
Jan 08, 2013 | Fisher and Paykel Fisher Paykel Intuitive...
I have a fisher & paykel intuitive eco and on the display screen it reads needs a service code 37 ?
Hello, It sounds like you have a restricted or blocked drain pump. This usually occurs in the outlet of the pump between the pump and the diverter valve. 1st check that the drain hose is not kinked or crushed and does not have too long of an extension on it. If the tub did not drain you will have to bail or otherwise remove the water. Of course unplug the machine before any service. Once that is done, lean the machine backward the drain pump is located under the machine on the right side close to you. unplug the wires to the pump and remove the pump by lifting the small plastic catch and turning the pump assembly a quarter turn counterclockwise. Next disconnect the pump from the hose to the diverter valve. you can also remove the pump hose from the diverter valve and check to see if anything is caught in the valve. That's really all there is to the drain system. Good Luck.
Mar 12, 2011 | Fisher and Paykel Fisher Paykel Intuitive...
Wont drain looked in pump area does nto appear to be anything clogging it. Shoulds I take pump out? If so how? Fault code is 37 on a fisher paykel IWL12
After taking all apart and putting back together 3 times looking for some type of clog in the pump area I decided to take the hose off that is located underneath the washer. There I found a penny!
All better! I love my fisher paykel! I personally fixed it.....saved myself $95.00 per half hour and parts. Since i am a woman lots of times a repairman would have said I needed a new pump!
Jun 12, 2009 | Fisher and Paykel IWL12 Top Load Washer
Starts to fill with water then beeps and says not getting water fisher and paykel intuitive eco
undo the water hoses at the back of the machine & check for any blockages between the hoses and the the water inlets.
Mar 09, 2009 | Fisher and Paykel IWL12 Top Load Washer
Washer won't drain after wash cycle
It may be a blocked pump under the machine.
I removed debris that got clogged there when the machine drains.
1) unplug machine
2) tilt machine back
3) locate pump under front right corner
4) remove pump by pushing and twisting it counter clockwise - note the locking latch needs to be lifted at same time
5) look for debris blocking the drainage tubes.
Sep 13, 2008 | Fisher and Paykel IWL12 Top Load Washer
Broken washer
could be clogged drain. look at my issue "eco smart won't drain, smells hot" on how to remove motor from bottom of washer and check lower drainage area. bail water out first and be ready to catch water when you remove that motor unit.
May 14, 2008 | Fisher and Paykel IWL12 Top Load Washer
Washing Machines Logo
15 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
