Flicking picture replaced lamp day later pic flickers
  • 38 Answers
Post make & model#
Posted on Mar 18, 2014
5 Suggested Answers
SOURCE: Replaced the lamp, 8 days later it`s out again.
You Have bad cap's on you power supply board causing the
5 volt line to go low. Call a service provider.
Posted on Nov 18, 2007
  • 1153 Answers
SOURCE: replaced lamp in Mitsubishi WD-62725, second lamp blew after 2 days,sound but no picture
www.ctechnicians.com read the self test diagnosis
Posted on Dec 12, 2007
Mr_Wizardtex
  • 205 Answers
SOURCE: dlp has no picture only flickering lamp & timer lights.
Verify color wheel is reconnected, color wheel needs to get up to speed before lamp strikes
Posted on Jun 28, 2009
SD Tech
  • 14553 Answers
SOURCE: replaced lamp in my mitsubishi wd 60638 dlp but now I have a flickering picture
Sounds like a new lamp that is generic (not Mitsubishi) as the set does not know which lamp is in the set--works with one and not the other you have found your problem.
Posted on May 23, 2012
Replaced lamp on my Mitsubishi 82 in dlp. after 15 minutes pic started to flicker losing color. was advised to also change lamp ballast, did that but still flickers with new lamp. put old lamp back in tv...
When you put the old lamp back in did the picture look OK? If so why did you replace to begin with? Yes, there are some poorly manufactured lamps out there, where did you obtain the replacement? Was it true OEM?
Dec 04, 2014 | Mitsubishi Wd-82837 82" Inch 3d Full Hd...
Mitsubishi tv flickering
the problem you are having is the colour wheel. it spins to correct the colour on the screen when it fails you get wrong colours and flicker... the motor on it fails after time. and will need replacing.
Mar 05, 2014 | Televison & Video
My projector has a blue flickering hint in the picture, is it a lamp related issue, or is it a lcd problem.....?My lamp do needs replacing because the indicator says so.......but will replacing the lamp...
blue flickering hint, means the lcd panel is break,
or polarizer is break. We supply original projector parts: lamp, bulb, Lcd
panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and
competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Jul 12, 2013 | Epson Replacement Lamp ELPLP30 f EMP-61...
Tv was flicking took apart and cleaned now turn tv on and it go's right back off no pic. though
Hi Leanne.. since your TV was flickering to begin with, that problem still exist since cleaning it will not resolve it... as a rule, cleaning a TV by taking it apart will not solve any problems, only creat more..
Flickering of the picture us usually caused by weak signal reception and should be the first thing to check. Next check the power cord and receptacle and make sure neither are worn or damaged. Try moving the tv to another receptacle... if it still is not working correctly, probably time for a trip to the TV repair shop...
Sep 09, 2012 | Polaroid Televison & Video
Replaced lamp in my mitsubishi wd 60638 dlp but now I have a flickering picture
May 23, 2012 | Mitsubishi WD-60638 DLP TV
Sony vio pcg7z2L
You could have a faulty inverter, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jun 27, 2009 | Sony Computers & Internet
Laptop runs but screen stays blank
Defective CCFL backlight may has the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Check out www.lcdparts.net for parts, repair service and DIY info.
Apr 01, 2009 | HP Compaq Presario V6000T Notebook PC
THE SCREEN OF MY LAPTOP (ASUS)TURNS PINK.Can anybody help me to solve this.
Connect an external monitor to the laptop and power it up, if you see a clear image on an external monitor, this means your video card is OK.
If you see a dim image or flicking image on the LCD screen it means you have a backlight problem.
Mar 14, 2009 | Acer Aspire 5630 Notebook
Oct 31, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Channnel keeps flicking like your changing channels with remote
when you say flickering??? are you saying the screen goes black and comes back on?? does the sound go out at the same time and comes bag on with the pic ? Is the sound there when this happens but is distorted. Is the pic blacked out or is it greying out with lines and twisting?? Need more info please as if its blacking out and the sound goes with it it may be going into shutdown. If the pic is getting kinda greyish with it twisting and the sound is there and ditorted then the tuner could be bad
Mar 25, 2006 | Sony KV-32S26 32" TV
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
