Question about Canon PIXMA MX340 Wireless Office All-in-One InkJet Printer
Connectng pixma mx340 wifi to my tablet
Im trying to connect my plt8801k tablet to my pixma mx340 printer can it be done and how if so?
  • 628 Answers
You should have no problems as long as the tablet can see the printer's signals. If you need to you may also use a USB cable to connect them. But generally you should have no issues in connecting a tablet to a wireless printer.
Posted on Mar 18, 2014
  • 823 Answers
SOURCE: how to recieve a fax
Take your incoming phone line and plug it into the place that says "line" on your fax machine. Plug another phone cord into where it says "phone" and connect this to your telephone. Test to make sure you have chosen the right places by dialing a phone number to fax to and listen for the dial tone. If you get a dial tone, then you have set it up correctly.
On the fax machine look for the button that says "menu". Push it and use the up and down arrows to navigate the options on the display. Look for fax set up and press "ok" or "enter" on the fax machines keyboard to access this area. Look for "number of rings" and change the fax machine to a number of rings that is less then your voice mail box if you have one. Then close and save your choices.
Have someone send a test fax by dialing your phone number for the line connected to the machine. The fax machine will pick up on the number of rings set and automatically begin receiving and printing a copy of your incoming fax.
You cannot use magic jack.
You can also choose to manually answer an incoming fax if you see that your display on the fax machine says "ringing" or incoming" you can push the "start" button and this will start receiving your incoming fax.
Posted on Sep 30, 2010
  • 3278 Answers
SOURCE: I am attempting to wirelessly
Hello.
First, delete your printer icon in Printers and Faxes, restart your laptop, then follow the Easy Install instructions and prompts. Choose the network printer connection and continue.
Hope this helps..
Posted on Oct 12, 2010
  • 128 Answers
SOURCE: Canon pixma mx340 4-in-1 wireless
error 6000 is a paper jam, which means there is something in the flag that senses whether or not there is paper in the path. Look very carefully in the area just before the paper comes out before the printing area. You will likely find a small piece of paper stuck, or a small object. Often a small inspection mirror helps.
Posted on Nov 01, 2010
  • 1570 Answers
SOURCE: tried setting up wifi with
Yes, you are correct, you need to turn off the firewall setting of your AVG antivirus and then re add again the wireless printer using the add printer wizard. Regards
Posted on Jun 24, 2011
  • 61 Answers
SOURCE: Printer Canon Pixma mx340 not
Your drives for the printer have been compromised, this is a common problem when switching to new devices, some times even moving the same equipment to another room will cause it. First thing you need to do is get into the "device manager" and see if your ports are enabled. Click in 'Start' Icon then go to 'Control Panel" and 'R Click' on "system". This should bring up a box with several tabs at the top. [Before I go any further I don't know what system you are running so you can also access "device manager' by clicking 'Start" go up to "my computer" and 'R click" this will open a drop down box where you want to go to the bottom and 'L click" on "properties" it will bring up the same box]. As I said before this should bring up a box with several tabs click on "Hardware" when it changes the first icon down will be "Device Manager" "L click on it and all the important drives and devices in the computer open up before (you may have to click the upper right hand corner to get a full page view) Each listing will have a little box to the left of it with a [+] sign next to it. Go down the list until you come to see "Ports (Com & LTP ). This is the way it shows on most computers. L Click" and the [+] box and it will open up to your drives. "R click on the first one and a drop down list list will pop out giving you the choices, choose "update driver" and let the wizard do it's thing. This is more than likely your "COM" port for your internet connections. Go to the next one that may say printer port or may just have "LTP", do the same thing to it. This is probably the only two ports activated on your computer, if there are more perform the same thing on them. Now we've got the PC opened up to take the printer drivers, try running your printer CD again and carefully follow all the download instructions. This should put you back into the printing business. In the event that this doesn't work you may need to go to your search engine and type " Free download for (your printer name and model) pay special attention to any letters after your printer type, such as "mx340a or n etc. This can make all the difference in the world on your download. It may not have one but be sure you look it over good. When you restart your computer after activating the drives go to "control Panel" again and "R click on "printers and scanners" then "L click open" and it should show your printer. Again "R click on the printer and 'L click on open" and see if the computer wizard can find your printer. (This step should have been performed before you try the internet download. I got ahead of myself.) All of your files are in the computer or printer and this should activate the directory and register keys should pick them up. dhgill1949
Posted on Sep 01, 2011
Got a canon pixma mg3250 wireless printer set it up as told put in cd rom seemed to have done everything i was supposed to but it wont print
A wifi printer needs to connect to your wifi network and it needs to be recognized by Windows.If your wifi network is already set up and working with other devices (tablets, smartphones, etc) , then you may be dealing with a simple security issue ( you may need to enter the proper passphrase, network key, etc.when you set up the printer) . If you do not have a wireless network already set up, then things get very complicated!!!
Feb 28, 2015 | Canon PIXMA MG3250 All-in-One Inkjet...
I have an canon MX340 printer that i bought in 2010. I know the printer is working because the maintenance nozzle check worked. I have recently installed microsoft 2010 on my wireless laptop. I'm us
You can only connect your printer to your PC via wireless, not to the internet. Your MX340 is not WiFi capable and is not a computer. Linking it to your PC via wireless just saves you having to connect it by cable.
Oct 06, 2014 | Canon PIXMA MX340 Wireless Office...
Why won't my canon mx340 usb cable does not fit into d-link router
There is no need to use USB cable to connect MX340 to a wireless router.
If you don't want to use the printer as wireless, plug the printer cable directly into your PC USB port.
Aug 18, 2014 | Canon PIXMA MX340 Wireless Office...
Dell XPS won't connect wirelessly to my Canon MX340? I have a wireless router for the internet that I am using right now
have you configure your router to access your printer?. try to navigate on menu at the printer and locate any possible wireless connection opened, then just follow the screen guide on your printer to access wirelessly.
Sep 13, 2011 | Canon PIXMA MX340 Wireless Office...
Which slot does the paper go in? Is there any online manuals?
Please read for PDF manual for Canon PIXMA MX340 Wireless Office AllinOne InkJet Printer.
Canon-MX340-Multifunction-Printers-manual
or Download Here
I hope usefull.
Jul 31, 2011 | Canon PIXMA MX340 Wireless Office...
Need driver for canon pixma mx347
You can download your Canon Pixma Inkjet Printer from here http://downloadnew.biz/drivers/printer/canon-pixma-mx347-mx340-mp-driver-517631.html Hope this helps.
Please rate if this solution was helpful,thanks!
Jul 14, 2011 | Canon PIXMA MX340 Wireless Office...
Tried setting up wifi with canon mx340, everything ok till end, then said connecting, tried several times, but still no joy. could it be firewall i have avg and comodo installed best wishes wal.
Jun 24, 2011 | Canon PIXMA MX340 Wireless Office...
My Canon MX340 is all set up wirelessly and has the blue light on. But when I try to print something from Word is shows that the printer is not responding. I know it prints because I used it to copy...
You MUST put in the password of the router in or it will never connect. Pressing a number key several times quickly should change the number to letters.
May 16, 2017 | Canon PIXMA MX340 Wireless Office...
Canon PIXMA MX340 Wireless Office All-in-One InkJet Printer Logo
113 people viewed this question
old marine
old marine
