Question about Air Tools & Compressors
My sander wont stop spinning - Air Tools & Compressors
My hitachi sv13ya done? My sander turn on spins but as soon as i try to sand it stops spinning. It has no torque. Is it done or can it be fixed
There is a ball bearing bearing on position 29 that is dirty replace it or remove and clean it open the sealings with a very little thin screwdriver solvent it out and re grease it and close the sealings again.
Hitachi SV13YA 5 Variable Speed Random Orbit Finishing Sander Parts
Sep 23, 2015 | Sander Tools & Hardware - Others
Sander doesn't spin
YOUR BALLBEARING where the disk is on mounted is the right bearing that have the problem for shure it is full of dust or completely dry it will not turn anymore SIMPLY TO CONTROL IF YOU MOVE YOUR DISK NOW ON YOUR MACHINE YOUR ARMATURE TURNS DIRECTLY WITH THE DISK thats not good the armature must stand still , replace the ballbearing or remove it and open it with a very little sharp screwdriver on the both sides solvent it out try to turn the bearing carefully until its turns without problems dry it or blow it out with a compressor and if its dry lubricate with ballbearing grease close it again and mount it again
Nov 13, 2013 | Metabo SXE450 00458 6'' Random Orbit...
Sander disk stops spinning on contact.
It sounds like a gear is worn out inside the sander.
Many of these have a gear or a splined shaft on the end of the motor armature, and the shaft or gear meshes with another to make the disc turn.
One of your gears or shafts has likely worn out.
Sometimes these can be fixed ( I've done a few) , but sometimes the repair parts are either unavailable, or too expensive to make it worthwhile.
Be blessed.
Mar 10, 2013 | Tools & Hardware - Others
When I push the sander on the wall it stops spinning and starts clicking
The best way to sand drywall is to use a pole sander (manually). You can pick them up for about $20.
This particular machine tends to leave grooves in the drywall compound if you are not familiar with how to use it.
If you should have any questions about "Drywall Finishing/Patching", or know someone who does, put your questions to Category:"Tools- Building & Power- HAND TOOLS" at FixYa.com
Thanks,
Jim
Aug 28, 2010 | Porter Cable 7800 Drywall Sander With Dust...
Dynabrade sander doesn't spin
check the exhaust muffler. or just take it off and see what happens.
there is usually an inlet air adjustment on the palm sander itself one of these will correct your sander.
if not, and your air supply is good. put some air oil in it or even a light weight oil will work.
if none of this is the correct action to get it going. its probably toast!
Mar 03, 2010 | Dynabrade 56818 5" Supreme Vacuum Orbital...
Hand sander stops spinning once placed on item to be sanded
This sander has a brake pad that is supposed to stop the rotation when the sander is not actually in use. It sounds like it's malfunctioning.
The only other thing I can think could be a cause of what you describe is an improperly assembled sanding base. Have you changed out the base, and if so, were you sure to properly align the replaced base on the machine before you tightened the allen screw?
If you're not comfortable disassembling a tool that is still under warranty ( I think it's two years for that one), I would recommend finding a Dewalt service center and taking it in for a factory service call.
Mar 24, 2009 | Black & Decker Black And Decker Cyclone 4...
The disc will not keep spinning
I am assuming you have a 5" pad palm sander. IF pad stops then belt is broken
Mar 05, 2009 | Dewalt Tools & Hardware - Others
Disc pad stops
It could either be that the brushes partially burned I would check to make sure your brushes are in good shape and take it out of the helpers pay ;)
Nov 06, 2008 | Porter Cable 332K Quicksand Random Orbit...
Air Tools & Compressors Logo
462 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
