What do I need to do to down load pictures from my Nokia 2605 Mirage cell phone to my MAC laptop ? I have the correct USB cable. When I hook up the phone to my Mac (or to the PC at work) the computer is not recognizing that a device has been attached for down loading images. Do I need to install/download special Nokia software ? Thank you. juergen
Re: What do I need to do to down load pictures from my...
I'm not familar with the Mirage. If it isn't a PDA or smart phone you need to get software to interface your PC with your phone. Palms, Black berries & other PDA's automatically come with this software.
If your phone charger cord has a usb connector on one end, then use it to transfer your pictures. If not, then get a cable that has the correct end for your phone ans a usb connector on the other end
ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000 Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile. send the IMEI no to me and i will reply you with unlocking code. IF Problem not Solved So Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator Enter The Puk code and Yes Enter The pin code and Yes So Puk code Open and Problem will Quickly Solved
Their are two ways this can be accomplished:
buying/ getting a code, then going through a process to unlock it
OR
Using a technique that does not involve codes OR money.
(I am NOT endorsing this product, nor do I have any sort of association with this product, I only recommend it)
If you so choose, you may use the code. This is actually the most popular, and instructions can be found here.
But for a second option, do this:
Or, for more options, just google "unlock nokia phones"
Hope this helped! Be Sure To Rate macapplezoo 100% Or Whatever You Thionk I Deserve!
You need your USB cable, your phone and your PC/laptop.
1. plug your USB cable from your phone to your PC or laptop 2. wait until your PC/laptop detects your device 3. go to my computer, left click your phone's drive 4. go to images folder and left click it. 5. there are many sub folders inside the images folder, always choose the last and the 2nd to the last folder because this is where your pictures are stored. 6. highlight all of your pictures and right click, choose copy 7. select the drive to which you will place your pictures. click paste.
Take both thumbs and place on back cover. Push away from the silver Xpress insert. Lift cover from back of phone. To put it back on, line up tabs and push cover toward the silver Xpress insert till it seats in place.
Yes you'll need a cable driver for your usb cable, or you'll need to download the nokia pc suite, that depends on what kind of cable you have, you can download the driver or pc suite from the nokia web site, www.nokia.com
good luck.
just get the software from the internet and the usb cable, or if u hav a memory card on usb mode (in phone settings) go on mass storage, and connect ur usb and it shud work if dat dunt work get a memory card adapter and conect it 2 ur laptop and send it 2 it hope this helps.
