Question about Samsung RF4287HABP Refrigeration : Refrigerator : French door
Samsung RF4267HABP ice build up - Samsung RF4287HABP Refrigeration : Refrigerator : French door
    New Friend:
Is the ice build-up in the freezer section, or in the chill section ?
Posted on Mar 17, 2014
My samsung rs20br has ice build up on the floor of the freezer, under the bottom drawer. I defrosted it but it has come back . How can i fix this?
Believe it or not your freezer has a heater that defrost your freezer. It runs on a cycle to keep the ice from building up. Your freezer may be set to cold or the heater isn't working properly.
Jan 18, 2018 | Samsung Refrigerators
Ice buildup in bottom of freezer compartment
Here's a link to a great website that will help you understand what might be causing your freezer to have that ice build up. I could explain it here, but if you look at this link, they've already done a wonderful job.
http://www.appliance411.com/faq/defrostproblem.shtml
Jun 08, 2016 | Samsung RF4287HARS French Door...
Ice maker ice jam
Not a whole lot you can do but to keep the frost down.
If you are able to move the items in the freezer to another freezer and let it sit overnight, all your problems will melt away....
Until a couple months later when it builds up
Make sure to double check your freezer is sealing correctly, bad gasket causes moisture to be sucked in.
Here are some basic ways to slow the buildup
How to Avoid Freezer Frost
Feb 10, 2016 | Samsung Refrigerators
Ice is building up and making fan noise. I replaced the defrost thermostat. Four or five days, it starts making noise again. Any ideas where to look after replacing the thermostat?
I suppose it's possible the fan has some issues of clearance. You may be able to adjust it to provide needed clearance. But if the Ice build-up is excessive, there may be a "timer" that may have an effect on the amount of ice build.
May 02, 2015 | Samsung Refrigerators
I defrosted my Samsung coils and when turning it on and there is ice building up already. Should this happen?
May need new defrost heater. If so, that heater will read infinite ohms. A good heater will read 50 to 200 ohms. Change small inexpensive clip-on thermostat at same time. But don't worry about a little ice build-up if your temps are okay. Excessive ice build-up will be shown by your hearing a crunchy sound when you reach into the freezer to press your hand against its thin rear wall.
Oct 18, 2014 | Samsung RS2556 Side by Side Refrigerator
Samsung RF217 refigergator makes a noise because ice builds up and fan hits the ice
If possible try to let the fridge cool down or a bit until the ice melts and if the ice is visible, than it would be better to attempt to break off the ice while it is warmer than usual
Oct 14, 2013 | Samsung Assembly Evaporator Refridgerator...
I have a Samsung RF265ABBP model. I just finished replacing the ice maker kit and everything works fine. I noticed Ice build up on the left side of the sliding door. It builds up on the fridge itself and...
Could be a gasket problem. But, also on those sliding doors, ice can cause them to not properly close all the way! Pull the door all the way open and check the track/rails for ANY ice. Make sure it is completely free of ice!
Oct 11, 2013 | Samsung RF265ABBP (25.8 cu. ft.) Bottom...
Tempreture on fridge too high ice build up in fridge mahes noise like a tractor
Your automatic defrost cycle may not be working. Feel the walls inside and if they are hard solid you have ice build up and the fan is hitting the walls or ice making the noise. Unplug your fridge for 2 days and let the ice in the walls melt. Put towels on floor to catch water. Plug it back in and it should run fine for a couple of weeks until the ice builds up again. You have a bad timer and it isn't letting the defrost cycle come on. Defrost cycle are heating elements that melt the ice build up and runs about 10 mins once a day or so. This will give you time to check if an afforable repair can be done or a replacement fridge.
Jul 11, 2010 | Samsung Refrigerators
Samsung RF4287HABP Refrigeration : Refrigerator : French door Logo
126 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
