Question about Microwave Ovens
Russell hobbs oven/grill model no rhm2013.. stopped heating there is a red light looks like half moons on panel ...iv read basic tips .troubleshooting called company .no one has answer,
woobie dog
  • 1273 Answers
SOURCE: Microwave is just over 1 year old and has stopped heating things
Most micro's have a % heat setting. Make sure that you are at 100%
Posted on Jul 22, 2009
tbirdfan1
  • 3051 Answers
SOURCE: Bulb blown. How do I change it?
Hello there :
first you will need to remove all of the screws off the back edges and the sides next turn over the microwave over and there will be 6 or 8 screws that are on the bottom edges remove them now turn over the microwave and using a flat tip screwdriver look at the seam and you can use the screwdriver to get the cover to start moving towards the back andd then once it is loose it will lift off
Now you will see the bulb towards the fromnt of the microwave simply replace the bulb and test it the microwave if it works reassemble the microwave and you are done ok ?
I hope this is very helpful for you
Best regards Michael
Posted on Dec 03, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: My Russell Hobbs microwave will not generate heat
If everything else is normal, the trouble may be a failed magnetron tube (the microwave source), problems on the control circuit board, or parts in the tube power circuit that are bad. It's also possible a door switch can be at fault, but this usually keeps something else (fan, turntable or light, most often) from running as well.
Microwave servicing is best left to professionals. There are potentially deadly voltages present, and a chance of microwave leakage if repairs aren't done correctly. Take the oven to a shop for an estimate, or just consider replacing it if it isn't a built-in, an over the range unit or a high-end countertop model.
Posted on Feb 02, 2010
SOURCE: Russell Hobbs HOB CTS34 - Faulty glass plate
Door glass broken on russel hobbs 28lt micro wave. Any idea where I can have this replaced. thank you
Posted on Mar 10, 2010
  • 193 Answers
SOURCE: Russell Hobbs HOB CJ/AL28 Microwave not worring
it is easy to fix if you know what to do but it is best sent to a local repair shop
Posted on May 01, 2010
Ihave a russell hobbs convection/microwave/grill model no rhm2574 when programming oven when pressing start button the oven trips the power to the sockets this happens on all functions.whats wrong
It is likely that the heater element is faulty. These elements can fail with a ground fault. You should get a quote for repair as it may be more economical to buy a new one, and you get a warranty too.
Sep 20, 2016 | Russell Hobbs Microwave Ovens
Have lost instructions for russell hobbs oven/microwave model no RHM20105-H serial no 0133100063
I think this the manual your looking for. That 5 is the model appears to be a S instead. Roll your mouse over the large black rectangle for pop-up download menu.
Russell Hobbs Microwave Oven User Manual ManualsOnline com
Dec 24, 2014 | Russell Hobbs Microwave Ovens
My microwave is not hotting anything
Not heating can have three basic causes:
Diode used in most models fails.
Inverter board used in most models fails (it powers the Magnetron)]
The Magnetron itself which does the actual cooking can fail and may look perfect.
There are some lesser reasons but they require some testing.
12_13_2012_3_01_15_pm.jpgtypical microwave diode
12_13_2012_3_01_55_pm.jpgTypical Magnetron
Dec 13, 2012 | Russell Hobbs Microwave Ovens
I am looking to buy a sandwich maker like the 17936 and set it on timer for the morning so they are ready for when I wake up and go to work - does this russell hobbs model heat up and then stop heating...
Here are a few links to some information about the Russell Hobbs Model 17936 Sandwich Maker:
http://www.amazon.co.uk/Russell-Hobbs-17936-Sandwich-Maker/dp/B002MRS1NM
http://www.reevoo.com/p/russell-hobbs-2-sandwich-maker
http://www.sonicdirect.co.uk/catalogue--iID--5785--russell-hobbs-17936-2-slice-sandwich-toaster-in-brushed-stainless-steel.php
I don't think you will find a small sandwich maker with the type of automatic timer you are describing. Most full size digital ovens have that function, but very few smaller units like the 17936.
Also, would it not be a bit impractical to leave a sandwich with perishable toppings in the machine overnight in order for it to begin cooking in the morning? Any kind of meat product left out overnight unrefrigerated may become dangerously contaminated and spoil.
For all the time these machines take to heat up, you might as well just get up 5 minutes earlier in the morning and prepare your sandwich then.
Good luck though either way.
Jun 14, 2011 | Microwave Ovens
My LG MICROWAVE OVEN IS MODEL MC-7836M CONVECTION MICRO GRILL IT IS RUNNING BUT NOT HEATING and GRILL ALSO NOT WORKING
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Jul 27, 2010 | LG LRM1230W Microwave Oven
Doesn't heat.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
satq
Jun 17, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Feb 02, 2010 | Microwave Ovens
Mar 15, 2008 | Microwave Ovens
Microwave Ovens Logo
44 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
