Question about DeLonghi Magnifica Coffee Makers & Espresso Machines
Esam 3200 delonghi magnifica infuser is stuck...
My esam 3200 infuser is stuck, I cannot take it out to clean it... when I turn it off then back on again the (!) light is a solid red, and the one cup & two cup coffee light is on, the machine doesn't do anything... What can I do to fix the problem?
  • waltonvincen
    waltonvincen Mar 17, 2014
    Turning off the power with the button didn't help, unplugging the machine and starting it up again didn't help, the (!) light is solid red and the 1 & 2 cups light is permanent green... When I turn the machine on it clicks once and then nothing.... How can I get the infuser out so I can clean it?
SOURCE: delonghi magnifica coffee machine...infuser jammed
Remove base plate and turn pulley clockwise (probably for several minutes) until infuser arm returns to vertical position and the infuser itself drops to the low position. You should here a click when it reaches this point. The infuser can then be removed as normal.
Posted on May 03, 2010
SOURCE: descaling a delonghi magnifica ESAm04
I had this problem too. The instruction manual says to turn the steam knob only half way counter-clockwise after pressing the button for 5 seconds, but you need to turn it ALL the way to have the procedure start (at least, that was the solution with my machine). Good luck!
Posted on Jul 08, 2010
SOURCE: hello i have an Delonghi esam
I had this problem until I realised that you need to switch the machine off by pressing the on/off button on the front of the machine first *before* switching it off at the back and unplugging it. This moves the infuser unit further to the bottom and then allows you to take it out.
Posted on Nov 11, 2010
ginko
  • 19396 Answers
SOURCE: alternating 3 lights (1 cup,
Hi.
The machine is not flashing an error message. When a problem is detected you get an error message on display.
First hold down ESC (or STOP/CLEAR depending on model), just in case machine is stuck in programming mode.
Disconnect power cord for two minutes. Connect back and try a reset if the problem is not fixed:
•Press the CHANGE button and the appliance displays "RESET TO DEFAULT YES";
•Press the OK button to reset the factory default values;
•Press the MENU button to exit programming mode or NEXT to change other parameters.
If that does not work, try holding down rinse or descale. If the machine starts rinse or descale, complete the procedure. If machine gets stuck in rinse or descale, keep filling the container while performing the procedure.
If all that does not fix the problem, call Delonghi at the number listed on the owners manual, the machine is defective.
Try all the rest first, or Delonghi may ask you to do some of the same procedures while operator is waiting at the phone.
Regards.
Ginko.
Posted on Apr 06, 2011
  • 30 Answers
SOURCE: new delonghi magnifica esam 3200.s from
Run the hot water tap till it comes good.
Posted on Jan 29, 2012
Magnifica ESAM 3500 milk temperature low
This is factory preset and cannot be altered. You do need to use the "clean" function on the milk frother unit to ensure the boiler and pipes heat up enough also.
May 15, 2014 | DeLonghi Esclusivo Magnifica ESAM3300...
Changing the Magnifica ESAM 3500 milk temperature
This is preset and cannot be altered.. Do ensure you preheat the milk frother before use.. by activating the "clean" button on the frother jug
May 15, 2014 | DeLonghi ESAM3500 Espresso Machine &...
How do you remove a stuck diffuser on ESAM4200. Have tried switiching it on and off but its still stuck
Hi Sue Are you sure that it is not the infuser that is stuck. Theere are a number of things you can do to try to loosen it. Has it clicked? I put the link to the manual here, you should be able to find help there, I have when I could not get my ifuser to click iuser.http://www.delonghi.com/corporate_en/products/esam-4200s-ex1/ Kolbrun
Sep 10, 2013 | DeLonghi Coffee Makers & Espresso Machines
User manual required for DeLonghi Magnifica ESAM 4200.s
here is general technical data for the unit
http://www.delonghi.com/uk_en/products/esam-4200s/
and here is the manual!
http://www.filesavr.com/YE9UE5DM5WIBGUV
Hope I helped, thanks for using FixYa!
Aug 08, 2011 | Microwave Ovens
Hello i have an Delonghi esam 4200 and the infuser got stuck can you please recommend how can i solve it
Aug 27, 2010 | DeLonghi Coffee Makers & Espresso Machines
I'm getting the "generic alarm message even though I've cleaned my DeLonghi Magnifica. What do I need to do next?
Not good; from page 21 of the owner's manual: If the message is still displayed after cleaning, contact the service center.
The good news is that when I had to send in my ESAM3500 for warranty repair, I called DeLonghi (1-866-528-8323) and got through to their repair center without difficulty. They sent a new shipping box and wrapping material, and a prepaid shipping label to a repair center about 100 miles away. I got my repair ESAM back in just a week. I hope that your experience goes as well. If it's out of warranty, though, it could be expensive.
May 17, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
Descaling a delonghi magnifica ESAm04
Apr 22, 2010 | DeLonghi Coffee Makers & Espresso Machines
Coffee Makers & Espresso Machines Logo
213 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
