Question about Star Micronics SP700 Receipt Printer
How do i set MSW settings to double-byte for chines character printing on sp700
Shodow item when printing
Try to recheck the utilities and the properties, set it and chose photo.
Jun 30, 2014 | Star Micronics SP700 Receipt Printer
Star micronic sp700 ethernet problem
10.x.x.x subnet can't see 192.x.x.x network. There must be manufacture reset button on the Star micronics sp700?. You can configured your laptop/computer IP to 192.168.2.100 (not the same as printer) than use crossover ethernet cable (you can find it in best buy), connected directly between your laptop and printer, you should be able to see it on your browser now.
Most people big mistake when assigned static ip. First you need to reserve that IP on your router so it doesn't get pickup by DHCP and assigned to another devices.
Mar 20, 2014 | Star Micronics Star IFBD-HE07 - Print...
Why does my star sp700 printer only print in red ?
seriously people? he said it's printing red. obviously it's not out of paper, the door is not open, there's no paper jam, etc.
Apr 27, 2013 | Star Micronics SP700 Receipt Printer
CANT STOP OKI 591 PRINTER TO STOP PRINTING REPORT
Check that the LINE FEED button is not jamming or on.
The LINE FEED + POWER ON will print the "Printer Character Report" or "Test Page".
May 24, 2010 | Okidata 591 Printer
HOW DO YOU CHANGE THE CHARACTER PITCH
You have not specified which printer you are using.
1. In a serial printer having a displaceable printing head and being selectively operative in a setting mode for setting a variable character pitch and in a normal mode for effecting a printing operation according to the set character pitch: a plurality of manually operable switches each having assigned thereto a normal function which is performed when the switch is operated when the printer is in the normal mode and having assigned thereto a setting function which is performed when the switch is operated when the printer is in the setting mode, at least one of the switches having a setting function which effects selective displacement of the printing head to one of a plurality of predetermined positions each corresponding to a different character pitch; means for producing character pitch data effective to specify a desired character pitch according to the selected position to which the printing head is selectively displaced; and storage means operative when the printer is in the setting mode for setting therein the desired character pitch data for use during a printing operation of the printer in the normal mode.
2. A serial printer according to claim 1; including controlling means for controlling the serial printer to effect changeover between the normal mode and setting mode.
3. A serial printer according to claim 2; wherein one of the switches has a setting function which enables the controlling means to set the setting mode.
4. A serial printer according to claim 3; wherein two of the switches have setting functions which effect selective displacement of the printing head in opposite directions.
5. A serial printer according to claim 3; wherein one of the switches has a setting function which enables the storage means to set therein the desired character pitch data.
Jan 28, 2010 | Electronics - Others
Using ASCII commands form IBM INFOPRINT to Tally T6218
I used escape sequence: <esc>(w
this instructs the printer to use Canadian Englis font page
Nov 13, 2009 | Tally LJ Series T6218 LJ Matrix Printer
I cant get the Adobe Acrobat Pro 7.0 PDF Printer to work. It comes up with an warning 20225 code; setup was unable to create a new item.
I got 2 possible solutions:
Solution 1: Use a supported installation.
-- If you install Acrobat (Professional or Standard) on a 64-bit operating system, you may see this error. Install Acrobat on a 32-bit operating system.
-- If you install Acrobat to a shared network disk instead of a local hard disk, the Adobe PDF printer is not installed. Install Acrobat on a local hard disk.
-- If you install Acrobat to a directory with a path that contains extended ASCII or double-byte characters, English installations will display the error message. Install to a path that does not contain extended ASCII or double-byte characters.
Solution 2: Ensure that the Print Spooler process is running and set to Automatic, and then repair Acrobat.
1. Select Start > Settings > Control Panel.
2. Double-click Administrative Tools and then double-click Services.
3. Locate the service Print Spooler.
4. If the Startup Type is not Automatic, set it to Automatic:
a. Right-click the Print Spooler.
b. Choose Properties.
c. Choose the General tab.
d. Choose Automatic in the Startup Type menu.
e. Click OK.
5. If the Print Spooler service is not running, then start it.
a. Right-click the Print Spooler line.
b. Select Start from the menu.
6. Start Acrobat, and choose Help > Detect And Repair.
God Luck!!!!
Mar 12, 2009 | Computers & Internet
Unusual character where special character or underline is given
If you have a spare USB cable around the house, try that first and see if the cable was bad.
Aug 21, 2008 | HP DeskJet 640c InkJet Printer
Horzontally double printing & characters are not clers.
Is the ribbon tight or sticking, If ribbon can't turn, it delays entire carriage, you will notice that if you move carriage up and down by hand ribbon turns, I have seen sticky ribbon s cause problems as well as gearing that drives ribbon with wornout gears
If self test fails then all faults /i can think of on these is
  • Dry rail/dirty bearing
  • incorrectly manufactured ribbon
  • Damaged dot head
  • broken/breaking ribbon interface carriage cable
  • worn ribbon drive gears
  • worn/dirty ribbon drive rail
  • main board
Nov 17, 2007 | Epson LX-300 Matrix Printer
Star Micronics SP700 Receipt Printer Logo
Top Star Micronics Office Equipment & Supplies Experts
GoogleLaughs
Are you a Star Micronics Office Equipment and Supply Expert? Answer questions, earn points and help others
