Lg washing problems- loose drum
Drum is making a lot of noise and appears loose
    Problem Solver:
  • 11 Answers
Check to determine if the drum is coming in contact with the dryer's frame. You can do that by manually rotating the drum. Some drums do not have bearings at the front but are silenced as they turn by hard plastic strips attached to the dryer's frame where it otherwise will come in contact with the drum and make a noise . I had that problem - replaced one or two of those plastic strips -- solved the problem. You will need to remove the front of the dryer to check if your dryer is built as mine.
Posted on Mar 17, 2014
  • 130 Answers
SOURCE: roper washing machine the drum is loose and makes
remove the drum unit and check out as follows: Remove top panel. Most of these have front controls, so the screws on the top back allow the whole top to come off easily, remove the screws and pull the cover forward. If the dryer is mounted on top of the washer, remove the dryer off first. Remove the 2 lower screws on the front panel, pull kick panel down and off. Turn off the hot and cold water taps and remove back panel.
2. Loosen two screws that hold weight on back half and slide out weight.
3. Remove drive belt. Cut wire tie, unplug motor and leave wiring in the bottom of the washer. Remove 4 screws/bolts that hold on motor and remove motor
4. On front right, loosen screw and remove rubber drain trap from tub. Squeeze large snap ring and remove water level sensor ( thing that looks like an old fuel filter ) from rubber drain also. Remove little hose from top of water level switch also. ( NOTE: You can also disconnect the level switch hose at the top of the washer. This will make it easier to re-connect, however you'll need to be careful that you do not damage the hose when you remove the tub assembly ).
5. At this point, you might want to remove the motor control board and pump motor assembly. Each is secured by 2 screws and are easily removed. This will prevent accidental damage and give you more room inside the washer to work with. There are 2 connectors on the control board and 1 on the pump motor � be sure to remove those first.
6. Shocks, push the lock tab to allow the pin  to be slid out of the tub and the shock will be free from the drum. ( picture help one and picture help two )Push pins through to the rear and remove. The baskets will now be hanging from the springs.
7. From top, twist out the tube from top of the outer tank. Place support under drum. I use 2 blocks of wood.
8. From front, carefully cut the glued spots where the door seal is glued to the front panel and remove the fill spout holder clip. The tools used is a piece of copper tubing flattened down. I use a wire tie to reinstall as the metal clip can be a pain to work with!
9. Drum should just be hanging from 2 large springs. Remove the clips/spring holders that go over the top of the springs so they can be lifted and removed from the washer. Start on either side, lift spring, move toward center and lower to disconnect drum from the frame. Completely remove spring. Repeat on the other side. Drum should now be sitting on the supports.
10. From above, lift drum and slide out the rear. Leaves you with an empty cabinet.
11. Lay drum on front face on a blanket or sheet and start to remove screws that hold halves together. Once all screws are out, the back half with pulley (top half if sitting on face) easily lifts up from the other half.
12. Remove and replace tub gasket seal. New seal will appear thicker than old one. The old seal can be picked out with a small flat screwdriver.
Assembly.
13.  Place supports in bottom of washer. Lift and slide drum back into place on top of supports.
14. I use a zip/wire tie to go around the water fill tube where the spring clip was and then cut the leftover tail off of the zip/wire tie. I remove the 2 screws holding the plastic hose in place to make installing the wire tie easier. Push the rubber boot over the plastic hose and use the wire tie to secure the boot to the plastic hose. Helps to install drum support springs (big ones on top) first.
15. Install safety clips back over springs. Glue the top hose back into place.
16. Front assembly reverse of disassembly.
17. Back and Motor assemble reverse of disassembly.
18. Finally, pull the boot over the front of washer. Don't do this until drum is in fully, or the boot might not end up on straight and might twist a bit. Small spots are re-glued again in place, super glue works well for this.. Spot glue at the 12 o'clock, 1, 2, 3, 4, 5, 6, 7, 8 and 9 o'clock positions around the opening.
19. Put on back and top.
20. Run load, check for leaks. Note: back panel is structural and should be on for a load to be run.
21. Should be done. Total time 3+ hours. I hope this helps anyone who has to get into the Frigidaire -Kenmore ( 417.###### ) front loader and replace the seal/tub bearing&shell or inner basket.
Bearing and Seal notes:
Tips for removal / replacement of inner tub....
1. After removing the back panel and drive belt, remove the pulley from the shaft. The bolt is removed easily, but we often have to gently pry around the base of the pulley to remove it (unless you have a puller). The pulley is very light and the metal is soft, so be very careful that you do not damage or bend it while prying.2. The inner tub will lift out once you have split the outer drum halves.
3. Remove the 3 tumbling fins from the old inner tub. The new tub will not include these, so you'll need to reinstall the old ones. They are held on by one or to screws each. *Careful* of the outside of the wash basket as it is VERY sharp!!
Posted on May 07, 2009
Danmart
  • 291 Answers
SOURCE: ariston front loading washing washing
Believe it or not.....its almost always the cloths ( heavy blankets) that one places inside.
TRY:: In the spin cycle if the load is unbalanced the TUB will rock and make that "loose drum out of alignment" noise. STOP the machine and open the door ( IF IT IS A TOP LOADER ) realign the cloths (heavy or more then one blanket) so that it is EVENLY spaced through out the tub.Start the machine again.If it does it again, stop the machine and REALIGN the cloths (blanket !!) again.
p.s. there is a simpler way of doing it but I don't want you to loose your hand in the process.
Posted on Aug 31, 2009
  • 353 Answers
SOURCE: Hi I have a Hotpoint Aquarius washing machine
sounds like bearing problem. you can get to it by removing the front of the machine
Posted on Dec 31, 2009
  • 3 Answers
SOURCE: Sir, Drum of front loading washing machine making banging noise
Mine did that and had to have the washer re-balanced.
Posted on Aug 16, 2010
  • 490 Answers
SOURCE: i have a kenmore front load washer model
they dont have tracks they sought of float in the middle of the tub held on by the shaft coming off the spider arm on the back of your drum, if you can move the drum back and forth and it makes a metal crunchy kinda noise your spider arm has snapped to fix it you need a new drum and will almost quite literally have to dissasemble the machine into every piece its made of, altho not neccesarily difficult is quite time cosuming about 3-4 hours (thats for someone with experience)
Posted on May 03, 2011
LG front washer squeaks upon wash cycle and last till end of wash. Gets worse with each cycle. Sounds like rubber rubbing together.
Open door, and pull on drum/tub forward and back and see if it moves a lot. Next try to wiggle the drum/tub and see if it moves side to side, up and down. If either, then either drum bearings issue or bolt that holds drum to outer tub is loose. Let us know what you find by making a comment to this answer
Apr 15, 2017 | LG Washing Machines
The drum in my front loader washing machine appears to have come loose and is making a loud banging noise
Call a repairman if you don't want to fix it yourself. It is gonna need a lot. Is it still under warranty? you could get a free repair. 25310660-qjvctasbhmsa34yyzpjscfdr-2-0.jpg
Dec 07, 2014 | Washing Machines
Lg tromm wm1812cw dum makes load noise when spinning
LOUD NOISES IN MACHINE;
LOT OF THINGS TO CHECK, THE BELT LOOSE OR WORN, THE CLUTCH, THE TRANNY, THE BEARINGS BOTH TUB SEAL AND BEARING, THE REAR DRUM BEARING,
THE DRIVE PULLEY- If the washer is making a loud noise the drive pulley might be worn out, cracked, loose or bent. Remove the drive pulley and inspect it carefully. If it is damaged or defective replace it.
THE TRANSMISSION, THE MOTOR COUPLER, THE MOTOR DRIVE BEARINGS,
THE DRIVE MOTOR- If the washer is making a loud noise the drive motor bearings may have worn out. Washer motors are normally almost silent when they run. If the motor is run without a belt hooked up to it and it's loud it will have to be replaced.
Jun 15, 2014 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Drum starts to move then stops then Le appears and a slight hissing noise from direct drive motor. Looks like intemittant fault
The LE error message means "locked motor error" which means the control is not seeing the motor running.
The problem can be caused by a broken wire or loose connection but the most likely cause of the problem is a bad hall sensor.
The sensor can be accessed by removing the rear panel and the rotor assembly. See the image below for help with this. Remember to unplug the washer first.
Make sure the rotor and drum rotate. Anything blocking the tub rotation might trigger an LE code.
Aug 11, 2011 | LG WD-1080FD Front Load Washer
Machine is making clanking and grinding noise during wash cycle drum does not appear to be turning. does not make this noise if ran without items in wash and drum turns with no items in the wash
You may have a problem with bearing. Place your hand inside the drum and see if you can move it up and down. If the drum can be moved up and down, you have a severe bearing problem that will require a technician to tear down the unit and replace the bearing and drum assembly. It's a very expensive job.
Good luck
Jun 16, 2011 | LG WM0642H Front Load
Drum appears to be loose and makes a lot of noise when on the spin cycle
With the washer empty, spin the wash tub by hand. The drum should be spin true without any noticeable wobbling and spin without much noise. If it wobbles or makes any kind of rubbing or banging noise as you turn it by hand. The problem is that the spider support arms are broken. It is an expensive repair job since the washer has to be completely torn apart and the wash drum needs to be replaced. Get a few estimates before deciding whether to repair or replace. Sorry.
Mar 08, 2011 | Whirlpool AWM6100 Front Load Washer
It makes a loud noise whilst drum goes round
This is indeed a known issue in LG dryers. Mine does the same thing. Instead of contacting LG, I contacted an LG authorized serviceman. He advised me that replacing the rollers would still make the same noise. The LG techs that he spoke with (these are REAL techs, not the bozos that the consumer talks to) said that the problem can be minimized by selecting the Wrinkle Care option. After the drying cycle is over, Wrinkle Care will tumble the clothes 5 revolutions or so, every 10 minutes. This keeps the rollers round as they are cooling down. It does help, as mine still thumps on start-up, but not for nearly as long. I have come to accept this as a small price to pay for a superb dryer.
Here's a general guide though -
  • If a washing machine is rumbling, and very noisy on spin, the main suspect is the drum bearings. Drum bearing failure is common on many washing machines due to water getting into them if the drum bearing seal fails. (Hotpoint and Zanussi in particular in my experience) To check for drum bearing failure you can take the belt off and spin the drum by hand. If the drum rumbles when spun then the bearings may have gone. There should be a constant rumble all the time the drum is revolving.
  • Another drum bearing failure symptom is excessive up and down play in the drum which can be checked for by lifting the drum up and down from the drum lip behind the door seal. A further symptom of drum bearing failure can be a brown rust patch underneath the washing machine and down the back of the outer drum, underneath the drum pulley (where the belt goes) although this patch is not always present. There are usually two small holes at the back of the drum bearings where water that has got past the drum bearing seal trickles out, and it's usually stained with grease and rust if water has got into the bearings.
  • Loud noises when turning the drum by hand can also be caused if the drum itself splits, or the spider at the back of the drum has come away from the drum, is corroded or even broken. This would normally be a loud noise on each revolution of the drum whereas the noise when drum bearings have gone is constant all the time the drum is turning. Lifting the drum checking for excessive play can often reveal a broken or loose drum spider which sometimes only occurs at certain points round the drum (the spider has three arms and is bolted to the drum at three points)
  • Coins or other obstructions trapped inside the tub under the drum can make horrendous noises as they get tossed about on spin. They often don't make the noise unless laundry is in though. Look out for obvious dints and creases in the drum itself as evidence of a coin or similar stuck inside although be aware that it only shows there's been an obstruction in at some point and the coin could have fallen into the sump hose or filter and not actually be the cause of the noise at this time
  • Other causes of a noisy washing machine are coins and other obstructions inside the water pump. This will cause noise when the washing machine is emptying the water. Coins or other obstructions can get trapped between the outer tub and the inner drum. This would produce a lot of noise on spin as the coins get tossed around inside. Often, spinning the drum by hand will not reproduce the noise in the case of coins because the coins drop to the bottom of the tub and lay flat when the washing machine isn't spinning
  • A light scraping or ratchety noise when the drum is turned by hand is commonly a bra wire trapped between the tub and drum. They can often be removed from underneath with the sump hose taken off. It's always worth checking that the wire isn't poking through one of the holes in the drum which can be pulled back out from inside the door. It's rare, but I've retrieved 3 or 4 this way over the years.
  • A high pitched squealing or harsh noise can be motor bearing wear. This can also be checked for by taking the belt off and running the motor alone.
  • A knocking noise can be a loose tub weight. This would normally be worse with heavy loads and would not be present on spin with no washing in. This is because the knocking noise is caused when the tub (or outer drum) shakes about on spin. Without washing inside the drum the tub doesn't move. Another symptom of a loose tub weight is grey concrete dust under the washing machine. Warning: These days most washing machines have plastic tubs and over tightening a tub weight bolt can easily shear the bracket resulting in a new tub being required. Try loctite. Often, once a tub weight has come loose the plastic tub is damaged anyway especially if it isn't caught early enough
  • Sometimes a badly worn drive belt can cause a surprising amount of noise. I've even come across some where i was convinced the drum bearings were gone until I took off the belt and spun the drum by hand to find no noise.
It's very tempting to ignore noises while the washing machine is still otherwise working. Some noises can be ignored as they will not develop into serious faults. Other noises, if left, will cause extensive damage and can end up costing considerably more than if tackled early or these days writing the washing machine off. Of course the problem is that you can't tell which of the categories a noise falls into - so ignore them at your own risk.
Apr 06, 2010 | LG WM-2277HW Front Load Washer
WM1285FHD ITNTELLIWASHER DD WHILE SPINNING THE DRUM IS MAKING A TERRIBLE NOISE LIKE SOMTHING IS RUBBING ON IT,EVERYTHING ELSE IS FINE.SHAEON IN SUFFOLK
Sorry Shaeon, it's likely that the spin bearings have collapsed (This info comes from Aust). If the drum is loose, that's your problem.. Very common demise of F/L machines
Mar 21, 2010 | LG Washing Machines
Drum makes loud noise when spinning
HI thanks for the question. Frigidaire has a life time warranty. on that part .call them. thanks the appliance doc. please rate my answer. thanks.
Apr 29, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
