Question about Microwave Ovens
Hi i have micro/grill model no rhm2013,its stopped heating up and is showing a red light,looks like half moons ?
3 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: My LG MICROWAVE OVEN IS MODEL
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Posted on Feb 25, 2011
SD Tech
  • 14553 Answers
SOURCE: panasonic microwave grill not working
I would call customer service with the model number to see if this is a known issue. You might also call a authorized Panasonic repair center and chat with them to get some idea of what a possible repair might cost.
Posted on Dec 04, 2012
Jenn-air combo micro and oven
need to open the unit up and look for a fuse to be blown..
Jan 08, 2014 | Microwave Ovens
Panasonic microwave grill not working
Dec 04, 2012 | Microwave Ovens
The interior bulb of my ge spacemaker oven jvm1490sh01 has blown out. How do I go about replacing it? Thanks
HI,
I looked up your model and found that if you remove the grill above the door, you can ***** the bulb area. With the grill removed, in the middle left side, you will see either a black or metal looking cover, if I remember correctly you slide the cover back toward the wall and lift up. There is where your bulb should be.
If you would like unplug the micro way before you enter this area for safety only. I normally don't but I know what I am looking for.
Good luck, be safe
Jul 23, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My LG MICROWAVE OVEN IS MODEL MC-7836M CONVECTION MICRO GRILL IT IS RUNNING BUT NOT HEATING and GRILL ALSO NOT WORKING
heatman101
Jul 27, 2010 | LG LRM1230W Microwave Oven
I have a WHirlpool Hood/Micro combo MH7140XFB-0. The micro portion has quit working -- lights, exhaust fan and clock still work. Turntable in micro turns but it doesn't heat and makes a funny noise.
Did your cooktop lights fail recently? If so, then the circuit board may have been damaged by a surge. We can probably repair that for you.
Otherwise, I would suspect a shorted high voltage diode or bad magnetron.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden behind the grille, which is very helpful when troubleshooting, testing, and locating components.
mini_manual_behind_grille_small.jpgAt our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find your mini-manual, or if you want to look at it before removing the controller, you can download it here.
You can find helpful exploded view diagrams and order parts by entering your full model number (as MH7140XFB0) here.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
(if it's not shorted or burned, it's probably okay)
http://www.gallawa.com/microtech/mag_test.html
May 26, 2010 | Whirlpool Microwave Ovens
Jenn-Air Microwave vent grill opens and closes
I have this same problem occasionally. Pull the vent grill open and look for a white cam that rotates when the microwave is on. To the right of that cam, there are two gray switches. The bottom switch should have a red tab that pops out. When the vent grill opens and closes continuously, the red tab is stuck in. Take a flat screwdriver or tooth pick and push gently in on the red tab to release it. It must get stuck due to grease or dirt accumulation. Good luck.
Apr 20, 2010 | Jenn-Air JMV8166B 950 Watts Convection /...
Ge convection micro combination has a problem with convection fan . fan runs for about 5 seconds, rattles, then stops. heat element gets red hot but little heat inide oven. replace fan motor or maybe more?...
I would say the convection fan blade is loose on the shaft.
If this is the case, it would try to run, but no cooling would take place, so the heat from the heating element would get very high but it would not be distributed through the oven.
The thermistor would then detect the extra high heat and stop it, I assume.
You may be able to use super glue or JB Weld to fix the blade on the shaft, as long as they are clean and dry and it is allowed to set overnight.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
Accessing these components for testing and possible replacement will require you to remove the oven from the wall and take off the outer cover.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
Jul 11, 2009 | GE Monogram ZE2160SF Convection /...
Can't remove the vent grill
Two problems found. The electrician that installed the micro. installed it incorrectly. The fan was supposed to be turned so that the exhaust would go through the pre-installed duct in the wall. To remove the grill, there is two screws on top of the micro. which have to be removed. The builder put in a deeper cabinet that covers the screws because it looks better. To fix it I have to drop the micro, take off the grill, clean it and all the grease off the micro., replace the charcoal filter, turn the fan so it will exhaust through the duct and reinstall the micro.
May 27, 2009 | Kenmore 80412 Microwave Oven
Microwave made a loud pop,won't heat,sounds like it's only on half power, makes a low intermittent hum
This is almost certainly a blown high voltage diode.
Please reply back with your brand and model number so we can help you.
May 31, 2008 | Microwave Ovens
Microwave Ovens Logo
16 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
