Question about Kenmore Washing Machines
Kenmore washing machine big troubles?
My washing machine is a Kenmore OasisHE and since many years we had some troubles with. It's always appears some various errors and always having a *bip* in continue. I wonder if someone know why? This morning the washing machine have 3 bip in continue, loss water and 3 anothers bip, after that the machine start to bip each minutes. I use it yesterday morning and everything was fine, but this morning for no reason (I was not use it at 5 am) the machine start to doing that. When I approch the machine the main button was flashing and the board show 2 and F2. Somebody know was it's the problem? When we want to start it today, she don't want, she don't work..
  • Kenmore Master
  • 15,557 Answers
Please list the model number of that machine. IT could be made by several manufacturers for Sears.
Posted on Mar 17, 2014
SOURCE: Kenmore Front Loader stuck in "LOC" and every button produces "ERR"
Look for the 2 buttons on your that have a lock symbol.  Pushing & hold both for 3 seconds.  This toggles the child proof mode.
Posted on Oct 15, 2007
jyackle5
  • 8197 Answers
SOURCE: Kenmore Elite He3t front load washer - error code reads H & F
the F code is a puwer outige. This is how to fix
Select PAUSE/CANCEL twice to cancel the cycle. Select
DRAIN & SPIN if there is excessive water in the washer.
Re-select cycle and press START. If the problem remains, call
for service.
This is what an HF code is.
"FH" (Water Inlet Problem--no water or insufficient water
supply)
Select PAUSE/CANCEL twice to cancel the cycle. Unplug
washer or disconnect power.
Check the following:
Are water faucets completely turned on?
Are screens at inlet hose connection to washer clogged?
Are water inlet hoses kinked?
Are water inlet hoses frozen?
Plug in washer or reconnect power. Re-select cycle and press
START. If the problem remains, call for service.
Posted on Dec 17, 2008
SOURCE: F2 error code on my Kenmore Elite HE3 washer
Had this problem on our Kenmore machine.
This is what done.
1. Unplug the washer
2. Take of the toe panel in the front by removing the three screws.
3. Get a bunch of towels (I mean a bunch!!!)
4. The pump is in the center, and it has a plastic grip handle that one can unscrew to remove the filter. As you unscrew it, LOTS of water will come out. Be ready with the towels. A cookie sheet helps to collect the water too.
5. Clean the filter assembly.
6. If one wishes to check the inlet of the pump, remove the back panel, about 12 screws. (Note, the following works for replace the pump as well)
7. Remove the large bellow from the bottom of the tub that goets to inlet of the pump by removing the clamp
9. Lift up on the plastic cover that covers the wires that power the pump. There may be a small plastic catch that is lifted up as to allow the connector to become free.
8. Remove the Torx screw that holds that is the center just under the filter screen.
9. Pull the pump forward.
10. Unclamp the pump outlet hose.
11. Remove pump
12. Unclamp the large bellow on the pumps inlet and inspect for debris.
13. Clean pump and fitler w/o getting water on the pump.
14. Install in reverse order. Remember, it is much easire to put the inlet bellow and outlet hose on the pump before you put into the washer
Posted on Jan 11, 2009
Depending on how fritzed your drain pump is this may or may not work. I've been using HE detergent because it is supposed to cause fewer suds. However, apparently is causing more suds than needed. I need to use only a couple tablespoons? If your clothes are not dirty enough for the soap to grab onto then extra suds are the result. The repair guy said we had an excessive amount of suds in the system and this affects the sensor and causes the drain pump to run and run and run until it shuts off from overheating. This is why we get the F2 and/or suds error code. He said once a month run the machine on the hottest water cycle with a cup of bleach (no clothes). This will clear out any suds build-up and is cheaper than Afresh which works, too, (but smells cleaner than bleach). After sitting for a day our pump started working again (yay!) It also stopped making the horrible loud sound. So glad I do not have to replace the pump!! yet...(knock on wood!).
Posted on May 13, 2009
  • 105 Answers
SOURCE: I have got Indesit WIXL 123 washing machine. Until
i had the same problem its the motor you need a new one luckly my father inlaw is a scrap collector and i come across a spare washer and salvaged all the parts and i tried plugging a new circuit board but still the same so i tried changing the door lock mechanisim but still the same, so itried just for the hell of it the motor and weyhey we have life i thought the motor was the most unlikely thing to cause the problem but im happy but for how long? next year will replace it with new washer.
Posted on Nov 29, 2009
Would i by any chance be able to get replacement parts for my 1978 kenmore washing machine?
call a kenwood service agent and ask but as most manufacturers stop supplying parts after 5 years , I think that it is a big ask
Jul 09, 2016 | Kenmore Washing Machines
I have a kenmore elite oasishe washer and it keeps setting off messages that I am not sure the meaning of. It finished washing the other day and it had hc on the machine what does this mean?
This HC error code will appear at the end of the wash cycle to indicate that the hot and cold water inlet hoses are switched.
If the hoses are not switched it could indicate a problem with the Electronic Control Board.
You can try to rest the washer by unplugging or flipping the breaker to the washer fo 2-5 min.
Restore power to the washer and try running a short cycle.
This will help clear any irregularities that the control board may have encountered.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 21, 2010 | Kenmore Elite 45986 Front Load Washer
My kenmore elite washing machine have a problem on spinning and washing it always stack.
It appears your clutch assembly has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
May 20, 2010 | Kenmore Elite 45986 Front Load Washer
I keep getting a code F1 on my OasisHE. It only
The F1 error code on this washer indicates a Primary Control Board failure.
It is likely that the machine control board will need to be replaced to correct this problem.
The part number for the machine control board is undetermineable because you have not provided me with the exact model # of your washer.
The procedure for replacing the machine control board is provided HERE
LINK: http://media.fotki.com/1_p,wfgstgtftbtkrrdxgtqsskgwtqkq,vi/gfsfgfsgqxgfqtqtgwf/1/1303472/5961857/image55806img-or.gif
NOTE: Be sure to unplug the washer to disconnect electrical power before accessing internal components.
There is a slight possibility that a problem with the pressure switch hose could be causing this problem.
A pinched or twisted air hose can cause this fault code.
When you open the console, check the air hose connected to the pressure switch on the machine control board.
If it is pinched or crimped, I recommend rerouting the hose to resolve this problem.
This may fix your problem without replacing the control board.
NOTE: You may want to check for this condition before ordering the control board. Most electronic control boards cannot be returned for a refund or credit.
If you find no apparent problems with the air hose on the pressure switch, then replacing the machine control board on this washer should correct your problem. There is a risk involved in replacing this part yourself.
As noted above, you could have a problem with the air pressure hose that is not apparent upon your initial inspection. A service technician would normally need to properly and thoroughly diagnose this problem before replacing the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Sep 11, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Doesn't always go to spin cycle....sometimes stuck on drain.
It appears your timer/main controller has failed in this instance.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!!!!!!!!!!!!!!!!!!!!
Mar 14, 2009 | Kenmore 43142 Front Load Washer
Kenmore Elite HE3t door leaking (Model 44936)??
If the unit leaks during use with a constant drip from the 6 o'clock location between the seal and the glass on the door the solution is to change tha door seal. it is quite difficult to do I would recommend you call a local service company.
Dec 16, 2008 | Kenmore Elite 45986 Front Load Washer
11082683310 kenmore washer leaking
your outer tub seal is leaking,it is a big job to replace,let me know if you want to tackle it-mike
Nov 03, 2008 | Kenmore Washing Machines
Washing Machines Logo
37 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
