Question about Hamilton Beach Beach 87108 Microwave Oven
Micro board is burnt up
The micoboard on my 900 watt HB microwave is burning up and it causing burn marks inside the microwave is there anywhere I can buy one?
  • Hamilton Beach Master
  • 932 Answers
Anthony, I have purchased what they call wave guide material from a company called QB Products. You can try Google to find if there is someone close to you that might have what you need. Catalog that I have is old but the number for the smallest size they list is 40QBP1012. That is for a piece 10" x 12". Hope this helps you. Make sure that when you take out the old cover that you clean the area underneath because what causes the burning is grease and food particles that get splattered up there and they get very hot and start causing the burning that you see.
Posted on Mar 17, 2014
NN-CT552 combi. What caused two burn marks On top of the door and on the frame?
The inside of a microwave oven has a special paint on it. If the paint becomes damaged, the microwaves strike the bare metal and arc. This leaves a burn mark. It will also ruin the magnetron inside the oven.
Jan 23, 2016 | Panasonic Microwave Ovens
My 1000 watt microwave gave off electrical burning smell then stopped working
check inside after removing power... look for melted plastic or burn spot inside.. bad fuse or wire connector.. replace as needed
Apr 09, 2014 | Hamilton Beach Microwave Ovens
Loud boom and burning smell in microwave
Is there any holes burnt into the liner inside the micro wave.? Or burn spots showing.? If there is thow it out. It is not safe to be useing it.It could start on fire. That problem is from when they are not clean out once in a while. End food is burn,t onto the interior liner end grease end oil,
Oct 22, 2012 | Sharp KB6001NS 24 Inch Microwave Drawer...
Hamilton Beach hb-p90d23al-dj keeps blowing fuses
If the microwave oven is less than 7 years old the problem is in the magnetron, " the most expensive part " or the inverter board, either way costly adventure, good for target practice.
Aug 13, 2012 | Hamilton Beach Hb-P90d23al-Dj Microwave...
When I turn on microwave oven fuse is burn out right a way. Thank you
Fuses burn for a reason: because the circuit is being overloaded. There could be several causes, first determine what else goes off when the fuse blows. All of the things that go off when the fuse is removed/blown/burnt are on the same circuit. A microwave is a heavy load, somewhere between 750 watts and 2000 watts, depending on the microwave. Remove other heavy loads (items which use lots of power) from the circuit. A 15 amp 120 volt circuit in a residence is good for 1800 watts (or 1440 watts continuously). If you had a 1500 watt microwave and four 100 watt light bulbs on the same circuit, you would be overloading the circuit. With a microwave, it is best to have it on its own circuit with nothing else (if possible). The fuse may also blow or burn in this situation if there is a problem with the microwave.
Oct 05, 2011 | Microwave Ovens
Arcing inside and there is now a small hole on the panel side. Is this fixable?
It looks like there's lightning (arcing) inside my microwave When you see arcing inside your microwave, it's because of food or liquid left in the cavity or on the wave-guide cover:
  • If the wave guide has any burn spots, replace it and clean the unit well.
  • If the cavity has any burn spots, spot-sand it smooth and touch it up with microwave interior paint.
Note… If there are any burn holes in the cavity, don't use the unit-seek help from a qualified appliance repair technician.
Thanks for contacting Fixya
Jun 20, 2009 | Microwave Ovens
Sparks, noise and burning smell
If it is burning and arcing at the antenna, it is probably arcing in the wave guide area. Probably will have to replace unit. I have had some success by removing the antenna, sanding and repainting the burnt areas of the cavity and sanding off any burnt marks on the antenna. Need to look at top of mag to see if also arcing there too.
Jun 16, 2017 | Panasonic NN-2555A Microwave Oven
The silver cover got a burn spot on it
Because the silver piece had a burn hole in it and the opening that it covered also had a burn mark, I bought a new one.
Oct 07, 2008 | Emerson MW8102SS 1100 Watts Microwave Oven
Microwave
A microwave needs all those surfaces to be fully reflective. those scorch marks greatly affect the magnetron. it will soon burn out . reccommend a new microwave.
Feb 17, 2008 | Microwave Ovens
Hamilton Beach Beach 87108 Microwave Oven Logo
80 people viewed this question
Top Hamilton Beach Microwave Ovens Experts
Are you a Hamilton Beach Microwave Oven Expert? Answer questions, earn points and help others
