Question about GPX KCL8806DT 7 in. Portable Television
Can not find tv setup mode in my menu
Unable to set my tv signals
I have a Ferguson F2620LVD TV, Unable to reset tv to original state, when purchased
SYSTEM SETUP 1.In Stop mode, press the SETUP button. 2.Use the or button to select the System Setup option. 3.Press the button to highlight the Default. 4.Use the or button to select the desired setup option. 5.To exit the SETUP MENU and return to the normal screen, highlight the Exit Setup Mode ( ) and press the ENTER/ OK button.
Default It takes 3-5 seconds to reset the unit to the factory default
Nov 02, 2016 | Televison & Video
Setup the wrong language during the initial setup process. Device will not let me go back and correct the issue. Need to know how to redo the language selection part of the setup mode. The device is no...
Press and hold the Play button until the player turns on.
After the Welcome screen the Main Menu will appear.
Press the PREV/NEXT button to select the Setting mode.
Briefly press the Menu mode button to enter the Setting mode in order to view or change the setup of your system.
Select the [EN] icon (the first icon on the first row).
Dec 29, 2011 | Audio Players & Recorders
I have an RCA F27442 TV without G-link cables and need to select cable tv channel input. The setup routine will not allow selecting cable channel input unless I first set up G-link. Is there any other way...
Yes, enter the menu. Look for signal source (ant/cable) select cable. Then run channel scan. This is an older TV and will require some time for the system to scan the cable channels and adjust. The process could take up to 20 min. Do not disrupt. Wait fo unit the TV is completed the process. If you have the operations manuel, the step by step for this process is posted.
Please note this TV is only capable of process NTSC TV signals. If the cable company you are using is supply Digital or Quam or ATSC type signals then the TV just won't work.
G-link can be turned off through the menu. You should see that selection in the first or second page of the set up menu. G-link is for TV guide and record setup for VCR operation. The TV guide should also be set to off or "no" in the same setup menu. You MUST got through the complete setup menu in order for the TV Guide not to try to operate each time you turn on the TV.
Feb 18, 2011 | RCA F27442 27" TV
I am having trouble recieving over the air digital signals. I have connected a 20 db amplified FM/UHF/VHF antenna to the cable/antenna coax connection, set the input to "TV", and set the TV to...
I believe you have probably selected the wrong TV mode. It seems that you have set the TV to analog mode. It is common for the digital tuning option to be greyed out in analog mode and only becomes available in digital mode. Look for a button on your Sharp remote labelled "DTV" or "DIGITAL" and press this, then open the menu and try the digital setup again. If you don't have one of these buttons, look for a button labelled "INPUT" or "SOURCE" and look for an input or mode called digital or DTV.
I will check on the exact method for your TV and post back with the details shortly.
Regards,
BElectric.
Feb 10, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
I have a cable coming from the wall, and when I hooked it up to my TV Panaconic 42'' viera Just bought the TV today. . the screen is black and keeps saying No signal.... what could the problem be? Just had...
You either set the options incorrectly when running the "First Time Setup" or you skipped the first time setup entirely. Even though the cable works with your older TV, you still need to setup your new TV correctly to receive the cable feed.
The quickest way to do this is run the setup manually from the menu as follows:
1. Turn the TV on
2. Press the "MENU" button on the remote
3. Use the DOWN arrow key to highlight "SETUP" (the arrows are the big ring button around "OK")
4. Press "OK" to enter the SETUP MENU
5. Use the DOWN arrow key to highlight "PROGRAM CHANNEL"
6. Press "OK" to enter the PROGRAM CHANNEL MENU
7. Use the LEFT/RIGHT arrow key to ensure "CABLE" is highlighted
9. Use the DOWN arrow key to highlight "AUTO"
10. Press "OK" to enter the AUTO SCAN MENU
11. Highlight "ALL CHANNELS" using the UP/DOWN arrows
12. Press "OK" to start the AUTO SCAN
The scan may take several minutes to complete.
13. Highlight "APPLY" using the the LEFT/RIGHT arrow keys.
14. Press "OK" - all of the scanned channels will now be saved.
The TV should now return to viewing mode and you should be able to watch cable on your new TV. If the TV does not automatically exit the menu, simply press the "EXIT" key on the remote, next to the MENU button.
Please run through the above steps and if you are still unable to get the cable channels on your new TV, please post back for further assistance.
Regards,
BElectric
Dec 16, 2010 | Panasonic Viera TH-46PZ85U Plasma TV
I have a Yamaha RX V665 and I am unable to change the volume
The volume keys should be working by default, but you may have volume punch through turned on (meaning the remote is sending signals for TV or CABLE volume function no matter what mode you are actually on). To unlock volume control for AUX mode, do the following:
1. Press and release AUX
2. Press and hold SETUP until the remote blinks twice
3. Type 993
4. Press and release VOL-
The remote should blink four times to confirm unlock.
Jun 07, 2010 | Yamaha RX-V663 Receiver
17 in. trutech tv unable to get channels except 2-13
For channel setup you will need to;
1) Connect the signal source to the back of the set.(Antenna or Cable)
2) Go into the TV Menu and select the same signal source you connected to the back.(Antenna or Cable)
3) Go to the auto program/scan menu and run it. This may take a few minutes.
Now the channels may be watched.
Mar 16, 2009 | TruTech PVS31170S1W 17 in. LCD Television
Unable to view setup menu on TV screen
I had this same experience and after hours of attepts to fix it (including the suggestions on this site) I found that the company that installed and set up my system literally disabled the "set up" on the remote so that it could not be changed. To fix this (and/or confirm that this may be your problem) reference page 39, "all reset functions" to reset your remote back to factory settings. As soon as I did this and hit "set-up" -- the set up menu popped up and worked appropriately. Hope this works for you!
Dec 16, 2007 | Denon AVR-3802 Receiver
No signal from either antenea A or B
enter the setup menu and select auto programed function,
Nov 15, 2007 | RCA F38310 38" TV
GPX KCL8806DT 7 in. Portable Television Logo
Top GPX Televison & Video Experts
Jaime Hernandez
Are you a GPX Televison and Video Expert? Answer questions, earn points and help others
