Question about Mtd Garden
Why did both battery cables melt on my MTD mower?
Original problem was mower wouldn't start. Changed the solenoid...mower started but wouldn't shut down using key switch...shut down on it's own when I got off the seat but restarted as soon as I sat down again. Changed solenoid again and battery...started up and could hear clicking noise when seated...continued to run with seat safety switch disengaged as I tried to locate the clicking sound which could be heard anytime there was pressure on the seat. Both battery cables melted before sound could be located but mower continued to run...had to pull the fuse to stop it. Is it possible that the solenoid wires were reversed. Battery was wired correctly. Also noticed the terminal that the red wire was connected to on the solenoid was heat damaged.
  • Mtd Master
  • 1,169 Answers
Quoted Text
  • Both battery cables melted before sound could be located but mower continued to run...had to pull the fuse to stop it. Is it possible that the solenoid wires were reversed. Battery was wired correctly.
The solenoid doesn't care about polarity itself. As for the battery cables being it would have been a dead short to frame ground somewhere along the positive cable.
Posted on Apr 14, 2015
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 188 Answers
You have a dead short between the battery terminals leads so the full power of the battery is running through both leads. Just from your description it wouldn't be the seat frame cutting a battery cable would it?
  • 5 Answers
Ignition switch
Posted on Mar 17, 2014
My yardpro mtd won't start. New battery & solenoid still nothing. I can jump solenoid& dump gas in carb starts and runs till fuel in carb gone.What could b problem and how do I fix it
does it have a fuel shut off solenois on bottom of carb bowl? if it has check to see if its opening by linstening for a click when you turn on ignition,you can also feel it if you touch the carb bowl. But why did you change the battery and solenoid if its a carb/fueling problem??
May 07, 2015 | Mtd Garden
What will cause both battery cables to melt on mower?
Sounds like you hook the new solenoid wrong. Like postive to ground.
Mar 17, 2014 | Mtd Garden
Hi I need some help please my mower wont start I changed the solenoid and still wont start it just makes a clicking sound when I turn the key also the cables battery cables get hot any suggestions
Check to make sure the back of your key switch is clean and free of all dirt. DON'T clean with a wire brush with the battery connected. Either use a plastic bristled brush (stiff) or disconnect the battery. Also, I have seen the stator spike and melt wires together. Cut the zip-ties and pull the black wire isolation tubing off the wires to check for melted wires. Use your sense of smell to help you sniff along the wires and find tbe melt.
Sep 18, 2013 | Garden
I have a Cub cadet LT 1024 which will not start. The solenoid clicks like it is trying and lights will come on but that is only reaction. Battery is brand new and hooked up properly.
solenoid clicks, only tess you the coil is working inside the solenoid. disconnect cable from battery to starter. with ohm meter check for continuty across main terminals of solenoid while holding key to start. if no continuity, solenoid is defective.
Apr 29, 2010 | Oregon Scientific Electric PTO Clutch for...
Mower will not start, battery cgarged up but onlhy
Check all the wiring connections on the starting system. Start at the battery. Both posts. Then, check where the ground goes to the body of the tractor. Make sure it's not rusty and making a good connection. Check the wire from the battery to the solenoid. If worse comes to worse, you can take a jumper cable and go from the battery + side and jump right to the starter post where an electrical cable connects. This will let the engine turn over, but make sure you have the mower in neutral and brakes set, with blades OFF!
Jan 28, 2010 | Mtd LAWN MOWER PART # 683-04163B FRAME...
What can make my MTD riding mower not crank, and melt the negative cable? The starter turns, and tries to start engine, almost made it one time, but within 20 secs or less I can smell burning, and the...
Either you are holding the key in the ON postion too long, or the starter has shorted out, remove starter for repair.
Does the negine turn freely or with alot more effort than before. If the latter then engine may be damaged. Need to check compression and try to turn over by hand without spark plug in.If you cannot turn over by hand, engine damaged.
Jan 26, 2010 | Mtd Garden
Mtd lawn mower trys to start as soon as i hook up battery
Sounds like the starter solenoid is stuck in the start position. Tap it sharply and see if it still does it when you hook up the battery. You'll probably have to replace the solenoid.
Jun 20, 2009 | Mtd Garden
Won't crank--some kind of electrical problem
Disconnect the (battery) starter cable and check with a multimeter the continuity of the starter relay thru the relay terminals which connect the battery to the starter (key will have to be turned to start) -- if you get continuity, it's likely not the relay, but I'm with you, it sure sounds like the relay (solenoid).
P.S. Running a starter directly off a charger is a good way to burn up a charger.
Apr 28, 2009 | Garden
Garden Logo
131 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
