Question about DeLonghi De'Longhi Energy Star174; Approved 40 Pint Dehumidifier - DE400P Dehumidifier
The pump is no longer working on my DP400 40 Pint dehumidifier. What should I do?
For 2 blissful months my DeLonghi DP400 40-Pint dehumidifier faithfully pumped the water into the drain.  Then about 2 weeks ago, I started to hear this beeping sound.  I discovered that the bucket was full, so I emptied it.  In 2days  it was full and beeping again.  I've searched high and low and cannot locate my owner's manual to determine how to get the pump working again.  I've searched on-line for a manual without success.  Can anyone help me figure out how to get the pump working and where to locate a manual on-line, so that I can return to that blissful state again?
Thank you!
  • Anonymous Dec 09, 2007
    My pump worked fine for about 2 years then stopped and makes a very loud grinding noise if I try to turn it on. I also cannot find my manual. Anyone have any suggestions?
  • Happy41 Feb 24, 2008
    I have a DeLonghi Dehumidifer CF80M. I was putting the tray back in after emptying and it got stuck! When I tried to put it back in again it was with some difficulty. It seems a small silver piece may be bent? Although it's working i.e. has power - there's no longer any water collecting.
    Can you advise?
    jan from sydney
SOURCE: water bucket
If yours has a button/switch to turn on a pump, that will redirect the water to the drain. Sllee
Posted on Aug 01, 2008
  • 161 Answers
SOURCE: Bucket fills but unit will not stop dehumidifying.
probably a bad switch at the float assembly...check that out....probably going o have to replace that. check also for loose or disconnected wiring at the switch. let me know what happens
Posted on Oct 01, 2008
  • 2976 Answers
SOURCE: I have a 45 pint
It's for when you dump the bucket. You put the cup in to catch the drips while you're dumping it.
Posted on Jan 31, 2009
  • 37 Answers
SOURCE: 50 pint dehumidifier has drain hose connected but
safety switch is turning off the need to drain out the bucket more often....or put the drain hose into an actual drain....ive seen some people run a small plastic hose from the dehumidifier to the sump pump hole in their basement.
Posted on Jan 27, 2010
  • 43501 Answers
SOURCE: How do I empty my frigidaire 70-pint dehumidifier?
Here is a tip that I wrote to help people with just that dehumidifier problem..
Dehumidifier2_bing.gif Problem It shows Bucket Full
Posted on May 15, 2010
Need for a home dehumidifier for a 120 square meters space
normall you will need one pint of water for each 1,000 cubic feed of space in your . . example. 2,000 square foot with 8 foot ceiling would contain some 16,000 cubic feet. = 16 pint per day capcity to dehumidify the area.
God bless you
Oct 29, 2013 | DeLonghi DH100P Dehumidifier
I need the intruction manual for Delonghi dehumidifier model #DE40P.
Here is a link to the Owner's Manual, you're looking for. You can download and print the manual for future reference. Take good care of your model, perform routine maintenance, as required. As it no longer in manufacture. It has been replaced with a 45 pint unit. However, some parts your model are still available, if needed.
Hope this helped you.
Jul 11, 2011 | DeLonghi DE40P Dehumidifier
Does not dehumidify
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
Oct 04, 2010 | DeLonghi 40-Pint Dehumidifier Dehumidifier
Our delonghi de400p dehumidifier shows an E3 error message. Customer Service says its a sensor but can't tell us what sensor. Any help would be appreciated.
I have a 40 pint and a 50 pint that are very similar. The 40 pint has the e3 error. Experimenting with the 50 pint, I found if I disconnected a particular sensor I got the e3 error. That sensor is a little can with two black wires (smaller than a AAA battery but shaped like that). It is attached to the cooling coils so must be a temperature sensor. This is not the little circuit board sensor mounted in the middle of the radiator in a plastic box/clip thing.
I am now about to see that part to see if I can replace it.
Jul 09, 2010 | DeLonghi DE400 Dehumidifier
What should I set it at
If there is actual water in the basement, any setting will probably cause the unit to run. I would suggest setting it around 60%, and turn it up as you feel necessary. Hope this helps
Apr 01, 2010 | DeLonghi DE500P Dehumidifier
I need a manual for a 50 pint DeLonghi dehumidifier has a manual for a DE500P this may be close enough to yours
Aug 28, 2009 | DeLonghi DE500 50 pint Dehumidifier...
My 3-month old Delonghi 50 dehumidifier is leaking
Did you find the solution to your delonghi 50 pint issue? We have similar problem and No Manual - we are looking for manual too, any thoughts on where to find that too, please?
Jul 06, 2009 | DeLonghi DE500P Dehumidifier
DeLonghi 50 Pint dehumidifier DE 500P won't turn back on
If it is not responding when you try to activate the shutoff button and are still not recieving an acknowledgement that the bucket is full you may hav a defective shutoff button. Try contacting the Manufacturer and see if you can purchase just the button. This i a common part and the price is usually reasonable. If you feel very technical inclined you can remove the button and touch the 2 wires together simulating a closed contact. The dehumidifier should now acknowledge the bucket is full. If you recieve the notification then the button is bad. If you found this solution helpful please rate it.
Thanks - Tech101
Sep 04, 2007 | Dehumidifiers
Dehumidifiers Logo
85 people viewed this question
Top DeLonghi Dehumidifiers Experts
dennis lewis
Level 1 Expert
Are you a DeLonghi Dehumidifier Expert? Answer questions, earn points and help others
