Question about Kenmore HE2 Plus 3.6 cu. ft. Super Capacity Front Load Washer
Works sometimes sometimes it doesnt.
I have to unplug for a while then it will work for a couple of loads.
  • 29 more comments
  • Jason Bump Mar 17, 2014
    wont drain sometimes either. not plugged and drain hose is not backing up
    Add a Comment.00++
    Add a Comment.
    button stuck sorry
    Add a Comment.
    Add a Comment.
    Add a Comment.
    Add a Comment.
    Add a Comment.
    Add a Comment.
    Add a Comment.
    Add a Comment.
    Add a Comment.
    Add a Comment.
    Add a Comment.
    Add a Comment.
    Add a Comment.
    Add a Comment.
    Add a Comment.
Lg front load doesnt turn on after one full cycle
Sometimes it can be due to the program controller unit hanging. please the mains power, check for filter capacitors might have gone weak, check the wiring to the controller unit.
Jan 02, 2013 | LG WM-2277HW Front Load Washer
Machine turns on but won't start
this means that the door is not shut check to make sure the door button is still there its behind the door on the frame you should see a little black button sticking out if its not there you need a new door switch if its there try pushing the door button a couple times really fast sometimes this button gets stuck if that doesnt work its probably your door lock
Aug 27, 2012 | Kenmore 44102 Front Load Washer
The blinking green lite that wont go off wont allow the tv to come on tv must be reset each time sometime reset works and sometime tv off for days have to unplug from wall for couple days then replug and...
The blinking green lite that wont go off wont allow the tv to come on. We tried resetting the tv it doesn't work Also the tv has been off for days have to unplug from wall for couple days then replug and reset. It still doesn't work. Please help.
Sep 25, 2009 | Televison & Video
37 INCH LCD HD NO PICTURE GREEN LIGHT ON, BUT NO SOUND
CHECK THE FUSE ON THE INVERTER BOARD, IFHIS DOESNT IT SOLVE IT REPLACED THE CAPACITORS, IF STILL SAME PROBLEM, THEN YOUR BACKLIGHTS ARE SHOT, HAVE THEM REPLACED
May 29, 2009 | SNK Magnavox 32MD357B_37 32 in. LCD...
Drive wont power up or down
It sounds like the hardware failed. If it no longer mounts or powers up then I would say the hdd crashed and died. Sorry.
Dec 20, 2008 | Western Digital 500GB My Book World...
TV turns itself off
The solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
I service these power supplies, for more info write to jah2mil@hotmail.com
Dec 08, 2008 | Akai LCT3201TD 32 in. LCD Television
JVC DR-MX1S
This machine has a lot of problems. One thing that often works is to turn it off and unplug it for a couple of minutes. Then plug it in again. Then it will say "loading" for quite a while. Leave it alone until it turns itself on. Then it should be okay. If the couple of minutes doesn't work, sometimes unplugged overnight (same method) works, but then you have to reset everything.
Feb 02, 2008 | JVC DR-MX1S DVD Recorder/VCR
I just recently purchased a G.E. front load washer and dryer. My washer would run a cycle then sit with 1 min remaining on the display. I know this is an estimated time but it would sit like that for a...
No you didnt ruin your washer, in fact that is the only way to reset the electronics. Just like the computer you are on, they sometimes glitch and lock up. Unplugging a washer doesnt harm it. It doesnt have a hard drive. If the washer continues to do this you will need to replace either the main computer or the display board.
Jan 18, 2008 | Washing Machines
Whirlpool LTE5243D Top Load Stacked Dryer heats sometimes and not others
couple things this could be lets start obvious
faulty door switch even though door latches doesnt mean its working properly
bad guages easy to check dont have to run dryer just guages
turn on setting let run threw cycle if it stops on cycle and dont move for a length of time this will be the problem
these 2 things are main causes of why a machine wont work or partcially works at times everything else is easy
Nov 27, 2007 | Whirlpool LTE5243D Top Load Stacked...
Paused. now stuck. cannot open, turn off, etc.
Unpluggin the machine is pretty much the only way to reset it.Leave it unplugged for a couple hours if that doesnt work its most like a control board issue
Mar 15, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore HE2 Plus 3.6 cu. ft. Super Capacity Front Load Washer Logo
19 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
