Question about Shuttle Computer Shuttle Xpc Sn78sh7 Glamor Series Barebones Pc - For Amd Phenom And Athlon Cpu
Replace the bios on xpc glamour
How I can replace a damaged bios with a dead pc ?
What is the fault when the battery light flashes orange (suspect dead batt), also the unit will not boot, nothing from the screen, and the blue power and Wifi lights are illuminated?
1. Suspect dead battery- Your battery might be dead. just replace your battery.
2. Cd-drive spin but cannot run
- solutions is -
1. Please check if the support DVD has been damaged
2. Please check if the external optical DVD drive can work normally
3. Please unplug other USB devices
4. Please disable [Boot Booster] in BIOS
4.1 Start the system and press on bootup to show the POST screen. Press again to enter the BIOS setup.
4.2 Set Boot Booster to [Disabled]
4.3 Press to save the configuration and restart Eee PC.
Alos with other solutions,
ASUSTeK Computer Inc Support Troubleshooting EEE PC 1000HE
Jan 19, 2014 | ASUS Eee PC 1000HE Netbook
Computer wont boot
That sounds like you have a dead hard disk drive if the hard disk drive is dead then you will need to have it replaced there is a way to check if it is dead or not, you will need to go into the bios for most it's usually the hi lighted tab when the bios comes if its dead the hard drive slot should say empty or none if it's not dead it will show the hard drive info
Dec 22, 2012 | Acer Aspire X1200-B1601A PC Desktop
My asus a52f not turn on after bios update it apear to be dead
never change ur bios setting/pdate without the clarification of ur laptop service provider. its better to go to ur laptop service provider before other damages are done.i guess you might have crash ur operating system
Mar 09, 2012 | Computers & Internet
I have a Gateway 840 GM and I have just replaced
At first check the battery that's on you motherboard. The battery powers the bios on your motherboard. The bios detects you push the power button and turns on the pc. If the battery is dead the bios has no power, so it cannot detect you push the power button and will not turn on the pc. So replacing the battery will solve the problem. If the battery is not the problem, I think your motherboards bios is dead. Maybe it can be fixed but you'll have to send it back to the manufacturer I think.
Mar 29, 2010 | Gateway 840GM (RB840GM) PC Desktop
PC CHIP Motherboard
Now by PC chips do u mean CPUs? because if so then yes your motherboard is dead but im not sure if it would be BIOS related. There should be a battery somewhere, one like a wristwatch but bigger and flatter on the motherboard, look for it and replace it and test if it works, otherwise it is most likely your motherboard is dead and you need a new one. There is a way of fixing the BIOS if that is the problem. Its called Force Flashing BIOS. I Don't know too much about this but apparently its not hard. Google It and see what you come up with
Hope This Helps
Oct 22, 2008 | IBM ThinkPad T20 2647 Notebook
Power supply runs, but no bios or boot
yes it sounds as the the cmos bios chip is damaged, if theres no bios showing, you will have to replace the mobo.
Sep 03, 2008 | Dell XPS 200 PC Desktop
Keyboard not functioning
key board dead , correct. ? even the caps lock key will not toggle its led.
my guess is you bought a clone keyboard from china, on fleabay
and its dead. as many are, some are wired wrong.
the ribbon cable on mine fits to a special connector that likes to break easy, is your broken this locking jack there?
is it plugged in upside down?
why did you buy a keyboard. was the other dead.
when did the keyboard fail. list week last year, or never
i bought it for cheap with dead kbd....
there is no HP drivers, HP retired this old PC, after 10 years.
so what makes you sure your non HP drivers are any good.?
NO OS stated, not even a clue. XP?
what I'd do , us boot to a Knoppix v7 live boot(dvd/usbstic)(linux)
if the keyboard fails NOW, then its bad KBD. or the jack cable or connector there, (or inserted wrong) or damage. there.
buffer chip is blown up with ESD events. (electrostatic discharges)
is the keyboard dead in BIOS
on ours we hit ESC or F10 and BIOS screens pop
power on hammer ESC or F10 or what the screen tells you to hit.
the go in to BIOS screens, now test the keyboard.
using say the arrow keys to navigate the BIOS menus
if the ESC and F10 key are dead that is a bad keyboard.
what must work here is the electronics.
  1. correct keyboard, some clones will never work.
  2. cable not damaged
  3. cable not upside down
  4. connector there not damage the lock not broken,(easy)
  5. the MOBO buffer chip not ESD damaged.
  6. BINGO BIOS now works by key commands
Aug 08, 2017 | Compaq Presario Laptop
E Machine
If your not able to get into the bios, your problem may lay there. Since your bios tells your computer how to run (as you probably already know) then it may not be telling your computer how to run. Try testing the battery on your board with a voltage tester, or just buy a new one. Try a few different things and try to get into your bios (like disconnect all drives). If you think your hd is dead, run a hd test with your computer as a slave. You can also try using a program Norton partition magic to scan the drive and see if its alright. (very powerful program). Make sure you do a full scan on it to make sure that its not physically damaged, like the mbr being permanently damaged by the drive becoming unbalanced. Good luck
Oct 02, 2007 | E-Machines eMachines Desktop PC
Shuttle Computer Shuttle Xpc Sn78sh7 Glamor Series Barebones Pc - For Amd Phenom And Athlon Cpu Logo
43 people viewed this question
Top Shuttle Computer Computers & Internet Experts
David Payne
David Payne
Are you a Shuttle Computer Computer and Internet Expert? Answer questions, earn points and help others
