Question about Vornado Heating & Cooling
Static electricity I have had 3 Vornado heaters (Type DVTH) for several years. It is not unusual for me to build up some static electricity on my body, for instance, after folding bed sheets. It is also not unusual for me to unintentionally discharge that static electricity when I touch the controls of one of my 3 heaters. However, I recently had 2 of those heaters freeze in the ON position after I unintentionally discharged some static electricity upon touching the controls of those 2 heaters. So, now the only way for me to turn on or off those 2 heaters is to plug or unplug the power cords. Also, none of the other controls on their control panels work anymore. In other words, both heaters are stuck on LOW and 70 degrees as the target temperature. How can this problem be fixed?
    Scholar:
  • 67 Answers
From what you have said, I am guessing that you shorted out the little controller chip(s) on the circuit board. Some of the Vornado heaters are serviceable by the company but you would have to check your model number. They have a live chat that can tell you if you go to Vornado.com and click on support you will see it.
Posted on Mar 17, 2014
  • 883 Answers
SOURCE: Rheostat vs. Thermostat Temperature Control
yes, it should work. Just ensure your rheostat will handle up to 1500 watts at reasonable settings. A better approach is a 1500 watt pulse-width modulator circuit that draws little power itself. these are available where power tools are sold (like harborfreight.com and known as speed controllers. I use one for a large air fan in my garage.
Posted on Nov 04, 2007
SOURCE: My Vornado TouchStone Vortex heat 500 Heater - temperature
After calling Vornado Corporation, they suggested that the room temperature monitor might be failing as it read 65 degrees no matter where you started the heater. I took the unit back to the store I purchased it from, and we unpacked another unit and found the same problem existed. Therefore, the product is not capable of heating a room properly and I will continue my search for a space heater to control the temperature in my upstairs office which does not have air ducts for heat.
If anyone has recommendations I would be interested in their comments.
Thank you.
Posted on Nov 20, 2008
  • 8 Answers
SOURCE: vornado heater doesn't work on high setting but only at low setting
Dust on the inside of the unit can cause the overload switch to shut many vornados down. Blowing the dust out of the unit with compressed air or a blower may help.
Another problem that causes vornados to stop working (light on - no heat no fan) is when one of the bearings starts to go bad in the unit. This causes the fan to be slower and less effective and the unit’s inability to move the heat away from the thermal overload switch again causes it to shut down.
Though you could remove the front and rear bearings and try to get replacements if it's even replaceable ... Once the bearing starts to go bad there is little that can be done ... HOWEVER, here is one solution to get more life out of the unit.
First, use a blower to blow all the dust out of the unit.
Then, because it is typically the front bearing that goes bad first, lay the vornado on it’s back (so the unit would be blowing air up toward the ceiling), this will relieve the front bearing somewhat and rely more on the rear bearing which tends to last longer.
The vornados I’ve had are all thermistor units ... that is, they don’t just turn on and off when the set temp is reached but in fact slow themselves down (both heat and fan) to keep some level of air circulation in the room. This is a good thing by the way.
There are usually two toggle switches .... one is a heat switch - usually Low & High .... the other is the thermistor switch (this sometimes is labeled “fan”) - usually Auto & High.
Once the unit is on its back ... Now, change the settings as follows:
Turn the Heat switch to LOW
Turn the Fan switch to HIGH
Turn the dial (with the temperature in degrees on it) to the lowest setting - which is somewhere around 60’ish.
Now turn the unit on and it should stay working.
Three things that could cause it to turn back off ...
You turn the Fan switch back to Auto.
You turn the Heat switch back to High
You turn the temperature selection dial too high ... though, you can cautiously turn the dial up a few degrees at a time ... the unit will start shutting down again when you set the temp too high ... then just dial it back down ... unplug for a couple minutes, then turn back on.
Posted on Dec 12, 2008
directcurent
  • 59 Answers
SOURCE: Vornado VH2 stopped working. on/off not functioning
if it is a rocker type switch replace the swich
IMPORTAINT make shure switch it is replaced with is rated at 15Amps
Posted on Jan 19, 2009
  • 126 Answers
SOURCE: control panel not working after "function lock" buttons pressed
MD,
Hit the up and down again and do away with the Function Lock.
Tom
Posted on Apr 24, 2009
Vornadofan electrical wiring. Old fan runs strong but replaced the wiring and now need to check which wires are what...can not find on vornado website, not in manuals either.
Good luck there. Vornado is very vague and does not disclose any information. If it is a vintage vornado, you can type the model number into the search box, hit images and they have a few showing the wiring.
Jul 22, 2017 | Vornado Dryers
I have a bodyguard t260 treadmill and when I run on it there is a great deal of static electricity that shocks me when I touch the treadmill handles
The shock is a build up of static electricity on your body called Electrostatic Discharge (ESD). Friction between the walking board and belt can generate static electricity.
If experienced, the shock is not harmful or dangerous.
Nov 11, 2011 | Exercise & Fitness
Where do I find model number or serial number?I turned off main water valve to replace a leaking pipe and now I can't turn on the water heater. How do I do it?
1) You posted under Bosch tankless water heater.
There should be a nameplate on front of unit or located where you can see it.
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/2400ESTechSupport/Troubleshooting/tabid/1295/Default.aspx
Bosch problems at Fixya:
http://www.fixya.com/support/p949576-bosch_1600h_lp_liquid_propane_aquastar_a/solutions
Bosch has online tech support form:
http://forms.boschhotwater.com/Home/BoschTechSupportForm/tabid/614/Default.aspx
2) Replacing water valve probably loosened build-up inside pipe that lodged in water heater or inside elbow just beneath tankless unit.
If water flow is stopped or slowed, tankless will not operate.
3) Remove pipes and see if clog can be flushed.
4) Also U-tupe search "delime tankless water heater" and technique used for deliming will be good way to clear out tankless clog and sediment.
Your tankless should be delimed each year anyway.
5) Read your manual cover to cover, and see words 'troubleshoot' and 'maintenance' are used throughout manual. Get acquainted with your water heater and manual, because tankless are maintenance heavy, especially if conditions are not optimal and as unit ages.
6) All costs are energy. Install tank type water heater for ez do-it-yourself repairs and maintenance.
Tank type work under all types of adverse conditions and water pressures and water conditions, and even withstand sediment build-up for several years. Of course tank-type pipes can clog too.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 08, 2011 | Bosch PowerStar AE125 AE125 Whole House...
My vornado heater stopped working.
vornado tv 500 work 2 minutes and stop forever
Feb 01, 2011 | Vornado EH1-0014-01 Compact Heater
I have a Vornado TVH600. The heating coil does not heat up; the fan is working. The heater has only been used for a couple of hours--worked fine and then one day simply stopped heating.
Sounds like you got a lemon. Contact Vornado Customer Service - the TVH600 comes with a 5 year warranty that covers all costs associated with replacing or repairing the heater. They even pay for shipping costs as long as the unit is still under warranty. Just give the rep the serial number on the bottom of your product. The number is 1-800-234-0604. When you call, you'll actually get a real person, and the support team is very pleasant and helpful. Good luck with your heater!
Dec 10, 2010 | Vornado TVH600 Electric Heater
Vornado dvth lights are on but no fan
I would call Vornado at 1-800-234-0604. They have great customer service- and usually have really good warranties with their products. I bet they can get you figured out. Any time I have had any questions, they have been very helpful. Vornado is also on Twitter, by the way - so if you "tweet" then some people ask questions via twitter too. I have always had good luck with their fans...
Mar 01, 2009 | Vornado DVTH Compact Heater
Rth230b honeywell display screen faint
Mike, The static electrical spark probably 'zapped' the Rth230b Honeywell Display unit. If you have already tried removing the power (batteries) from the unit and after waiting several minutes; reapply the power (batteries). If the problems remain unchanged, then it is time to replace the Display unit with a new one. The static electricity problem is problematic and the only way to prevent the same problem from recurring is to discharge yourself before touching the Honeywell Display. As you walk across the room which (probably has carpet), causes the static electricity to build up on your body and then discharges itself through the Display unit when you make contact with the Display unit. You might try coming to a complete stop and attempt to discharge the static charge on your body by touching the wall first with one hand for a second before touching the Display unit with the other hand. Naturally, cold weather with low humidity makes the static electricity worse. Hopes this helps you. Henry
Feb 04, 2009 | Honeywell Programmable Thermostat Heater
Jan 08, 2009 | Vornado VH2 Compact Heater
Heating & Cooling Logo
114 people viewed this question
Top Vornado Heating & Cooling Experts
Bill Long
Lyle Siemens
Lyle Siemens
Roberto Lopez
Level 1 Expert
Are you a Vornado Heating and Cooling Expert? Answer questions, earn points and help others
