Question about Panasonic KXDT343 Phone
Changing the Time Displayed
I'm looking at the solution here and it says to start from extension 101. Is that necessary? I work in an office with many phone lines and I don't believe we have an extension 101 or know which phone that might be.
  • 23 Answers
Press intercom and dial 101, see which extension rings. That's 101
Posted on May 01, 2014
  • 6 Answers
SOURCE: Change my display name
This is how I did it:
1. Press the 'Program' button 2. Then dial ** (star, star) 3. Enter the password (usually 1234) 4. Press 'Next' until you get to 'Ext Name' 5. Press 'Enter' 6. You will need to know the Extension Number of you phone, when you find out enter it (eg: 104 or whatever yours is) 7. Press 'Clear' to get rid of the old name then start entering the new name via the number keys. Note: If you keep cycling through the letter on each number you can get to lowercase or uppercase letters. 8. Press 'Enter' then you are all done... pick and hang up the handset.
Posted on Feb 12, 2008
cnavarro
  • 2460 Answers
SOURCE: main line shows solid red light
Fast fix is to turn off the power on the cabinet and power it back up.
Carl
Posted on Sep 09, 2008
cnavarro
  • 2460 Answers
SOURCE: Can not pick up line on incoming calls from one extension only
That's what happens when you plug in the system and don't program it. You need to review ICD groups.
By default, the phone connected to the first extension is the master phone and the only phone that rings.
Carl
Posted on Sep 12, 2008
SOURCE: Changing names assigned to extension numbers
I just worked it out.
Press Program
Then **
followed by your passcode (usually 1234)
Then 004
Then press next till you find Mark
Press Shift then the button under Clr
Then enter the name so for Claire start with 2 and swing the jog button round till you get a C, then press 5 and swing the jog button round till you get an l etc..
If you make a mistake press Transfer
Then when you've got your name correct press Auto Dial.
Posted on Mar 24, 2009
stwill2326
  • 77 Answers
SOURCE: panasonic phone
This system will have to be programmed to allow line 1 to ring on that particular set. When you pick up line 1 now and it dials out it is dialing the last number you called from the phone.
Posted on May 30, 2009
Trying to change my name displayed on the LCD?
It's a trick. When we install Panasonic TDx systems, you have to give the phone users access to programming. If your installer gave you access, you can press PROG and dial **1234 and the system will let you into programming. By default, extension can usually do it, in our case, we allow it on all phones.
If you find the phone that can dial PROG ** (it won't beep at you when you start the sequence), program 004 is extension names. Dial it, press ENTER twice (it moves from softkey 3 to 4) and you'll be looking at extension 101 and a name if programmed. The NEXT key scrolls through the extensions and the keypad pressed X times to get to the letter and the right arrow key to step forward if you need to press the same number key steps you forward. The round ENTER key saves the new name, then pick up the handset and drop it back down to exit programming.
Carl
Jul 01, 2011 | Panasonic KX-T7630 Corded Phone
I am also trying to change the extension names but for some reason when I press program the only thing that shows up is "Program No?" what do i do next?
Start by pressing ** and see what the display shows. If it doesn't show anything but beeps, then you have the wrong phone. Try looking for extension 101 or the first phone in the system.
When you find that phone and press program **1234, you'll go into programming. Dial 004 and press ENTER. If you press ENTER again, you'll be looking at extension 101, or you can dial an extension and be looking at a name. Now you spell out the name on the keypad using the letters and the arrow key if necessary and press ENTER (the center of the Navigator button) to store the name. Notice that the 4th time you press a 3 letter ALPHA key, you will get lower case letters. Punctuation is under the 1, * and # keys and Q appears under the 1 and 7 keys :-)
Next steps you to the next extension and you can just pick up the handset and set it back down to end programming.
Carl
Oct 26, 2010 | Panasonic KX-T7633 Corded Phone
How do i change date and time?
Hit program 0 and enter date in YY/MM/DD format. The time should then be displayed. This has to be done from the administrative phone, usually extension 101.
Nov 13, 2009 | Panasonic KX-T7731 Corded Phone
As simple as changing the time.
A 7640 has on display, so it's going to be a tough assignment. I'm guessing it sits next to a 7636 and that DOES have a display.
If it's extension 101 or programming is allowed from that set, press PROG, dial **1234 and ENTER then ENTER (note it changes soft key positions)
You should be looking at program 000 which is the date and time.
The FWD button steps the display forward and the ENTER will save the new time when you're completely done, then, I think you get an EXIT key, or pick up the handset and set it back down to exit.
Carl
Mar 25, 2009 | Panasonic Lands Phones
Office 2007: Windows Installer searches for Office 2000
It looks like a problem with file associations. The computer maintains a list of file extensions and the programs that will open files with such extensions.
Please go to the link below for details on changing file associations:
http://support.microsoft.com/kb/307859
Mar 24, 2009 | Microsoft Office Professional 2007 Full...
The incorrect name being displayed when you use a preset number
The side buttons is programmed as extensions
To change the extension names follow these steps :
If you are using the KX-T7730 phone on a Panasonic KX-Txx 308 or 824 system.
From the Switchboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle/hook :
1. Press PROGRAM * # followed by the system password ( default is 1234).
2. Now press 604 and then SP-PHONE. Enter the jack number you wish to change ( 01 is extension 101, 02 is extension 102 etc. ).
3. Enter the name ( basically the same as texting on a cellphone ). Press AUTO DIAL / STORE to save your change.
4. To go to the next extension press SP-PHONE. Don’t forget to press AUTO DIAL / STORE to save your change after each name entered.
5. Press PROGRAM to exit program mode and you are done.
Jan 12, 2009 | Panasonic KX-T7730 Corded Phone
Changing date on Panasonic KX-T7731
If it is displaying "101:" that is your extension. You can press the * key (with phone on the hook) to scroll your display through date and time formats and to display your extension.
When it says "PITS-PGM NO" you will need to press one of the buttons on the numerical key pad to choose a function to change.
Hope this helps!
Feb 07, 2008 | Panasonic KX-T7731 Corded Phone
Problems with Intercom
Yes, you just need to program those buttons on your phone. Press "feature" then "redial" then press the button you want to program, then press "1" then it's extension # (example: 1-0-0 to program the button for extension 100) then press "feature". After you've programmed those extensions, the intercom should work.
Dec 20, 2007 | NEC Electra Elite DTU 16D-2 Corded Phone
Changing the time on my lucent partner 18D
Press
Feature 00
Left Intercom Twice
Dial #103
Enter Time in Military (14:05 = 2:05 PM)
Feature 00
Oct 29, 2007 | Lucent PARTNER18 Corded Phone
Adding/Changing Name to NEC multi-line phone
On an NEC Elite you must enter system programming to change the name of the extensions. Unless you have a PC connection to the system this is somewhat complicated. If you would like me to step you through the system programming, please contact me @ 850-326-0394.
May 21, 2007 | NEC Electra Elite 32D-1 Corded Phone
Panasonic KXDT343   Phone Logo
205 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
