Cddvdw sn 208bb does not burn stuff on CD-R
It runs perfectly, except for the fact that I cannot burn stuff on CD-R's. At some point it crashes down, and that's it. I have to pick out the battery of the laptop in order to restart.
    Top Expert:
  • Computers & ... Master
  • 26,713 Answers
Faulty burner. The laser can read discs I presume but cannot develop enough power to burn a disc.
Posted on Mar 17, 2014
5 Suggested Answers
SOURCE: DVD burning problem
Hi guys .. it was very simple... Some laptops (such as mine Compaq Presario C755TU) are meant for WINDOWS VISTA .. Certain features will work only with VISTA.. i removed XP and installed VISTA and it's working fine.. life is beautiful again !
Posted on May 26, 2009
  • 5 Answers
SOURCE: I had my laptop formatted because it crashed .
First make sure that all of your updates are current, then reboot. If this does not fix the problems then go into your device manager and uninstall your dvd/cd player and your network adapters, then reboot, This will force your system to reload the drivers for the dvd/cd player and your network adapters.
Posted on Jan 22, 2010
siawolf
  • 749 Answers
SOURCE: My Asus X83Vb is running on Windows 7. The CD
I would install the 64bit vista drivers available for your machine at the asus website. these are made for your machine. there could be several issues with drivers made for other models of motherboards
Posted on Apr 05, 2010
davidmamian
  • 543 Answers
SOURCE: burning cds fine but session will not close any idea what to do?
change your burning programm
Posted on Apr 25, 2012
Why do l have horizoncal the bottom of my tv screen
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Nov 22, 2014 | Samsung samsang slim dvd-rw sn-208bb 8x...
Tsstcorp cddvdw ts-t633a hp touchsmart does not burn music cd
Hi
The most likely cause of this issue is that the CD drive has gone faulty so will require you to replace the unit
Regards
Cliff Cook
MCP
Jun 21, 2014 | HP Computers & Internet
Tsstcorp cddvdw sn 208ab cracking noise and skipping
The cd player needs to be removed to check for blockages or replacing as necessary.
Jan 09, 2014 | Toshiba Satellite Computers & Internet
Probably the drive is failing. The internal clicking indicates the drive is trying to read the disc but can't.
Jan 09, 2014 | Computers & Internet
I have an Acer Extensa 4620Z and I am trying to burn a cd from itunes and am having much difficulty doing so. When I click to burn, it begins to start for about 1 second and then stops with the message:...
The problem with iTunes is that it uses its own/modifies the disc drive driver. What you can try is uninstall iTunes and performing what is called the Upper/Lower Filter Fix. This involves hitting "Start" and then selecting "Run" from the start menu. If that isn't in the Start menu, you can hold the Windows Key and hit 'R'. When the Run dialog box opens, type "regedit" in the box and click "OK" or "Run". This will open the Registry Editor window. Expand HKEY_LOCAL_MACHINE, then SYSTEM, then CurrentControlSet, then Control, then Class. This should reveal a bunch of items with seemingly random characters in their name. Select the top most and arrow down until the item at the top in the right-side column says DVD/CD-ROM Drives. Below that, you should see two potential keys, LowerFilters and UpperFilters. Right-click on these and select Delete. Then, restart, and reinstall iTunes. It should correct the issue.
Aug 27, 2011 | Acer Extensa 4620 Notebook
My samsung SN-124 drive does not read discs. However, the diagnosis told me that it works normally.
Try both of these steps. They should help fix the issue.
Please press the windows key on your keyboard , hold it down, and press R
Type in devmgmt.msc and press enter
If it asks to open, click yes.
Then, you should see a list of devices installed on your computer..
Double left click the cd dvd drive choice to expand it ... Then..
right click on each listing inside the cd dvd section..
And click uninstall.
Once uninstalled. restart the computer, and test the cd drive..
It should now be working in windows normal startup!!
If not, then try the following as well.
Go to the link below.
http://support.microsoft.com/gp/cd_dvd_drive_problems
on the page that comes up. click on the green run now box.
It will start a file download ( this file is perfectly safe as its directly from microsoft)
Once you download the file, make sure to run the file..
It will run a dignostic program that will attempt to repair and fix your broken drive.
KittyTech..
If you need further help, reach me via phone at https://www.6ya.com/expert/carolyn_427ff26936286336
Feb 21, 2011 | Samsung SN 124 (SN-124) Internal 24x...
Dvd icon is shown but does not reads CD/DVD
If you have CD-DVD burning software uninstall it and restart the computer.Open this link and click on run now http://support.microsoft.com/kb/929461
Restart computer again and check
Jul 29, 2010 | Samsung SHS223B DVD±RW Burner
DVD drive doesn't read suddenly...?
IF YOU MADE ANY MOVEMENT OF YOUR COMPUTER YOU MAY HAVE DAMAGED THE READ LED ON YOUR DVD, IF THIS IS THE ONLY DRIVE ON YOUR COMPUTER COSIDER AN ADDITIONAL DRIVE
Feb 21, 2008 | Computers & Internet
Computers & Internet Logo
77 people viewed this question
David Payne
David Payne
