Question about Hoover VHC391 T-80 Dryer
Hoover tumble dryer leaking
The water pump is working with 240v directly applied,so is it the condensor switch?
dididsaythat
  • 291 Answers
SOURCE: Hoover tumble dryer
I think you may have a bad relay on the motor, where power is re-applied after the push start is released
Posted on Oct 14, 2007
SOURCE: I have a hoover Nextra
My nextra has just started to do same thing, does anyone know what is wrong
Posted on Jun 11, 2008
SOURCE: I have a Hoover vision hd b energy condensor dryer
My engineer is coming out, didnt realise i had to pay for this assistance,it made out on the ad that someone was able to help you by giving advice,it didnt state you had to pay, for i thought forget it.
Posted on Aug 27, 2009
hunter19_46m
  • 7482 Answers
SOURCE: The felt seal on my Hoover HNC175 tumble dryer come off.
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Remove the electrical box that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the machine, this will expose the belt and drum, and the felt seal.
You may be able to replace the felt seal at this time, or you may have to buy a new one and install it.
I would also recommend that you do the following while you have gone this far.
Remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Be sure to pay attention to the route of the belt, this will come in handy later when you go to reinstall the belt and drum
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good luck,
I hope this helps
Posted on Oct 19, 2009
wildbear6
  • 192 Answers
SOURCE: Hoover Maxi 6 TC50 Tumble Dryer making squealing noise
Have you fixed this problem? I also have a Hoover condenser dryer, only a few months old, and has started to make a squeal/whistle. I'm thinking it might be the front fan needing some WD40, OR too much water vapour around the belt that moves the drum causing the sounds.
If it's the fan, lubricating the shaft and its components should fix the problem, if a wet fan then I'd think maybe fully cleaning the condenser filter, reservoir ect will fix the problem.
The problem seems to go away though "mostly" 15 or so minutes after you start the dryer, so that makes me think ones it gets warm something is expanding to allow more "give" so maybe the belt.
Posted on Jan 01, 2010
I have a Hoover nextra 6 kg condenser tumble dryer which is leaking water and the collector is empty and seems not to locate fully into the hole at the back?
Check for Lint/Dirt in the Drain and then you need to ensure it is fully connected in the Washer to the Drain...
Jan 03, 2015 | Hoover Dryers
Aug 26, 2009 | Hoover Dryers
Not Pumping water to reservoir
Fixed this problem by removing the back and side panel and simply clearing a build up of fluff from the channel that feeds the water from the condensor unit to the reservoir. To do this I had to open the plastic unit that houses the pump by simply unclicking the top section and clear this and also clear the entire base section. Dryer now not leaking and drying much quicker.
May 16, 2009 | Hotpoint Dryers
Water leaking from back of m/c
You may have accidentally disconnected the pipe which takes water from pump to bottle.
Please post back if any assistance needed to access pump.
Thankyou for using Fixya.
Jan 23, 2009 | Zanussi TC7114W Electric Dryer
My Hoover TC650 condensor dryer has a fault. When turned on it makes a noise (buzz) but the drum does not revolve. If I turn it by hand and then quickly close the door and press the button it will...
i saw your question and never worked on a hoover dryer so i checked it out go here to see video
https://www.how-to-repair.com/help/hoover-candy-tumble-dryer-drum-not-turning-and-belt-ok-faulty-capacitor/
i have to tell you on all the dryers i've ever worked on they never had a cap in them,only washers,on a dryer that isn't a condenser dryer if you get the dreaded buzzing sound and start it like you did,open the door,hold in the door switch and spin the drum with your other hand while someone else pushes in the start button and it would start it would be the motor,i've seen a condenser dryer and the problem always was with the filter,people that had just bought one didn't know you had to clean out the filter box,never took one apart,i saw that nobody answered you so i hope this video helps you out and i learned that condenser dryers have a cap in them.
Dec 30, 2017 | Hoover Dryers
Hoover six tumble dryer runs for about 15 minutes then trips the electrics, condenser has been cleaned and water container is always emptied
usual cause is water being thrown by the fan onto the heater. after this has happened, remove cover over heater and see if water is present.
the water is there because the water path from condensor box to pump housing is blocked with lint
Sep 17, 2008 | Dryers
Hoover tumble dryer
Oct 11, 2007 | Hoover HDC6 Electric Dryer
Hoover VHC391 T-80 Dryer Logo
42 people viewed this question
Top Hoover Dryers Experts
Tim Whalen
John Tripp
John Tripp
Are you a Hoover Dryer Expert? Answer questions, earn points and help others
