My phillips hts8140 soundbar has sound coming out of one speaker and the LED display light is not working The display still works and shows on the screen but the front doesn't light up it is no longer under warranty and I need someone to fix it I live in Milton Keynes Buckinghamshire and I need a local engineer to fix it for me Solutions
wyoed1
  • 211 Answers
SOURCE: Screen went black
I am working on one right now with a similiar problem. The power supply is bad in the one I am working on, and sadly, the part is not made anymore. I hope you have better luck than I am finding the bad component in yours. Sorry for the negitive answer.
Ed
NC Electronic
Mills, Wyoming
Posted on Jan 06, 2008
SOURCE: techwood twp 4205 plasma screen wont work
quick easy fix.
white block style ceramic resistors (2 of) on power board.
go to rs components online
part number 199-7696. pennies each.
replace both resistors.
Done.
Posted on Dec 29, 2008
SOURCE: Can't view local HD with built-in QAM tuner on Sharp Aquos LED
I found this solution at ehow.com and it works: http://www.ehow.com/how_5417083_hd-channels-comcast.html. You'll just have to switch over to another input to view the HD channels.
Posted on Dec 07, 2009
SOURCE: Plasma screen displays horizontal lines
http://www.scribd.com/doc/2893683/PANASONIC-CHASSIS-TH42PHD5-TV-PLASMA-TRAINING
Above is a training manual for your type of set use the troubleshooting and see how you go.
Posted on Apr 29, 2010
  • 8457 Answers
SOURCE: Phillips ambilight TV Flashing red
Check the tv power supply board for those dying parts call copactors.That the board,where the power a/c cord plug into it.These capacitors are alway bulges or puffing up on it tops.U have tools and know basic electronic?Replaced those dying soon to be dead capacitors,will fix the power supply and have stable tv power again and tv will work.Or try website like Ebay.com to buy a whole refurbish power supply board for the replacement.
Posted on Nov 23, 2010
Can't get any sound from it FROM SAMSUNG TV PLEASE
If you plugged the soundbar in to the back of the tv then you may have automatically disabled the sound from the TV. You'll have to hit the menu button on the TV and go the the Sound/Audio menu to see it the TV speakers are enabled or disabled. If you enable the TV speakers then the output to the sounder will turn off. I'm assuming you don't want that.
Feb 23, 2016 | Ematic ESB210 Ultra-Slim 2.1 Channel...
My Dell AX510 Soundbar Speaker isn't working, although the blue light is on, indicating it has power. I'm using a Dell monitor that is set up primarily for Playstation usage.
Ensure that the sound is actually supposed to be coming through the speakers. Just because the power is on doesn't mean that audio information is actually on it's way to the actual speakers. Maybe the television volume is low or muted, maybe the output volume is being routed somewhere else, or maybe the soundbar is broken. You should investigate and follow the signal to find the problem.
Sep 29, 2013 | Dell Ax510 Ax510pa Soundbar Sound Bar...
CANT GET SOUND FROM SOUND BAR VSB200 INT VIZIO VP422. THE LED LITES COME ON, THEN ONLY TWO STAY ON, THE INPUT SWITCH DOESNT DO ANYTHING, EVEN HOOKED UP AN OPTICAL CABLE.
I had a similar problem. I tried all the TV settings, but still it would not work. I plugged the sound bar directly into the cable box (AT
Oct 15, 2010 | Vizio VSB210WS Soundbar
Some DVD's dont work on my DVD player??!!
This worked for me (taken from the service manual)
Power on Unit Select Disc Then Open / Eject Then type the following...
9999 followed by *subtitle* followed by the region you want EG: Region 2 would be - 9999 *subtitle* 2
Works perfect for me :)
Mar 12, 2010 | Philips SoundBar DVD Home Theater with...
We bought a Samsung Soundbar x810 but the Subwoofer does not seem to be working properly although the blue and red led light up. I have tried rebooting/resetting per user manual instructions but it still...
Purchased a x810 & everything tests out fine except TV signal sounds from cable box. We have the Comcast cable box connected to the 50" Samsung Plasma TV hooked up to Samsung x810 Soundbar all using HDMI cables. But we are not getting cable shows sound through Soundbar. Please advise
Nov 04, 2009 | Samsung HT-X810T Theater System
Codes to make philips soundbar hts 8140/75 mulitzone
I followed another post which is a generic code for all philips dvd players. open the dvd drawer, push 9.9.9.0, close drawer. done! terrific
Jun 05, 2009 | Philips DVP5990 DVD Player
Need to multi region Phillips Soundbar
HI Ian,
Have also just purchased a Philips HTS8140 with Philips LCD screen.
Found a result on web as follows:
1.Turn on TV
2.Turn on Sound Bar System.
3.Press eject.
4.Press 9 9 9 0 (0 being Region Free or place the desired region #)
(a message displaying "region 0",or the region you chose, will appear on the screen.)
5.Switch soundbar off to soundby.
6.Turn player back on and it should be either region free or the region you selected.
So far I have not been able to check with anyother disc exept region 4.
Hope this is of help for you!
Xtopher
Jan 10, 2009 | Philips SoundBar DVD Home Theater with...
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
