Question about GPX KCL8806DT 7 in. Portable Television
I cant find tv setup in menu
Unable to change tv settings
How do I reset settings for DVD-S661 when I am unable to get the setup menu to display on my tv screen. Is there a "blind" setting change option?
Are you you using a HDMI connection fromt eh DVD to the TV? if so are you changing the input on the TV to the correct HDMI port?
Oct 26, 2014 | Televison & Video
Program tv
Set the remote control with an other code to your device, and check. If you wish to get more details, check the links given below. Setup code list and setup proceedings to many popular brand remote controls are given. Pull up older posts there. http://electronicshelponline.blogspot.com/
http://electrohelponline.blogspot.com/
May 06, 2013 | Samsung AK59-00104R Remote Control
I can't get a menu screen up on my Denon AVR 2803.
Did someone turn the OSD off on the menu? You might try a reset of the receiver. This would be in your manual.
Aug 23, 2012 | Denon Avr 2803 7.1 Channel 875 Watt...
Cant get the child lock off on the tv remote
Hi willow 42,
Enter to user menu by pressing MENU on remocon,
choose setup - high light Chile lock
Change to Off.
If still problem with it, please try to reset your TV set.
Good luck.
Mar 23, 2011 | Samsung HP-R5072 50 in. Plasma HDTV
Can't change tv from cabl
Not knowing what brand or model you have, I would guess that you have a setting somewhere in the setup menu for that. If it is an older set it may have a switch on the back near the antenna/cable connector. Thanks for using fixya.
Nov 09, 2009 | Televison & Video
Setup Menu will not display on TV screen
Ok, on the back of the unit, there is a single yellow composite output. There may also be a Red, green,blue.Component. Take 1 RCA cable and plug it into that yellow output, and route it into your TV input, also a yellow composite. Make sure that whatever input you put that into on the tv, that you change the TV input to that to view your player. when and if you get a picture, you should be able to get to the menu through the GOVID remote.
Later once that Path is working, you can upgrade it to the Red,. green, blue, if your TV has the inputs. You did not give a model for the TV or I could tell you what it has.
If you need any more clarification, please reply.
Best Regards,
Charles
Jan 05, 2009 | GoVideo Go Video DVD/VCR Combo
Innovage jumbo tv remote
how do connect the remote to the television??
Sep 11, 2007 | Televison & Video
Ilo DVDR05
To change from p-scan back to i-scan with no video picture, mu1 model: 1.turn dvd on with no disc, wait 10 sec. 2.press "setup" 3.press "down arrow"(selects audio/video) 4.press "enter" (selects audio/video menu) 5.press "down arrow" 4 times (selects scan mode) 6.press "right arrow" (selects scan menu) 7.press "up arrow" (selects interlace mode) 8.press "enter" (should see picture) Or find a tv with p-scan capability.
Nov 30, 2006 | iLO DVDR05 DVD Recorder
Sony KV-32S26 32"
One of the front control switches, that are located in the back of the buttons on the front of the set most likly are damaged or broken. These switchs are small and your going to need to pull out the entire chassis of the TV set to replair or replace them. If you have solid state TV repair experience thenm it should not be a big deal, but if you DONT please seek out a local tech to assist you with this repair as sliding out a TV printed circuit board can be a tricky thing, as it can bend ,crack or pop the surface mounted componets right off the board. A repair like this shouldnt cost alot. really all depends on if the board is damaged or not. good Luck
Sep 12, 2006 | Sony KV-32S26 32" TV
GPX KCL8806DT 7 in. Portable Television Logo
Top GPX Televison & Video Experts
Bill T
Level 1 Expert
Jaime Hernandez
Are you a GPX Televison and Video Expert? Answer questions, earn points and help others
