Question about HP DesignJet 430 InkJet Printer
Regarding paper type selection
After installing Hp designjet 430 plotter, it is not showing the paper type to select coated paper, what shall i do now?could some one help me for this problem ?
  • 26 Answers
SOURCE: Designjet 1050C
the plotter measures the media automatically. There is no size setting,only type of media.If you want to print on 8.5x 11 only a few times,load a sheet to print on by simply lifting the cover an aligning the sheet on the blue lines ,on the right side.If you plot a lot,I suggest get a 11" x 150' roll.
hope this helps
Posted on Mar 26, 2008
faxman789
  • 297 Answers
SOURCE: hp designjet 430
This usually is solved by removing and reinstalling the ink cartridges...make sure the electrical contacts are clean (use a dry paper towel) on both the print cartridge and the carriage.
If the error still happens then the carriage or trailing cable are bad and will need replaced.
Posted on Jan 17, 2009
  • 22 Answers
SOURCE: HP DesignJet 430 wont accept media
This is the problem with the sensor. It tries to read the size of the paper, the sensor is on the side of the carriage assy(cartridges are installed on this assy). You can try cleaning this sensor or get it replaced or some times the service center will replace the carriage unit as a whole.
Posted on Dec 01, 2009
Testimonial: "Is there a specific proceedure that I would use to clean the sensor?"
  • 123 Answers
SOURCE: HP DesignJet 430 rejecting media
When you load the paper, the carriage edge detector measures exactly where the right edge of the paper is located. Then the paper is rolled forward and the edge is measured again. If there is a difference in the measurements, the printer assumes the paper is not loaded squarely and rejects the paper. After you load the paper and the printer asks you to align the paper, take your time, release the paper with the release lever, and line up the right edge of the paper with the right edge of the paper roll. You might have to do it more than once to get it to load. Some plotters are very sensitive and others are more forgiving.
Posted on Apr 15, 2010
Geekman
  • 32281 Answers
SOURCE: Hp Designjet 430 new black cartridge printing blank page
Blocked print head nozzles
Inkjet printers need to be used frequently to prevent blocked print head nozzles. You may have blocked print head nozzles.
Try the printer maintenance to clear the printer nozzles.
After several deep cleaning attempts and there is no improvements in the print then a new print head is required.
A new print head maybe expensive and it maybe more cost effective to purchase a new printer.
Posted on Oct 23, 2012
HP Designjet T1200
remove any paper off/on machine re-insert paper check and select the right type of paper,if still same problem call for a service technician
Aug 29, 2014 | HP DESIGNJET T1200PS 44IN 2ROLLS 32GB RAM...
Dec 01, 2009 | HP Office Equipment & Supplies
DesignJet 5500PS InkJet Printer WILL NOT CUT THE
check the media you have selected. if you have the wrong media selected, the cutter will not work.
Nov 03, 2009 | HP DesignJet 500ps InkJet Printer
Sep 25, 2009 | HP DesignJet 430 InkJet Printer
Designjet 450C
In my 8 years of servicing plotters I haven't seen published specs as far as the paper thickness goes.But from experience and seeing my customers produce problems free plots, you don't want to plot on anything past 30 lb media. 99% of plots are done in the 18-24lbs range. Media Types: Paper (plain, vellum, coated, glossy) Film (vellum, coated, glossy, clear, matte), Translucent Bond for Black output only
Hope this helps
Mar 02, 2008 | HP DesignJet 450c InkJet Printer
Hp designjet 430
Nov 28, 2007 | HP DesignJet 430 InkJet Printer
Designjet 1050C
hope this helps
Nov 09, 2007 | HP DesignJet 1050c InkJet Printer
HP DesignJet 430 InkJet Printer Logo
18 people viewed this question
Seeker5211
Seeker5211
