Question about GPX KL858S 8.1 in. Under Cabinet TV
Dont have tv setup mode - GPX KL858S 8.1 in. Under Cabinet TV
Need codes to program my Toshiba tv
Setup codes are : 062,084,102,118,122,130,131,173,214. If you want more details about the setup proceedings, check this. A general setup proceeding to a universal remote control are given here. It might differ to model to model and brand to brand.
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Jan 02, 2013 | Circuit Electronics Universal 6 In 1...
L dont have right 4-digit code for daewoo, the codes i have,dont work
Try these codes.
0130 0004 0009 0100 ................. 0005 0138 0043 0140 0039
....... 0252 0279 0444 0080 0042 0058
....... 0017 0010 0126 0018 0127 0019
Direct Code Entry
    Code Search Method.
    1. Manually turn on the device (TV, VCR, etc.) to be controlled.
    2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
    3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
    4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
    5. Press and release MUTE to install the code. The indicator light goes off.
    Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Apr 17, 2012 | Televison & Video
How do i program my ge tv remote
Direct Code Entry
Apr 17, 2012 | Memorex MLT3221 32 in. LCD TV
Hi i have a universal remote px-rc1 and i dont know what is the code for toshiba tv 27AF45 model and how to set it so that i can switch between tv and video(AV) modes. please help me with this
Hello
Three digit universal remote codes for Toshiba TV are:
013/ 049/ 089/ 105/ 109/ 117/ 118/ 120/ 159/ 178
Four digit codes are:
0240 0261 0260 0287 0290 0358 0369
0924 0398 0274 0341
Direct Code Entry
Jan 25, 2011 | Toshiba 27AF45 27" TV
Background music is unbearable on TV - almost impossible to hear dialogue
I had a similar problem.. What's needed is to change the audio mode of the tv.
You may need the original tv remote to access it's setup menu or maybe able to do it with onboard buttons. (not the channel setup, but the screen brightness and hue and other stuff - Audio setup)
When entering the audio setup, you may find you're in surround sound or some other "type" of sound processing. Maybe simple Speech mode will suit you. Try different modes till you find a happy medium for your own taste.
Jan 23, 2011 | JVC AV-32260 32" TV
I have an RCA L40FHD41 television and a Direct TV remote RC65R. None of the codes for RCA on the Direct TV website work. What code needs to be entered so that I can control the televsion from my Direct...
try these codes " 11447 11347 11781 10029 12187
10747 11147 11247 11547 10174
10679 10774 11922 11948 11958
10038 10093 11661 11917 11953
12002 10051 10090 10278 11047
11919 "
if those dont work then try this: "
You may still find a setup code that works for your device by stepping through the library codes in your remote. The following instructions will help you do this.
StepNSet
Set the "Mode Switch" to the desired mode such as TV for a Television.
Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
Enter the code "991" followed by the "device number"
for Televisions
for "AUX 1" devices - VCRs or DVDs
for "AUX 2" devices - Audio
You can step through the setup codes for this mode by pressing the "Channel Up" key to go forward through the codes or pressing the "Channel Down" key to go back to the previous codes.
You can try out each code by pressing one or more function keys such as power, volume or digit keys.
When you've found the setup code that works for your device, press the "Select" key. "
Sep 11, 2010 | Universal Remote Control DIRECTV Universal...
Cant program direct tv remote with my new sylvania lc320slx
The remote is only programmed with only so many codes. Sadly, It doesn't hold all code for every TV made.
But you can try making the remote search every code stored inside to see if one of them will work.
Here are the instructions form the DIRECTV web site:
StepNSet
  • Set the "Mode Switch" to the desired mode such as TV for a Television.
  • Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
  • Enter the code "991" followed by the "device number"
    1. for Televisions
    2. for "AUX 1" devices - VCRs or DVDs
    3. for "AUX 2" devices - Audio
  • You can step through the setup codes for this mode by pressing the "Channel Up" key to go forward through the codes or pressing the "Channel Down" key to go back to the previous codes.
  • You can try out each code by pressing one or more function keys such as power, volume or digit keys.
  • When you've found the setup code that works for your device, press the "Select" key.
May 18, 2009 | Sylvania LC320SS8 32 in. LCD Television
Cannot turn off cc
Yes. one of those six boxes are 'setup' box.
  1. go into setup and you will see cc mode (second from the bottom of the list).
  2. simply select the cc mode and make sure it is set at "off"
  3. exit the menu and you are set.
Regards,
Feb 16, 2008 | Panasonic CT-27G5 27" TV
I accidentall setup up my tv for ez scan now what??
when your in the EZSCAN mode and its scanning you can skip the scans that you want by pressing ENTER when it begins on the scans you dont want..It will tell you what is scan mode is DTV,CABLE,ANALOG TV .Press ENTER as soon as it scans the unwanted scan modes then let it scan on DTV ..
Dec 07, 2007 | Zenith TV SPEAKER SYSTEM, FOR 50" PLASMA...
Sanyo DS 31520
make sure your got the right cable mode selected through the remote or autual switch on back of tv. if not it youll only see cable channels up to channel 13 that means in is standard tv mode or air. once you selected cable ...run autoprogram and it find all the channels for you. these newer sets, dont bother with looking for a cable switch, its all done automaticly when you hit that autoprogram button but it would be in the menu under setup.
Sep 06, 2007 | Sanyo DS31520 31" TV
GPX KL858S 8.1 in. Under Cabinet TV Logo
24 people viewed this question
Top GPX Televison & Video Experts
Bill T
Level 1 Expert
Jaime Hernandez
Are you a GPX Televison and Video Expert? Answer questions, earn points and help others
