Question about Samsung Galaxy Tab Tablet PC
My power button is dented in is there another way to shout down
The button can't press at all it got dented in , so it can't turn off
    Filmmaker:
    Uploaded 5 video answers.
  • 95 Answers
Take the battery out.
Posted on May 03, 2014
How do I get out of Safe Mode?
Hi Claudia. I found this.
I found Please remove leather case on your kindle before performing the steps below.
Please press and hold down the power button for 25-30 seconds until the Kindle restarts or Shutdown. If it prompts for Shutdown then please shut down the device and power it back on.
That should fix the problem.
If the answer to your question was informative and helpful, please show your appreciation for my efforts by clicking the green Accept Answer button right below my first response.
Thank you for choosing Experthelp.
Safe mode turns on when you shut down the kindle while the volume button is being pressed down. Solution-Restart your kindle by holding the power button until the screen shuts off. Make sure that the volume button is not being pressed while you restart your kindle. Then keep pressing the volume button, about 10 times to unstick them then turn on the kindle. Safe mode should turn offand how you go into it.
and I found this
Jan 17, 2016 | Amazon Kindle Fire HD
Get rid of dead robot
try clearing your cache partition, you can get to the android recovery with your buttons.
1. Turn tablet off. You may need to use two hands in this process to press and hold buttons properly.
2. Turn on the tablet with power button, wait a full 2 seconds from the time the tablet starts showing the red Motorola logo, then press and hold the down Volume key. (you should not hold down the power button after it turns on and logo appears)
3. "Android Recovery" will appear on top of screen if timing is done correctly. Release volume button. (if you continue to press volume down at that message, the message will cycle through "RSD, Fastboot, and back to Android Recovery. Make sure message states Android Recovery before you go to next step). If stuck at a RSD protocol or Fast boot screen, reboot the tablet by holding power button then pressing the volume up).
4. While screen states "Android Recovery", Press volume up button, the screen will say "Entering Android recovery mode" and a few seconds later an Android robot graphic will appear alone on the screen. Release buttons.
5. Hold down power button and then press the volume up key together to see the Android Recovery screen menu selections.
6. Use the volume buttons to move up and down through selection in this menu.
7. Using the volume down button, scroll down to "Wipe data/factory reset"
8. Tap Power hard key to select option.
9. Scroll down to select "Yes, delete all user data".
10. Tap the power button to select. Wiping and formatting data will take a few minutes.
11. You will return back to the Android recovery screen menu.
12. Tap the Power button to "Reboot system now" which will power-cycle tablet and eventually power back on to the Initial Set-up / Welcome screen present when you first turned on your tablet.
Jan 21, 2015 | Tablets & eReaders
Help to reboot my tablet
Hi, you need to perform a factory reset, follow these instructions:
Dec 31, 2014 | Tablets & eReaders
I've had several issues but the one now is that all my tablet will do is show a pic of an android laying down with a red triangle on it bearing an exclamation mark. At the bottom of the screen it says NO...
Oct 29, 2014 | Tablets & eReaders
Nabi jr has a green android laying on it's back with red exclamation make, want do anything. How do I fix it?
Oct 27, 2014 | Tablets & eReaders
Forgot password on icraig jelly bean how do i reset it
First, Turn your device off.
Now, press and hold the down volume button, while holding down the button, press the power button until the display turned on. then go to recovery by navigating up and down through the volume buttons.
Then quickly press the power button to confirm. And there, your device will start resetting to factory default.
Jun 09, 2014 | Craig CMP741d Tablet
I turned down the brightness on my RCA tablet and now it won't turn back on. What do I do?
You may have to reset it. With the device turned off, press and hold the volume down button, and then briefly press the power button. - Wait for the screen with the three Android images to appear, and then release the volume down button. - Press volume down to select clear storage, and then press power. - Press volume up to start the factory reset.
Mar 16, 2014 | RCA 22LA45RQGB 22 Class LCD HDTV - 1080p,...
Tablet will not charge or turn on
You may have to reset it. let if charge for about 24hrs, 10hrs may work fine too and With the device turned off, press and hold the volume down button, and then briefly press the power button. - Wait for the screen with the three Android images to appear, and then release the volume down button. - Press volume down to select clear storage, and then press power. - Press volume up to start the factory reset. if this doesn't work your charging port may be lossened or damaged, have a technician check it.
Mar 05, 2014 | RCA Tablets & eReaders
Mid tablet wont shut down
So you need to be In the main menu interface then press the power button for about 5 seconds to shut it down. Below is the power section out of the manual.
1.2 POWER
startup: Long Press and hold the power button, the system will enter the main interface
shutdown: In the main menu interface, Press the power button about 5 second to shutdown, The system can hint "power off" option, Clike"ok". you can safely shut down.
Lock screen: Short press Power button to lock screen or unlock screen.
Remark 1.When power is empty,system will shut down automatically.
2.Illegal turn off the device,restart will scan and restore the disk,it may take longer time to enter into system
Jan 30, 2013 | mid Archos M729B Android Tablet
I can't unlock my Nextbook Premium 7.
pls hw can i unlock my arnova 7b 9 dot pattern
Sep 20, 2012 | Nextbook Tablets & eReaders
Samsung Galaxy Tab Tablet PC Logo
Top Samsung Tablets & eReaders Experts
Jaime Hernandez
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
